I think the dimming of the SC600 after a while is the built-in timer in it. Using a stopwatch, I have tried it several times in my SC600. If started on TURBO mode, the light will step-down to HIGH after exactly 5min, 3 secs., or if a ‘tired’ cell is used, then it will step-down anytime below 5min.
A bit of glass is missing on the SC600, right?! It needs emergency care before mkett39’s bucket of oil! The T50 is dead, its lost already. Let us treat our wounded! Please!
Just got the package and do I have some news for you! I decided just for the heck of it to drop a fresh battery in the UF and she functions perfectly. So it seems we will have two working lights to conduct the test on. Hope to do test fri or Sat and will post pics and results.
I’m willing to bet it had a bad connection with the head off the body tube. The pill in the T50 is basically soldered to the body and you can break this solder connection and have issues, I have with mine, but if it’s together snugly mine works fine.
My guess is that some water left in the light caused a short somewhere. When dried up it worked again, just like the pre-smartphone Nokia's that were submerged: open it up, let dry for a week, put in a fresh battery and presto!
Wow! I am shocked! I tried both the power supply and 3 different 18650s. I just realized I did leave some batteries in those lights, so enjoy the new batteries mket. ;)
No, it killed one of my batteries. Sent to scaru without because 1) it’s about the lights not the batteries and 2) didn’t want any problems with the geniuses at the post office
Just tested it to answer your question and looks like I spoke too soon because it’s working again. Left the batteries in for everything except the two bakings and the boiling. After the second baking which was to dry both lights out and my final test, the battery I’d been using in the UF-T50 wouldn’t put out. Thought at first the light had died but popped in a new battery and it worked. My guess is all the water leaking into the UF-T50’s battery compartment eventually somehow took its toll but only temporarily. At least it didn’t pull a Boeing 787 Dreamliner at Shadow HQ
OK, here is the picture showing both lights working the day of the test.
Now what was strange once again as the t50 was working since I had gotten and it in fact was not the battery. Both batteries tested at 4.04 volts but something revived it. However, after taking this picture and getting ready for the oil dunk it knocked against the ZL and went out. Never to come back on! I could hear something rattling in the pill but to no avail would not work but continued anyway with all test.
The oil bucket with low viscosity hydraulic oil. sc600 first
T50
I found no evidence of oil getting in. I used tape on the sc600’s lens which worked fine.
Prepare to be drug along behind my pick-up. SC600 is on
SC600 broke my small line about 50 to 75 ft in but T50 went about 300ft before coming off.
The SC600 was off when I picked it up and would not turn again. A few scratches and such but both lights took it well with no broken parts.
The PUNISHER!!!
prepare to be rolled over!
