Mini C8 AAA XM-L U2 Mod. XP-G2 Shots Added. 1.17.13
50 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 4 days ago
I got all excited seeing these lights and thought as a few others did that it would make a good host so a couple were ordered. Here is a link to another post on these mini imposters. The flashlight is nothing special except for its good looks. Anodizing is patchy at best and the threads and o'rings are ok. light output is a bluish very dim beam with a small hot spot. I am going to mod the other light with the standard reflector. It has a plastic 21mm lens standard which I did not want to use so have ordered an AR 21 mm lens. I think the standard reflector will work with either a XP-G or XM-L. The round hollow part (see other thread for pictures) can be filed down so that it sits over the led and the hollow part left will fit over the square base of the XM-L. If you used an XP-G I would file the hollow part of completely and it should sit on the star ok.
Enough waffle. Here's some pictures.
A standard C8 against the imposter. The mini actually looks a lot smaller than it does in the pictures.
The parts used were a custom pill, 10 degree TIR lens, IOS single mode AA driver and XM-L U2 LED I had kicking around.
The flashlight had to be bored a couple off mm deeper to fit the TIR in deep enough so that it did not stick out the end.
Another shot to give you an idea how small this thing is. Unfortunately I do not have another AAA torch to compare it to.
And finally the beam shot. guess which one is the modded light. At the tailcap the std light draws .35 amp and the modded light is 2.2 amps with a Turnigy LSD AAA.
I decided to use Old Lumens trick of using an XM-L TIR with an XP-G2 LED. The results to say the least was surprising.
The Fence shot. The XM-L on the left has a lot larger hot spot and a far bigger spill than the XP-G2 on the right which is a lot brighter in the hot spot. Both LED's were driven by identical single mode AA drivers.
The plants in the middle were about 9 to 10 meters away. To me the difference was astonishing and the TIR worked perfectly with the incorrect LED being used in it.
Firstly is the XM-L U2 which I would describe as a cool white.
The XP-G2 is supposed to be a 1D tint. The light itself is a lot warmer in color.
With the XM-L in this light I was a little disappointed. The XP-G really brings this flashlight alive.
Edited by: MRsDNF on 01/17/2013 - 06:02
scaru
scaru's picture
Last seen: 4 years 1 month ago
Nice work! Very impressive AAA light.
Slim Pickens
Slim Pickens's picture
Last seen: 1 week 6 days ago
Very nice mod! I’ll take it Silly
How do you like that boost driver btw?
Old-Lumens
Old-Lumens's picture
Great mod!
Which driver is that? I have been looking for something in single AA/AAA that will put out more than about 500-600mA. This driver puts out over 2A stock?
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
MRsDNF
MRsDNF's picture
Thanks guys. It is the first time I've used this driver. I did not take any measurements at the LED. One thing I can tell you though is it has the best mode memory of any light I have owned. I will check it out tonight to see what the output is like. Its another six hours before its dark.
Slim Pickens
MRsDNF wrote:
One thing I can tell you though is it has the best mode memory of any light I have owned./p>
I hope so!
(…dat light humor)
MRsDNF
MRsDNF's picture
Sorry OL. I missed your post. I started 3 pages back and W8 does not refresh the pages. Its a single mode from IOS.
Link. http://www.intl-outdoor.com/nanjg-110-boost-12aa-circuit-board-p-482.html?zenid=ftcaf5cnhmoum8fkbunu4jk5t6
Chicago X
Chicago X's picture
Last seen: 7 years 6 months ago
Nice job on a small (frustrating) torch.
I had a couple of these; tried modding one, binned it.
The second one was quickly passed on before it met the same fate.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
dct73
Love it!
MRsDNF
MRsDNF's picture
I've just finished a quick run time test. With the Turnigy LSD AAA 800mAh battery at 1.4 volts and ambient temp at 20 degrees the flashlight ran for 25 minutes with a maximum temp of 37 degrees before the temp started dropping and light output dropping very quickly. With the battery removed voltage was 1 volt.
mattthemuppet
nice little build! I’ve used those TIRs and like them a lot, very useful beam. What diameter is the driver? V. interested in current at the emitter too.
OL – with these AA/AAA 1.5V boost drivers, tail cap current is going to be ~4x emitter current for a decent driver. So this should be putting out around (hands waving) 500mA at the emitter, give or take. I’m pretty sure >1A at the emitter from a single AA is pretty much impossible, due to physics and other stuff I don’t understand.
MRsDNF
MRsDNF's picture
The driver used was 17mm in diameter. The pill is stepped to suit the insides of the flashlight body. The diameter where the driver sits was 18mm from memory which made the side walls on the pill .5mm thick. The light output from this driver doesn't set the world on fire but at the end of the day it is run from a AAA battery with a run time of 25minutes si I suppose you cant expect much more. I have another to build and will use an XP-G2 with the same driver so it will be an interesting comparrison. This may take awhile though as I'm heading to ezarc country for the land speed record attempts mid way through next month.
relic38
relic38's picture
Last seen: 3 years 3 weeks ago
Hey O-L, I just received a 1-2AA/AA boosty from FastTech and so far it looks decent. At 1AA/AAA it drops off a bit, maybe around 600mA. On two cells it easily puts out 725mA. The efficiency didn’t look too bad either. Might be worth a try. I haven’t given it a full run through yet, but iitial tests look promising. It’s the best 1-2AA booster I’ve run into so far… I haven’t tried the one at I-O.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
djozz
djozz's picture
Last seen: 4 hours 9 min ago
cool and fun light! Sort of O.L. style mod without the maglite+219+copper pipe to start with Wink. Oh, and without direct drive, and with a lathe. Ok, quite different from O.L. style then. But it does have the TIR Smile
MRsDNF
MRsDNF's picture
relic38. What does the driver linked put out on one battery?
JohnnyMac
JohnnyMac's picture
Last seen: 1 month 6 days ago
Great job on that light!
If I'm figuring right, 1.2v x 2A = 2.4w and if the emitter has a forward voltage of 3.2v then the driver is providing 750mA (2.4w÷3.2v=.75A).
Not too bad for a AAA driver, IMO. 8)
relic38
relic38's picture
FT SKU # 1127402 , tested with a power supply, driving an XM-L:
Vin (V) Iin (A) Iout (A)
0.9 1.70 0.26
1.0 1.80 0.32
1.2 1.87 0.43
1.4 1.90 0.55
1.5 1.90 0.60
2.0 1.48 0.73
2.5 1.04 0.71
3.0 0.87 0.74
I didn’t measure emitter Voltage, but XM-L’s are below 3V when under 1A, so this is between 1W and 2W of drive. This driver appears to be between 50% and 75% efficient. IMO, not too bad.
Note: This driver does not support 10440/14500 Li-Ion. Even a LiFePO4 would be borderline (emitter current was over 2.5A DD at 3.7V!)
These are the best performing ones I’ve tried so far. When I get around to ordering from Manafont, I might throw in that other one just to check it out.
Welcome the night.
MRsDNF
MRsDNF's picture
Thanks guys. We just need a 3 mode now, high, med and low with memory and it would be ideal.
MRsDNF
MRsDNF's picture
XP-G2 pictures added and night shot pictures added to the first post.
JohnnyMac
JohnnyMac's picture
Fantastic! Great work, mate. 8)
scheven_architect
Last seen: 3 years 1 month ago
SO cool, since I’ve got my olight I3 yesterday, I’m starting to fall in love with these small form factor lights.
totilde
totilde's picture
Last seen: 1 year 12 months ago
Very beautiful light, I’ll try to buy some
Mooooooo
scheven_architect
what’s the total cost of the xpg version?
Really like the ‘cuteness’ of this light with the power of the xpg,
Too bad the stock one sucks Smile
MRsDNF
MRsDNF's picture
Thanks guys. Costs are. All prices are from memory but should be close.
Ebay flashlight around $3.50.
Pill 1 hr labour and $1.00 material.
IOS driver $2.80.
LedDna LED (out off stock) XP-G2 $5.50.
10 degree TIR about .75c from cant remember. Lots of stores have them
I forgot to mention that I tried the stock reflector but the hotspot was very shadowy. I did not play around with heights as the TIR was sitting there looking at me.
dct73
That’s better! XM-L’s just don’t work too hot in these tiny lights. I’ve been thinking about popping an XP-G in one since your first post. Now I’m sure. Smile
MRsDNF
MRsDNF's picture
I've had time to sleep on it and I'm not sure if I have been a little un fair on the XM-L. The difference in patterns is the main reason the XP-G looks good even with the same TIR. The XM-L puts out more off a wall of light so all the light is spread around whereas the XP-G has a tight hotspot making the light shine farther away making it look far more impressive and in this size light seems to be far more suitable. At the end of the day it would depend on what you wanted to do with the light.
dct73
Ya, it all depends on your use. I have two xm-l’s and one xp-g in AA form. If I’ll be using the light outside I’ll grab the xp-g almost every time. Like you said, in this size light the xp-g seems more suitable. I just have to wait until my latest order comes in before I get started on anything new.
Halo...
Halo...'s picture
Last seen: 4 years 4 months ago
Such a cool little light. Beer
Old-Lumens
I use the same Mfg & angle TIR on XM-L, XP-G and Nichia. XM-L is always going to be floody, XP-G and Nichia will be more of a spot. Does not seem to matter the die size as long as the led is centered in the TIR.
unknown00101
Last seen: 1 year 1 month ago
I’m trying to find a suitable TIR optic for basically a mirror of this mini C8 mod. I don’t have the mini C8 in my hands currently, so I don’t have the height measurement.
XP-G2 led on aluminum. The pill will probably be copper scraps soldered together. Same driver from Intl.
Would any of the tight angle optics from FT work?
MRsDNF
MRsDNF's picture
This is a link to the TIR used (from memory).
http://www.fancyflashlights.com/goods.php?id=341
The body had to be machined slightly deeper to fit the TIR in and the lens pressed in. If I was to do it again I would machine a small groove at the outer edge of the TIR and make a spring clip from a P60 earth spring to stop the battery pushing the whole lot out making for a bad positive connection. Similar to how the lens is held in place her.
http://budgetlightforum.com/node/20696#node-20696
The XPG-2 will work fine with this TIR as long as everything is centered.
I’m looking forward to seeing your build.
