You sir are mistaken. The BTU is a light that throws 700m and puts out 2880otf at 30sec - nothing is wrong with the torch. And beating a TN31 isn’t exactly an easy task for triple led lights. And the BTU does 124K vs the 126K I got tonite with the TN31 - both super close.
I respect anybody’s desire to get the TK75 - it’s a bad arse light. I like the BTU better, but I assume many will prefer the Fenix name and its lighter weight. To each their own you know. But to say there is “something wrong” with the torch is quite simply wrong. That’s a fact.
I actually suspect because I am suspicious guy, that current new TN31 are not using good material compare to old one. Thrunite is definitely doing engineering change if the price reduce from 200 to 139. I grabbed the first batch of discount where they at first plan to have limited 20 units only. Later Thrunite extend the discount until now. So I suspect new batch is not similar to old batch. Heat will affect XML performance by a lot. Both ILF and my TN31 out throw TK70 slightly, so I expect the very hard driven and U2-ed BTU to out throw TN31.
Maybe it is the reflector and AR lens that let TK75 win this time. Every parts play a role.
I was on the shining end meaning I held the lights and got the best view obviously and believe me both lights lit up the whole road and surrounding area for hundreds of yards. I have to say the BTU looked like it threw a little farther and was slightly floodier. I personally do not see anyone being disappointed in either one of these beasts.
I am stating the fact. BTU is heavier so heat sinking should be better, driven harder so output should be higher, but the fact it is not. So something is wrong with it. If Fenix drive harder and put U2 in their TK70, it will beat TK75 easily.
I have to say I wonder what a BTU would be like de-domed,I don't have the nerve to do it but it would be interesting to see what happens to the beam.Sorry if I'm going a bit off topic,I have never seen this done.
The TK75 did not win in throw. Was short by about 30k and almost a 100m. The TK did have a slight lumen edge and did still throw its butt of considering it has a smaller reflector. Again it’s a great light.
And my brothers TN31 is a fairly healthy example with it’s consistent testing in the mid 120’s. And ever test I’ve done on the BTU also puts it solid in the mid 120’s. But I still give the TN a slight edge since most tests done together put it a couple k in the lead. Of course 2k at those distances is equal to perhaps 5m.
If you go with the TK75, you won’t regret it. Again I love my BTU and wouldn’t consider trading my brother lights, but its mostly a personal taste thing. I actually prefer the beefier feel of the BTU. But likely most people would prefer the lighter weight of the TK75. And if you intend to use one of these for long carry at work - the TK75 is the obvious winner there.
The TK75 weighs less than the BTU by a fair bit and is even lighter than my TN31. To me it feels good in your hand. It is a very well thought out design.
That would be an interesting experiment. If it goes along with other XML’s, you might end up with a 2000otf 900m thrower. Would be impressive if it worked that way. But I’m not brave enough to try it and I don’t wont to lose 1/3 of its output, even though it has some to spare.
Fenix continuous Turbo runtime is 75 minutes with their 2600mAH 18650s, that means each battery is drawing 2.08A in Turbo mode. Total is 8.32A with 4 batteries, drive 3-LED, that means each LED is getting 2.77A if no loss. All these show that TK75 is very well designed in efficiency and safety for both batteries and LEDs. I don’t blame BTU can’t meet Fenix efficiency. But lumens wise it should win all the way, now BTU only advantage is throw of 100m more that is not practical at all. And I can tell you my practical gain from SR95S UT compare to TK70 is only the 100m-200m range. Below 100m, SR95S UT is brighter but TK70 flood better. Beyond 200m human can’t see very clear anymore unless it is very big object at distance.
rdrfronty, do you have lux number for 5m or 10m? Would like to see how the lux number compare to 50m lux number.
At 50m, it will be 2500 multiplying lux reading. Your lux reading for BTU will be 124k/2.5k=49.6 lux, and TK75 will be 94k/2.5k=37.6 lux. These readings are close to noise floor if your meter is not good enough.
I totally respect that the BTU throws further and seems brighter, however the seller for me with the TK75 is it runs on turbo much longer, and you can get battery extensions for incredible run time. In a perfect world I’d have both, but if I’m going for a 5 mile walk thru the bush at night I’m taking the Fenix.
I don’t have 5m and 10m reading from last night. But we tested both lights twice at the 50m, both times being with in 1 lux. I will test them again later when we do beam shots in a week or two. I’m just waiting for my TN31mb to arrive first.
But I know those numbers are very close to true considering the fact we actually walked at the true distances last night and measured the true throw for both lights. And that distance was measured using a 100m tape measure. The 124k for the BTU is equal to 704m and we were able to measure in the .2’s in lux at a measured 700m, and then only in the .1’s in lux at 800m. The same worked out for the TK75. It’s 94K calculated out to 613m, and we measured the TK to have in the .2’s at 600m and then only .1’s at 700m. Now my meter, like most only reads in the tenths of a lux, so I can’t narrow the max throw to an exact number, but it’s obvious that the BTU can do right in the 700m range and the 600m range. How easily and how steady the meter holds these numbers helps to tell me if its likely low in that range or higher in that range.
The throw numbers are correct + or - a few lux or percent. We tested them to many times and in two many ways to be off very far.
Makes good sense. If I was going for a long trek, I too would take the TK over the BTU. It does have the longer run time with 4 cells and the lighter weight. Truthfully I would take a smaller light than either of these though if I was going on a longer journey. Now the longer turbo to me is a moot point though when you consider the highs in the equation. The high of 2160otf for the BTU after the turbo kicks off is almost double the TK and higher than 95 percent of the lights on the market can do period.
Well the BTU has three U2 emitters that are driven an estimated 3.8a each per Ric and cnqualitygoods. Now considering the 2880otf I get in total, that equates to 960otf at 30sec per emitter. That is actually pretty spot on for a 3.8a U2 emitter with decent heat sinking. We’ve got U2’s that do worse and some that do better. The U2’s with slighter better output is the TK75 its 975 per led and the best - TN31 with a measured 1120otf at 30sec. Though I’m pretty sure it’s driven we’ll over the 3.8a. So personally I’m totally cool with the 960 per emitter and 2880otf total the BTU gets.
Besides considering the level of these two lights, the measured 45otf difference between the two is equal to about 1.6% difference. That’s closer than most lights of the exact same type would be. And a good chance the next TK and BTU tested might flip flop with victor and winner with bin variances and etc.
