No need to hurry. The night is still young.
Thanks for the unintended tip on the keeppower 26650’s, I need some decent protected cells for a build, I was looking at the enerpower? Cells from Germany as they are hkj tested at 4500mah, and I want run time and output from this build.
Protected king kongs sound good to me though and I like my keeppower 18650’s
Ok, here the pictures are. For the beam comparison both were on their highest mode.
Hope this helps, I will add this is a great light! I recommend it 100%.
Umm is it just me or is there only one beam shot pic?
Nope, there are two, one intense hotspot on the right, one dim diffused hotspot on the left.
o_O
And the left one is the UF-210?!
Never xD
I thought the UF-2100 is bright… but here I can barely see it. Is the A8 really THAT much brighter?
You mean the UF-2100? Then yes, or actually mine is one with an upgraded driver. The hotspot really is that much more intense.
If you´re bored and want to do me a favour, could you take two separat pics showing UF on high and A8 on high?
In case the difference is really still that big, I think I… “need” some new lights
Saying I'm bored is an understatement. ;) I'll go pull out a tripod and manual camera so I should be back with pics in 15 minutes or so.
Did you go with a cool white a8 then? I’m loving my 3c one.
Yep, mine is CW. Here the individual pics. As before they are both on their max setting.
A8
UF-2100
And a mouse over. Mouse over for A8, mouse out for UF-2100.
If you need any other pictures tell me.
Aaaaah, that`s what I thought. The bright hotspot from the A8 confused the camera and killed the UF´s light.
Thank you very much, scaru!
Isn’t your 2100 an e1320 edition? Damm! Makes me even more happy with my blf a8.
Yep, so mine is actually more powerful than the average one. :evil: The A8 is actually a pretty awesome light.
Is that UF-2100 driven at 2.8A or 3.5A?
-Garry
Smo vs op reflector then I guess, plus >20mm vs 30mm
When I measured it through the tailcap I got 3.1 amps.
I started to get in on this deal but didn’t. Boy do I regret that decision!
Rey announced in the sales thread that he still has some left. Jump in before its too late!
-Garry
He has at least one less than when he made that announcement. ;)
