Nitecore EX10 lens removal
4 posts / 0 new
jamesearljonesi...
jamesearljonesisascab's picture
Last seen: 6 hours 44 min ago
I wanted to clean the lens of my Nitecore EX10. after doing some extensive research online, someone suggested a rubber pad like those for opening bottles. Put rubber pad on weak hand. place EX10 bezel first against pad and turn counterclockwise. will need a lot of force to turn. after removing the bezel the lens oring and reflector can be taken out. be careful to remember how glass is placed as it has two different coatings on each side.
i wonder or does anyone know if they make smo reflector.
03/04/16
8 lives left
Boaz
Boaz's picture
Last seen: 7 hours 12 min ago
Can you measure the glass for me ?   in mm.
I have 2 with broken glass .:(   I'll change the emitter while I'm in there though .. so
jamesearljonesi...
19mm hmm gitd orings
03/04/16
8 lives left
jamesearljonesi...
http://budgetlightforum.cz.cc/node/1585#new
guess i shouldve looked earlier. match already had it apart.
03/04/16
8 lives left
