Agreed. The BTU is kinda like a bulldog in my eyes. People either think they are ugly or so ugly they are adorable. The fat, squatty, hefty light appeals to me. Just like the SRK appeals to some and not to others.
Maybe it is your love for BTU have blinded you that you refuse to look at it objectively. I am just stating the fact driven at 3.8A per led, BTU output must not get below TK75. Else most probably it means problems below:
1.Heat sag
2.Battery voltage sag
3.BTU is not really U2, but T6
XML-2 U2
Ok, sure your right
Dale, no one can be 100% sure. Yours can be XML2 T5. They need to be properly measured to confirm.
From U2 to T5, every led can have a saving of 3 dollars. 3 LED will be 9 dollars saving for seller. This is not new scam for XML flashlights.
I had this modded… I know exactly whats in it .
Dale I wish you had a way of checking the output on your XML2 upgrade. Would like to see how much the change really makes. I know yours looks really good. A 10 percent increase would be very nice. Not sure if it would be worth me upgrading from a U2 though. NW T6 to XML2 U2 should be close to 20-25% jump. That’s really cool there.
Does anybody have the actually rated numbers of the U2 vs the xml2? Is it like 5-10-15% increase?
That is cool. Just to highlight potential scam especially flashlights not performing as it should be.
BTU problems :
1.Heat sag >>> IMO BTU transfer heat better than TK75
2.Battery voltage sag >>> Yes, 3.8A to LED while Vbat load about 3.5V- and Vled about 3.4V-
edit : plus Vdrop at Circuit and resistance at tailcap switch, springs (That why I like BTU with 4x18650s)
-IMO solder wires to springs to reduce resistance, I did almost my flashlights
3.IMO BTU is really U2
4.REMEMBER that Reflector(TK75 is better ) and lens(not AR) cut off OTF 5-10%
I know I just last week I got a couple C8’s modded with XML U3’s. 3.8a drivers mounted on brass pills. Tailcap reads about 3.74a range on both lights with the same 3400mah protected Keeppowers. Both lights tested yesterday right at 960otf after 30sec. That is exactly what the BTU does - 960otf per U2 = 2880otf = the exact number we got. So yes I’m confident the light has U2’s and is performing just fine.
Since most owners are convinced heat sag and LED bin are not issues, then it might be 3*18650 and reflector and lens causing lower OTF. These three things are picked up before but claimed to be not an issue. But now it has high potential to cause BTU not performing. If possible, I suggest to do things below before testing to see real performance of BTU:
1.Use 3 good unprotected batteries
2.Solder wires on spring
3.Remove the lens
“BTU not performing” - you do understand the difference between the two lights is less than 1.6 %? That’s like saying a single xpg cr123 light running at 288otf because your friend has one that does 292otf. Seriously, do you think even name brand ANSI lights don’t vary more than that? I KNOW they do. I’ve tested 50+ lights for a total of perhaps 3-400 lumen tests. Any given light will vary more than that from one test to the next.
The BTU is performing properly. The TK75 is performing properly. Both are dead on for what U2’s should be doing at the amperage they are driven at.
Group Hug!!!
I love group hugs! Everybody take a deep breath and just chill.
and don’t forget… with TK75… you can have extra extension tubes ( up to total 9 but fenix recommend only 2 tubes) for longer running time ( come in handy for search and rescue mission)
Sorry guys, I’m trying to not get worked up. I started this thread trying to show what both lights can do, good or bad. I feel both have their pluses and minuses. I think anybody with either one in their hand will be very impressed with their performances. I am obvious a BTU fan, and believe me it hurt to post up that the TK75 had the slight edge in peak output. I was trying to be as unbiased as I could. I knew going into this thread the TK75 might pickup more fans. What I didn’t expect to see is people trashing an great performing light like the BTU. Having favorites and opinions is normal human nature. That’s one thing that make forums interesting. But attacking a light, with incorrect accusations, by someone who doesn’t own and has never even seen the light, is just wrong.
Saying the BTU its too heavy, saying it should have 4 batteries, that it should have AR lens, that it’s ugly, or needs a side clicky - those are all good and proper opinions that others have stated. And thats all fine - those are opinions, popular ones at that. But I can say also say the TK75 feels a little flimsy, doesn’t have deep enough reflectors, should throw further, has too low of a high, has weird two button controls, etc. But those are just my opinions.
However falsely staing that the BTU is under performing - that does ruffle my feathers because I know the statement is not true. Does my brothers TK75 have slightly higher output than my BTU - yes. That’s a fact. It’s also a fact that my BTU performance of 2880otf, obtained with 3ea 960otf , 3.8a driven XML U2’s, are well with in the proper output for a normal, decently heatsinked light.
Ok little rant over. Now I’ll group hug (can I step on Dengoh’s toes while doing it though? ). It would make me happier
Yes that would make for impressive run times to say the least. Only negative there is it would make it pretty big, about like the TK70 or bigger. I would think just taking the TK75 as is, along with spare batteries would be more practical for long journeys with it. You would still get the long base run time with the 4 starting batteries, could swap out fresh runs if the time required it, but it would allow you to keep the light weight and compact size that is one of the TK’s best features. I would hate to carry around a TK70 sized light for hours on end. I say that knowing my similar sized SR90 would get pretty cumbersome too after a bit of time lugging it around.
But irregardless, it’s nice of Fenix to give you that option of battery extensions if so desired.
My brother and I both have slightly different takes and views on these lights like everyone else does but we just agree to disagree. I personally find the ergonomics and looks of the TK75 to be more to my tastes while he prefers those of the BTU. I would not trade my TK75 for his BTU or most any other power light out there. I have been watching the thread on the RC40 with a little interest but personally think that even though it should be a beast it also looks like a beast (kind of homely). I don’t think the BTU is ugly by any means. It is a little big for my personal tastes but I am glad my brother has one so that I can play with it too. Even thought I like my Tk75 better I challenge anyone to pick up a BTU in CW and shine it around a while without getting a big smile on your face. Betcha can’t do it. Lol.
The RC40 is going to be a heavy flashlight to carry at 3lbs 4oz. That’s even heavier than the TK70. And the price has yet to be seen.
I don’t have a BTU Shocker, nor can I say I really want one. The TK75 does more than I need and it’s a lot smaller and lighter to pack. I also would bet money that the quality edge would go to the TK75 no doubt. The TK75 is just a more practical light.
Great review. I’ve just bought a tk75 and it was a hard choice. I almost bought both as I like them both so much. The tk75 was cheaper and I like the size of the tk75 more than the btu.
They both get great reviews and I’ve decided that if I was to go for something as big and bulky as the btu I’d probably grab a big headed hid. I’ve got a tn31n for throw so at the moment I have no real need for much else.
