Shadow SC600 vs UF-T50 -- Winners Announced -- The Lights Are Done!!!!!!!
I have contacted Zebra light. I have not heard back yet. I did not contact UF, since they are overseas and even if they wanted to send parts, it would take weeks, since the Chinese new years is just about upon us.
I could southern engineer them, if that's the consensus. I just think the Zebra light is a nice light and I would like to put it back stock. The UF, I don't care. That light is a cheap copy and to me, it doesn't matter if it turns out something else. I can do something. It just won't be pretty, but you know what? That was the whole point of this thing, to make what I can out of them, so I will, even if they end up being candle holders.Tongue Out
Just give me a few days. I will know how it is going by Monday. I need the week end to think things out.
Shipping from China usually takes 2-3 weeks, thats not too much.^^
If Zebralight customer service doesn’t pan out…
Another vote for using them as a twisty. Tho please don’t permanently seal the switch. Silicone sealant should be removable. Give the future owner the ability to try other mods so the lights can have a continuing journey! Perhaps they will be passed around like BLF mascots!
Direct drive, AMC7135 single mode or maybe 8* AMC7135 low,med,high . If the twisty is easy enough for mode cycling.
Looks like nobody here is even considering the Uzi test. That would’ve been kinda neat to film. :frowning:
Well, we tried external pressure with the two of them. I say replace the battery in each with an M80, run the fuse out of the switch holes, and test them for internal pressure resistance. >)
Turn the T50 into a single mode mule, the SC600 should try and get warranty service from ZL.
That’s pretty inspiring….to apply this ‘never-say-die’ spirit in life as well as lights!
I can’t wait to hear zebralight’s response….
i think that is a great idea… we are testing the limits of these lights. after all, if theres a warranty, how far will that warranty go???
And if they do fix it, I think we know what to do with it. :Evil: Just need to make sure it comes from a different address each time. And who ever has it when they refuse to warrant it keeps it. :P
lol. so its kind of like russian roulette. we each take our turn, who ever bites the bullet, errrr, wins?
Weld ’em up into a steampunk hybrid !
Would like to see it as a BLF “perpetual trophy” light !
I am going to start with the UF T50 first. I have decided it will have a TIR optic with an 8x7135 driver and the tail cap will be the switch (twisty).
ufb1
I have tested the led. It works. The TIR is a gift from a member here and it is 26mm, but it is not for an XM-L. We will see if it will produce a good beam, or a terrible beam.
I have a lot to do, so this is just a teaser, naturally.Wink
01-25-2013
I had time to do a little today. Just enough to make sure the stack up will work.
11
First thing was to remove the locating tab from the optic, with files.
12
But the optic didn't sit down in well and the stack height was too short, so I cut the old reflector,
12a
and used it as a base and support for the optic.
12b
The optic sits in the reflector and it is supported.
12c
The head is together and the optic fits well in the bezel, (after a little sanding around the outer edge of the optic).
12d
The base of the pill seats exactly where it did before.
12e
But that hollow pill does not work for me, so Copper it is, to fill it in.
12ff
I will use an 8x7135 driver with H/M/L modes.
12g
That darned pill still has no contact with the head, so even with the copper inside, it will heat up fast.
12h
I think I can use some copper sheet to fill in the gap between the pill and the head and help with the heat problem.
That's all for now...
01-26-2013
The O-L paint and body shop is open today.
pbs1
I was at the point where I had to do something with the UF, as far as the exterior, so I can finish the guts, so I decided I might as well paint both of them today.
pbs2
The UF T50 gets a black with copper flake coating, followed by clearcoat.
pbs3
The SC600 gets the rough Brown coating, followed by clearcoat.
The incandescent lights are my oven. Man I hope I never have to give up incans, or my body shop will be closed for good.
That's all for now. It will take 48 to 72 hours, before I can work on either light any more.
01-27-2013
Remember how I said 48 to 72 hours. I lied to you! Tongue Out
za1
The pill is all done and in place. It has an 8x7135 driver with three modes H/M/L.
za2
Here's the TIR optic. The bezel is not round any more, but it is what it is.
za3
Tail Cap. This light is now a Twisty!
za4
Yep, since the paint has Copper flake in it, I used a Copper round to cover the original switch hole.
za5
It's hard to show the copper in the paint, but in the sun, it sparkles.
OH, here's a little Bonus!
The SC600 is DONE!
sa1
The head.
sa2
The Tail Cap. This light is also a Twisty now!
sa3
sa4
I used a Brass round on this one. I think it matches the paint better.
I didn't do any build photos, because all I did was put in an 8x7135 driver. The led sits in the head, on a flat, so there's no pill and nothing to really show. I did mess up though. This driver has the stock five modes. Sorry 'bout that, but I ain't gonna take that sucker apart ever again!
That's all Folks. I would love to do beam shots, but I do not have an 18650. I just can't do them by trying to hold 3AA cells up to the light, while taking photos.
nice upgrqade the TIR, i hope it will work fine.
More photos of the UF build updated in POST # 299
Thank you Old-Lumens for your first flashlight aid and the pictures.
I think the Zebralight service would laugh about the pictures of the SC600 or ask themselves: How can they do this torture to the small flashlight.
Do you told them, what are the reasons for the actual conditions?
I told them we were a bunch of certifiable nut jobs on BLF and we had nothing better to do at the moment, than to torture inanimate objects.Wink
I told them about the thread and gave the link to it. No reply so far. They are probably still laughing.
lol. you should have said you were just hiking a trail at the local high school and it dropped out of your pocket :stuck_out_tongue:
should be interesting to see the response
fixed it for you :stuck_out_tongue:
What a tradition to start with! Perhaps from now on all manufacturers supplying BLF edition lights will test theirs like Shadow, Scaru and Mkett39 did as part of BLF critical tech specs to ensure worthiness in carrying the badge. Don’t say we never told them so! :bigsmile:
