Are my Eneloops genuine?
25 posts / 0 new
sb56637
sb56637's picture
Last seen: 40 sec ago
Hello everyone,
Well, my Eneloops, cheap NiMHs, and cheap charger arrived from China in pretty good time, three weeks exactly to South America.  But what do think about these Eneloops?  Are they genuine?
And what about my charger?  Do you think it's a genuine POWER charger?  It's "Omnipotent" too, which means "All-powerful".  :bigsmile:
Don
Don's picture
Last seen: 2 years 3 months ago
From the Sanyo HK website, the packaging looks very similar but not identical for the product code,
http://www.sanyohk.com/main/product.php?product_code=R1S4QDER#
The usual giveaway is misspellings on the packaging or battery like the "genuine" Panasonic CR123s I got on eBay which say "Matsushita Elestric Industrial Co."
If you have eyes the age of mine, use a magnifier to check for typos in the small print. I'll put up some pics of my known genuine Eneloops for comparison though minor changes may have happened in the two or so years since I bought them.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
On the battery one of the lines says "Do not dispose of in fire nor short-circuit".  The "nor" sounds a bit odd to me.  I would put "or".
Don
Don's picture
The light box and the tripod are somewhere in the trunk of the car just now so here are some not great pics to be going on with. the flash has not made them easier to see.
0
45
90
270
385
top
bottom
There are 4 vents at 90 degrees apart at the base of the +ve button, though i think I read on CPF that there were some with three vents instead but I can never find stuff on CPF these days. A quick look through the "Flashlight Electronics Batteries Included" section should give some answers with any luck.
About the charger, not a clue.
Don
Don's picture
"Nor" is more grammatically correct even if I'd use "or" too.
alfreddajero
alfreddajero's picture
Last seen: 2 years 4 months ago
Comparing my cells to what don has mine are the exact same except mine says HR6......and i have had these cells over 5 years now, bought them at wallmart when you could get it ther.
With Darkness, there will always be Light.
sb56637
sb56637's picture
Hmmm, thanks for the pics Don!  Mine are "Size AA HR6", I'm not sure why that is different from yours.  And the precautions bullet points are in a paragraph instead of aligned in a list, as this terrible picture kind of shows:
sb56637
sb56637's picture
Thanks Al.  Do yours have the precautions written in a paragraph with bullet points or in a bullet list?
Don
Don's picture
The R6 is AFAIK the ISO designation for that size of cell (Actually the IEC is the standards body - the International Electrotechnical Commission AFAIR) - it may be that the ANSI standard is different. Turns out I'm not entirely right on this - at least according to the source of all that is apocryphal. The ANSI name as far as I can figure out from a poorly written article is 15H. The HR may be for the part of the world that goes by ANSI instead of IEC.
http://en.wikipedia.org/wiki/Battery_nomenclature
R6 is the size of the cell - the H prefix means NiMH rechargeable. So both R6 and HR6 are correct though HR6 is more correct. I suspect a typo in the Wiki  as it says the H should be a suffix which would make the proper name R6H. Actually as it is in Wikipedia I'd need signed statements from three known expert witnesses before I'd necessarily believe that water is wet.
fishinfool
fishinfool's picture
Last seen: 3 years 6 months ago
All of mine look exactly like yours sb56637 and they all have been purchased at Thomas Dist. no earlier than Dec. 2009 so it looks like all of your eneloops are all legit.
 What is the date code or yours?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
sb56637
sb56637's picture
Sweet, thanks!
sb56637
sb56637's picture
Sorry, where is the datecode?
alfreddajero
Heres mine....Sanyo must have changed the label at some point or another.......Yes my cells have been through hell and back, what did you expect from 5 years of use.  And this is what happens when you force the cells into a tight fitting tube made for alkalines.
alfreddajero
You will find that on the seem....your going to have to hold the cell right next to a light so you can see it since its basically pressed into the label.
fishinfool
It's normally underneath the paragraph but it's not in colored print.  It's stamped on there so you need a magnifying glass and the right angle to see it.  Here are a few of mine:
09-07TK (Jul. 2009)
09-0610 (Jun. 2009)
09-07TG (Jul. 2009)
sb56637
sb56637's picture
Ahh, I found it.  09-09S
fishinfool
So yours is September 2009
sb56637
sb56637's picture
Cool, it looks like they're genuine then.  I got them from this seller on eBay.
Don
Don's picture
08-02RT mostly with some
08-02RQ
alfreddajero
Not bad a price indeed.....very good in fact.  So how do you like them man...have you used it yet.
fishinfool
Those are a little cheaper than the ones I buy at Thomas dist. so I think I'll try them out next.
sb56637
sb56637's picture
I haven't really had a chance to do runtime tests, which is what most interests me.  Wink  I'm currently charging the cheap BTY NiMHs that came with my charger to make sure the charger won't destroy my Eneloops.  The charger cost $7.00 including 4 AAs and 4 AAAs.  It's not exactly a high-quality device.  It's supposedly a low amperage charger, which is what I wanted.  And it does appear to have four individual channels.  The only problem is that when I put in more than two batteries the individual red lights above the batteries don't light up, just the green one in the center.  The green one in the center seems to run all the time, so I doubt it will indicate when the charging cycle is done.  I guess I'll just leave them in for 24 hours.  It does appear to be charging them, because I gave it 20 minutes and tried one of the batteries which I had previously drained dead, and it had charge in it.  So we'll see.
Don
Don's picture
As I remember it is a 200mA charger which is neatly on 0.1C (a tenth of the rated capacity). The standard for charging at 0.1C is for 16 hours. They are probably safe in the charger for a day or two but it is a bad idea in general to leave cells on charge indefinitely. Nor is it necessary with low self-discharge cells to top them off before use. It is best to run them well down (Around 0.9-1V per cell) then charge them back up. If your power is flaky or prone to brownouts, a little longer won't hurt. If you can, it is a good idea to keep an eye on the power supply voltage - the cheapest of multimeters will usually do this- just remember not to electrocute yourself.
Overcharging kills more rechargeables than anything else.
sb56637
sb56637's picture
Thanks Don, I was planning on topping off the Eneloops, I don't think I will now.  I guess I'll just commence with a runtime test then!
fishinfool
I normally fully discharge all my nimh batteries with the c9000 before doing a regular charge, r/a or break-in.  I keep records on all my cells so with a full discharge, I get pretty accurate mAh totals.
