Don's second light was my first light.
my first high power led light was a lowes taskforce.
i stuck a 18650 in there and it was really bright but started to smell funny.
My first led Flashlight was this http://www.dealextreme.com/p/3-in-1-15-1-3xaaa-flashlight-10-white-led-5-uv-led-red-laser-3248 also i f i don't know if it can be consider a real flashlight.
My first "real" flashlight was a 501 body with a q2 in it.
No, I think the 'unreal' flashlights count more! Kind of trying to trace what people were buying when 'white' LED's emerged, and were a novelty.
'Squeeze light'! Yes! My family had an incandescent one. Piece of crap. Great way to get Carpel Tunnel.
Come to think of it, my '2nd' I believe was a white 3-LED mini-mag drop-in (my first drop-in!). Fry's sold both the Nite-Ize kit (with clicky switch) and an almost identical kit branded "Balboa", I think. Stupid me, I got the Balboa, and the switch died prematurely, but the beam was slightly superior to the Nite-Ize. Still have the drop-in. But my mini-mag is dissembled, in disarray, and will probably never be used again. I truly had a love-hate relationship with the Mini Mag. Mostly hate.
Drifting off-topic: anyone remember the Radio Shack (Tandy in Europe) "free" multi-C cell plastic flashlight BODIES they used give away as a promotion every year or few for awhile back in the late '80s? I think RS was hoping you'd buy the batteries for it there. Can't remember if those came with a bulb, but the 'thing to do' was to buy RS's krypton bulb to 'hot rod' it. Remember the batteries leaking onto my friend in a tent in the middle of the night.
TerraLUX TLE-5 led upgrade for Minimag 2AA, then TerraLUX TLE-6EX led upgrade for Mag 4D, then P60 drop-in for SureFire 6P. Then the disease began...
My First LED experiences are all DIY. First were combinations of batteries connected to batteries, with resistors. The first torch format one was a double 5mm Amber LED connected to 2AA batteries via a resistor with a switch, in a PVC pipe with cork ends to hold the LED, switch and batteries.
Later there were designs for boost converters for single white emitters and Those were my first White LED torches, in various packagings. Each with a slightly different boost driver design. Everything was put together from plans, Even had to manually draw the circuit board with permanent marker before etching!
It Still works! Even the sliding switch mechanism was rebuilt from tinned wire. I think I was 14y at the time..
Emitter is Plug and Play, Can connect any 5mm emitter onto this host. But the emitter must not be disconnected when powered, otherwise the buffer capacitor on the output charges up and when reconnecting the emitter :POOF:
D10 with 4C tint XP-G on Minimum output, vs 5mm White (not a very bright emitter, prob 6000mcd or something) (this driver is very light on the emitters, low drive current)
D10 vs Green 14000 mcd LED
Lots of room
This 50 lumen powerhouse I purchased about 15 years ago because it looked like a "serious" flashlight in the package. (and its $40 price meant it had to be a "professional" torch)
It is actually very robust. Much more so than its output would suggest
As you can see, this 3-mode wunderlight has hit the ground several times from significant height, always bezel end first of course.
It's a sad light really but the 10 LEDs are white and it does turn on when the button is pressed. Which is not too damn often.
sst90host?Foy
Does it have a suitable design to take a SST-90 and sink a minutes worth of heat? hehe. Maybe...
Here's picture of the insides I took a long time ago.
maybeitcouldFoy
The first white light I remember having was an LED Lenser V2 Mini Moon it's also the only one I've ever lost.
I got it in Feb-March 2001, it has that odd coloured beam yellowish in the middle and purpley-blue around the edges.
Everyone was amazed by it. Sadly I left it on a desk in an office I was installing network cable in, sadly someone pocketed it rather than handing it in :(
My first also / Romisen RL-B7 = Still have it , but now XM-L T6
Pook: I've got something like that.
Mine is blue. I think it came with another light I bought, probably 15 years ago.
offtopiccauseitaintwhiteFoy
That was about ten years ago. It was a small LED lenser, possibly a V2 and crazy expensive. It used three AAAA batteries, that were so difficult to get. I sold it on.
An old XJC B-12 . It came in a nice box with an 18650 and a charger .
Fall of 2003 I discovered this little classic in my local home improvement store. This is a little later model of the same light (which I still have and still works just fine.)
It led me to search for 'LED flashlight' on Google, which led me to CPF, which led me to start FlashlightNews, which led me to get ticked off at CPF's management, which led me to start FlashlightNews Forums, which eventually led me here.
All because of one little LED flashlight...go figure!
Mine was Ace hardware Luxeon III(china made) light driven by 2xAA, surprisingly waterproof i left it at 0.5m under water in the swiming pool overnight and no single drop of water inside. I changed it to SSC P4 since and now it still in by box without driver hoping to get a new lease of life.
Wow, an Indonesia member! Welcome, rizky_p! Seen you around here before but didn't notice your location--hello! They have ACE hardware in Indonesia? Just products, or the actual hardware stores?
My first LED light was an unbranded, clear anodised 9x5mm LED cluster light, resistor regulated, 3xAAA, around 1999. Back then, I was admittedly ogling at the then-new LL lights with those funny names like "V²" or "photon pump" and the ridiculous pricetags, but never bought one. More sense then money.
My second LED light was this one: https://budgetlightforum.com/t/-/1966#node-2175
I got it sometime around 2000, and was really proud of it. It had the air of "professionality", or at least I was convinced of that.
Despite a few more 9-LED and 12-LED cluster lights, it wasn't until late 2009 that I looked into LED lighting more seriously, again. I tried to modify a minimag with a "super-bright 5000K" white 5mm LED, directly driven off two alkalines. This didn't satisfy me for long, and in spring 2010, I replaced my crude first attempt at modding with a proper terralux TLE-5EX conversion which I used for well over a year.
If my foggy memory recalls accurately, my first “real” LED light (other than some run of the mill 5mm LED) was also a TaskForce from Lowes. I remember my brothers showing off their 1W LED torches and being amazed at the output. Saw this one at Lowes and had to have that 1W beast! Oh, how times change!!
my first was a White LED keychain with a 5mm led. when the battery died, it got tossed.
my first hand held white led light was a Maglight 2AA incandescent with a cheap 5mm 3LED drop in module that i got at walmart. little bit blue tint. i think i lost it somewhere.
the first that had some usable output was a Coleman max with a XR-C (i think) led. 3AAA. fairly green tint. still have it. it may get some mods soon. 2nd light from the right. you can see the green compared to the rest of the lights.
Brian
