REVIEW: A8 BLF Edition - 1x26650 - XM-L T6 NW
_the_ +1 A Gentleman..
Gords - Your response to the new member from CPF was/is poetry. Eloquent and well articulated..
I quite like my A8, although the one problem is it isn’t floody if you’re referring to spill, in fact the spill is very narrow. The hotspot is similar to to a P60 so this part of the beam profile could be considered floody. The problem is the Bezel as it cuts out a lot of the spill due to it’s recessed design. To get mine off I had to carefully apply some anti adhesive gunk as mine was glued. Once removed the spill size is average.
It's too bad the drivers are out of stock. Is there a similar alternative?
Mine arrived today. Works great with my new Soshine 26650 LiFePO4 :slight_smile: Feels very solid but heavier than I thought it would be. No lanyard hole though.
18650 adapter + holster were included. Overall great price/performance. I wonder how long it would run in moonlight mode? J)
WKJR, I think we've discussed this before: I had issues with my first A8 spontaneously changing modes while bike riding. With a lot of finagling in the tailcap area, I got it to quit but then I sold the A8 'package' to another cyclist that was just beginning night riding. I'm curious if you've used the BLF version yet on your bike and if you've had any issues with mode switch?
My light is in the Chicago area, I'll be getting it delivered to work on Monday.
I’ve actually tried banging mine about to induce a mode switch, won’t happen. No matter how hard I bang it about it stays locked in, you should be fine 8) I’m using keygos protected cells in mine if it makes a difference, but I can test with button top king kongs if you need?
That´d be awesome : )
Thanks, gords but no need. Thanks for the reply, whokilledJR is probably asleep right now. Glad to hear your copy works so well. I've missed this light since I sold it and can't wait to get the BLF Edition.
I have unprotected KK and Keeppower 26650 (protected KK) cells to try with it next week.
Ok, I'll get right on it.
No need to hurry. The night is still young.
Thanks for the unintended tip on the keeppower 26650’s, I need some decent protected cells for a build, I was looking at the enerpower? Cells from Germany as they are hkj tested at 4500mah, and I want run time and output from this build.
Protected king kongs sound good to me though and I like my keeppower 18650’s :slight_smile:
Ok, here the pictures are. For the beam comparison both were on their highest mode.
Hope this helps, I will add this is a great light! I recommend it 100%.
Umm is it just me or is there only one beam shot pic?
Nope, there are two, one intense hotspot on the right, one dim diffused hotspot on the left.
o_O
And the left one is the UF-210?!
Never xD
I thought the UF-2100 is bright… but here I can barely see it. Is the A8 really THAT much brighter?
You mean the UF-2100? Then yes, or actually mine is one with an upgraded driver. The hotspot really is that much more intense.
If you´re bored and want to do me a favour, could you take two separat pics showing UF on high and A8 on high?
In case the difference is really still that big, I think I… “need” some new lights
Saying I'm bored is an understatement. ;) I'll go pull out a tripod and manual camera so I should be back with pics in 15 minutes or so.
Did you go with a cool white a8 then? I’m loving my 3c one.
Yep, mine is CW. Here the individual pics. As before they are both on their max setting.
A8
UF-2100
And a mouse over. Mouse over for A8, mouse out for UF-2100.
If you need any other pictures tell me.
