That theory does not fit.
I will call the performance of these two batteries virtual identical.
The lowest trace (i.e. the 5A) is the best to see differences in protection.
Yes, the 5A trace is different but the capacity is the same. So that would be a different PCB. Why doesnt my theory fit then?
The 5A track is the same for the two batteries, except at the start and that has nothing to do with the protection.
Okay. So there is a difference in the cell?
That dip at the start might be due to temperature (The cell need to heat up a bit, to get full performance), my testing lab does not have a tightly controlled temperature, it will vary a few degrees.
Thats plausible. Thanks for enlightening me. :)
Thank you for conducting your tests and sharing your findings.
Thanks very much! Frontpage’d and Sticky’d.
Where can I get these batteries??
HKJ posted in his graph.
HKEquipment
HKJ, will these fit in the TN30 & TN31? Thanks.
Any known fav lights that these positively won’t fit in? I know Hi-Max’s won’t fit in 501Bs, but I’ve not seen too many batteries that are so big that they don’t work in most lights.
The diameter is to large, but they do fit in length.
I would expect there are many light, but I have not tested.
Rusty Joe:Where can I get these batteries??
Distributor On CNY Holiday
I think fasttech has them in stock though. I ordered a set a week and half ago and just got them. Got another set coming in.
Again. I. Advance I apologize but if I had to pick between the keeppower black 3400 maH protected or these Panasonic 3400 maH protected which is a better performer?
HKJ:This is a very good battery, except for the length. Only buy it if you know you equipment can use a very long battery!
I have these Batteries, they are a tight fit, but they fit both the TN30 and TN31.
Keeppower, without a doubt
