Review: Four-way Convoy S2/S3 mini-review
114 posts / 0 new
rivet62
Last seen: 8 years 3 weeks ago
I’ve been thinking about upgrading my EDC, an Eagletac D25C2 mini. It is a 2xCR123 XPG light with an advertised 343 lumens. Although it suits my needs well, I’m moving toward 18650 LiIon cells for my using lights, and perhaps it is time for an upgrade.
I saw the EDC 18650 at intl-outdoor, and being unable to decide between the new XP-G2 and XM-L emitters, I bought both. Then, fasttech added the same lights to their web page. I went a little nuts and bought a Convoy S3 and a Convoy S3 from fasttech, too.
Initial impressions
The three Convoy S3 hosts are identical, as you would expect. The fit and finish is excellent with no significant flaws that I can see. The knurling is on the smooth side, so it certainly won’t wear out your pants. The overall aesthetic is plain, which suits me just fine. The only concessions to ornament are the glow-in-the-dark switch button and lens o-ring, and the stainless bezel ring.
Here is a surprise. Notice in the title picture, the S2 is a bit longer than the S3s? The S2 has a deeper reflector than the S3. It’s hard to judge how much deeper it is, but I’d guess around 8-9mm.
This is the white-wall beamshot setup. The lights are turned on to their highest mode, set 50cm from the wall. From left to right, they are the Intl-outdoor S3 with XP-G2, the Intl-Outdoor S3 with XM-L, the Fasttech S3 with XM-L, and the Fasttech S2 with XM-L. The last light, on the far right, is an Eagletac P20C2. I used it for comparison because it is also an XM-L with a similar sized reflector.
This is the same scene shot in full manual mode, 1/125 at F6.3, ISO 100.
This is 1/80 at F4 ISO 100, intentionally over-exposed a couple of stops to better show the spill beams. I had the white balance set to daylight, thus the orange tint.
You’ll notice that the S3 beams are floody. I don’t think the above pictures do justice to the reality. I would say that the S3 lights are extremely floody, more so than any other XM-L light I own. Even the 2.8A Intl-outdoor version lacks the “wow” factor usually associated with heavily-driven XM-L lights. It constantly makes me want to turn it to a higher mode, even when it is already on high.
The XP-G2 is a little better, but not much. The Fasttech S2, with its deeper reflector, has a beam more like what I was looking for. Unfortunately, it only has a 3*AMC7135 driver, so it isn’t as bright as the more heavily driven lights.
Conclusion
The S3 has the makings of a good light, but it suffers from a fatal flaw. The reflector needs to be optimized for the XM-L emitter, to allow a more balanced beam profile. The S2 seems to have potential, but I’d really need to see one with a driver pushing more current to the LED. An XP-G2 combined with the deeper S2 reflector would have promise.
So, is it time to retire my trusty D25C2? Nope, it remains safe for now. The beam pattern is only half the reason, take a look:
Obviously, an 18650 light is going to be a little bigger than a 2xCR123 light. The Convoy, though crosses an invisible line. The D25C2 clips unobtrusively iinside my front pants pocket. Pocket carry of the S3 is going to generate “are you happy to see me?” comments. Sure, I could carry it in a jacket pocket, but if I’m going to do that, why not carry a P60 class light, or even a C8?
Verdict: 3/5
Objective measurements
Here is the methodology for the following measurements. The tailcap current test was done with a inexpensive Radio Shack DMM in the normal manner. I was using the 20A scale, so the lower readings may have some measurement error. For the temperature test, each light was turned on its highest level, and the temperature was measured with an infrared temp gun once per minute for ten minutes of continuous operation. Finally, a lightmeter was used to measure the brightest part of the beam for each light’s highest mode.
intl-outdoor Convoy S3 XP-G2 R5 2B 3 mode
tailcap current measurement:
L 0.08 A
M 0.43 A
H 1.38 A
temperature measurement:
0:00 25 C
0:01 29 C
0:02 31 C
0:03 34 C
0:04 35 C
0:05 35 C
0:06 36 C
0:07 37 C
0:08 36 C
0:09 40 C
0:10 38 C
lightmeter measurement:
4100 lux @ 1m
intl-outdoor Convoy S3 XM-L U2 1A 3/5 mode
L 0.16 A
M 1.40 A
H 2.81 A
0:00 29 C
0:01 36 C
0:02 41 C
0:03 46 C
0:04 51 C
0:05 55 C
0:06 58 C
0:07 61 C
0:08 63 C
0:09 65 C
0:10 66 C
5300 lux @ 1m
fasttech Convoy S3 XM-L U2 1B 3 mode
L 0.08 A
M 0.44 A
H 1.39 A
0:00 26 C
0:01 31 C
0:02 33 C
0:03 35 C
0:04 36 C
0:05 37 C
0:06 37 C
0:07 38 C
0:08 40 C
0:09 40 C
0:10 41 C
3300 lux @ 1m
fasttech Convoy S2 XM-L U2 1B 3/5 mode
L 0.06 A
M 0.52 A
H 1.05 A
0:00 25 C
0:01 28 C
0:02 30 C
0:03 31 C
0:04 32 C
0:05 31 C
0:06 32 C
0:07 33 C
0:08 35 C
0:09 36 C
0:10 37 C
3000 lux @ 1m
Edited by: sb56637 on 08/26/2014 - 17:19 Reason: sb56637 replaced <!-- break --> with <!--break--> via Scanner Search and Replace module.
rivet62
I have a few pics (including beamshots) to add, as soon as I figure out how to put them in Smile
mfpmax
mfpmax's picture
Last seen: 4 years 11 months ago
Now what’s interesting is most of the “S3s” i’ve seen were Grey color(like the S2), while all of yours are black. I’d like to get another “S3” so I can get a actual black version. Right now I have a Gold one I mistakenly ordered(didn’t check the box for Grey)
Boaz
Boaz's picture
Last seen: 1 hour 22 min ago
The Xml 5C emitter is nice and so is the driver ..  the Convoy s2  has a serious lack of knurling. If you don't mind a smooth almost slippery light than this guy might work for you . I need much more bite on a light so the convoy is asking for at least a big fat rubber band wrapped around it between the body and  the tail like a makeshift cigar grip .Otherwise it's WAY too slick a light for me. With the green gitd tailcap it almost smacks of cheap .
Sorry to hear that the s3 has the same problem ..
 that said the driver choices from fasttech are amazing and again the 5c is a nice neutral without being to warm .its a perfectly smooth beam and all flood ..thats just the way it is .Mine are running at 2.1 amps which seems to be a perfectly fine set up for this light .
rivet62
mfpmax, I know someone that has three black S3s. Smile Shoot me a PM if you’re interested.
mfpmax
mfpmax's picture
Should tape them all 3 together into one light J)
RaceR86
RaceR86's picture
Last seen: 5 years 2 months ago
Thanks for sharing! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
sb56637
sb56637's picture
Last seen: 51 min 1 sec ago
Thanks very much! Frontpage’d and Sticky’d.
bdiddle
Last seen: 2 days 19 hours ago
So what you are saying is that the S2 has a better beam than the S3, and since fasttech sells a 2.8A version, I need to buy it. Right?
Newb
Ouchyfoot
Ouchyfoot's picture
Try using a Sanyo 16650 in your D25C2. A perfect fit.
rivet62
I’d definitely recommend the S2 over the S3 for a general purpose EDC. The 2.8A version gets hot quickly on high, but if that doesn’t bother you, go for it. I’d probably go for the 2.1A driver, myself. Either way, it’s hard to go wrong for less than $20.
rivet62
I never knew such a creature existed, and yet there it is on intl-outdoor’s web site. I think I’ll add one to my next order and see how I like it.
Thanks for the suggestion. :bigsmile:
bdiddle
Yeah I already ordered the 2100mah S3, but I think I will ahve to order the S2 now.
Did you notice if any pocket clips fit them?
Newb
Ubehebe
Last seen: 6 years 6 months ago
Great review. Wish I had read it before I bought.
Just got my 2.8 Convoy U2 from Fasttech today. And like you, every time I thumb through the modes, I keep waiting for there to be one extra mode to push it into real turbo. But I can see why they did what they did, I think. Overdrive it any more and you could boil a can of soup on it.
Having said that, it’s a great little light. Nicely built. Takes unprotected and protected 18650s. Small. About 3/4” shorter than a 501B; 1/2” smaller than the Ultrafire 2100; about the same size as the dismal (horrible beam, low power) SacredFire NF-918. So the size is definitely right.
The flood has its place for walks and around-the-house use where you don’t want to burn out your eyes.
But where is that turbo mode?
Oh and the ability to turn off disco modes is STELLAR!!!! Manufacturers take note: Hide the blinking modes or just kill ‘em altogether. They are annoying beyond words. Tear-out-your-hair annoying.
Thanks for the great review!!!!
rivet62
I tried a Solarforce L2 clip from solarforce-sales.com. It physically fit between the tailcap and body, but the tailcap did not make electrical contact. It might be possible to make it work by shimming the contact ring in the tailcap to compensate, but I haven’t done that yet.
The S2 body is 24mm in diameter, if that helps your search.
rivet62
Thanks, Ubehebe.
It is a decent little light; I’m actually quite impressed with the build quality. And if you need a “room sweeper”, the S3 is your huckleberry.
I’ve played around with the S2 a bit more, comparing it to the Eagletac P20C2 and D25C2. The S2 beam profile is almost identical, and conforms well to my idea of an all-round EDC.
Good point on being able to disable the disco modes. That was the first thing I did to each light, but I failed to mention that.
bdiddle
Have you checked if we can add a few more 7135’s easily? Get that turbo?
Newb
Ubehebe
I should know how to do that, but don’t. Is there a BLF FAQ kicking around about it?
Trevi_lux
Trevi_lux's picture
Last seen: 1 year 11 months ago
Hi
My “S3 convoy” arrives tomorrow, my only 18650 are Nitecore, do you think that will take? I am somewhat concerned, I think they are too large.
Ubehebe
I noticed kind of an odd thing with the S3 — so you may have a battery issue, but maybe not. I can use keepower protected, Fasttech’s Samsung and sanyo protected, teneregy, etc. But here’s the deal. The threads are anodized (or painted), so the only way you can get a contact is to screw the cap on ++ALL++ the way until it contacts the body tube. The tube top has the paint removed, which contacts the switch retainer ring. If the battery is too long, you can just remove a patch of paint on the tube and cap and that will give you a contact with the cap not screwed down all the way for long batteries.
I can see (I think) why they did this. You can leave the light in an “unarmed” state by unscrewing the switch cap by like a 1/2 turn, if you want to leave batteries in it for a long time and are concerened about shorts or whatever, or the battery draining over time. However, the downside is that some longish batteries fit pretty snugly, maybe too snugly. I get a driver whine when I use the fasttech sam/sanyo longish protecteds. Probably nothing to worry about, but maybe it is. Looking down in the barrel, the extra pressure could be causing the spring to bend and touch one of the chips or chip contacts? Or maybe it is just a peculiarity with the fasttech protected circuit.
Another neat feature: The s3 blinks when you get down to about 3 volts left in the battery. I should have let it go and see if it shut off the battery, but I didn’t. :-0
The more I use this light, the more I liike it.
Trevi_lux
Trevi_lux's picture
Thank you very much for your quick response.
Tomorrow I will find out.
garrybunk
garrybunk's picture
Last seen: 2 hours 19 min ago
rivet62 wrote:
I tried a Solarforce L2 clip from solarforce-sales.com. It physically fit between the tailcap and body, but the tailcap did not make electrical contact. It might be possible to make it work by shimming the contact ring in the tailcap to compensate, but I haven't done that yet. The S2 body is 24mm in diameter, if that helps your search.
What about this clip at Wallbuys?  I have no idea what diameter it fits though - any ideas?  Ah, I see it's for a Jetbeam PC20 - EDIT - no, I think PC20 is just the clip's model number, it says "Suitable for:T20,T25,M20".  Gotta look up those diameters.
1
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
garrybunk
garrybunk's picture
Ok that clip seems to be for an Olight T20 which is stated as being 24mm diameter.
-Garry
mfpmax
mfpmax's picture
Fenix clip with an O-ring works as well. Pictures of the Fenix clip in the other EDC 18650 thread.
Vectrex
Vectrex's picture
I wonder if the intl' outdoor clip would fit through the lanyard holes of the S2.
mfpmax
mfpmax's picture
The issue with that is that it would hit the switch boot. I think someone mentioned or did use a clip like that but drilled new holes instead. Which probably would be better as to not intrude onto the switch boot.
Vectrex
Vectrex's picture
Maybe a small countersunk bolt would fix that problem without having to damage the anodizing? The main question is, would the distance between bolts fit? For the rest I would find a way to make it work.
nekdo12
Last seen: 7 years 2 months ago
Now I have S2 with T5 5C and 1,4A driver.
The best EDC light :bigsmile:
rivet62
Congratulations, nekdo12, that sounds like a great combo.
How do you like the 5C tint? I haven’t used a light with that tint yet, but I sure like the 3C in my C8.
nekdo12
3C is better, but 5C is also ok.
I also sended 3 requests at Fasttech for S2 with 3C. After CNY I will send another :bigsmile:
Ouchyfoot
Ouchyfoot's picture
…but 4C is sublime.
