Wow, that’s a howitzer of a light!
I wish it was 3xD!
i suppose a driver swap + a small spacer could make it 2x26650?
I’m outside my local HD, No luck! :_(
Thanks BR for the photos! Any idea if the pill is hollow? I'll try to check back with the driver diameter soon.
-Garry
Anyone ever used aa batteries in a light like this? Can you get the same output?
I agree! Why the heck did they go with 3 C's? It's already a monster off a light! With 3D's they could have advertised more runtime too! The Black Friday one made sense to be 3C, but not this one.
-Garry
I doubt alkaline AA's would push as much current, but NiMh's would be fine.
-Garry
Because there are lots of cheap 26650 battery tubes now.
I doubt alkaline AA’s would push as much current, but NiMh’s would be fine.
-Garry
Sorry I really meant aa eneloops.
Would they work?
Should, I can test another day.
-Garry
Tailcap current on included fresh alkalines: 3.10A very quickly declining to about 2.5A where it continues declining slowly. I wonder how steady NiMh's would be?
Yes plastic reflector and lens dimensions 63.2 Diam x 57.4mm deep. Driver is 20mm press fit. Pill doesn't appear to be hollow. I didn't pull emitter up, but can see plenty of aluminum and plenty of thermal glue.
Damn bright too! Didn't shine outside yet, but bright as hell inside!
-Garry
OK Garry, I’ll check the store by work this morning.What do you know, I happen to have a gift card to HD from X-mas!Good luck in the field today, it’s gonna be cold here in MD as well.Lukily one of the shop heaters is right over my bay!
Thanks betweenrides, wish we got defiant brand over here
It certainly sounds like a good potential mod host, it should take one 26650+ spacers, might get to keep it up at 3a for a while that way and retain the 3c capability 8)
A few more photos I took:
Driver = 20mm
Reflector Diameter:
Reflector Depth:
Shot in my hand (for size);
Rough Whitewall shot (taken with my phone, for what it's worth, distance to wall approx. 10 feet):
By the way, it was 1°F outside today at the site I worked at. Windchill at -15°F. Wasn't too bad really, so long as you dress for it. I usually jump at the opportunity to get out of the office into the field, but last night I was questioning my sanity at doing so this time!
-Garry
(P.S. I'll try to come back with current draw on NiMh cells at a later time. I might have to charge them up first though.)
Thanks for the pics! Fortunately my local HD didn't have them, so I still have 20 some bucks in my pocket :)
Oh, man....that thing is SO getting cut down to 1 x 26650....
Oh, man….that thing is SO getting cut down to 1 x 26650….
Yep, I’m pondering 2 different builds- IF I can find one that is!
lflex plus 3 nimh c cells
lflex plus 1 26650 cut down body
I guess I should have measured inside battery tube diameter and tried a 26650 cell for fit? Sorry. Wait! I have a 26650 (protected TF Flame) at work I can try! Be right back!
EDIT - Nope! Won't fit. Would have to bore the tube slightly. It can probably be done, but the tube isn't very thick. This would look like a monster in a single 26650 configuration!
-Garry
Dang it.
Thanks, Garry.
That’d be pretty sick w/ 26650. I wonder who I need to talk to at “Defiant” 8)
