nice… you’re giving me idea about strapping 4 skyray king together
Rich,
Kudos to your creativity and pursuit of the most light from a hand torch! Not the most polished mod, but pretty friggin' cool if you ask me. Seriously though, I think we need some beam shot comparisons.
It reminds me of a build using 4 x 3-up XPGs in a mag host with a massive copper heatsink and the same optics. I saw it on CPF once but can't remember whose work it was.
If only you used a larger host like C8’s; Imagine a tri or quad C8 setup like that with XML’s all driven at 2800ma+ >) .
I’ve been thinking about tri C8 setup for a while like this but planting them in a PVC pipe and making some kind of holders; If I add some interrupters and keep the modes while driving them off of a large lipo in the back I could have different lights at different outputs/modes while avoiding battery fuss.
Now I just need some cheap c8’s ;). A fan could be driven off of the lipo if it needed active cooling (Stationary flood, when used w/diffuser, etc) but I’d intend on using this as a mobile ‘flood light’ with a better run-time than bigger spot lights.
I just need to see how lights handle the lipos (I’ve got a cheap headlight I plan on hacking up this week and while it is higher voltages that can always be stepped down or I can just wire larger individual cells in parallel w/some fuses to prevent any dangerous overheating. If the current is too much it would have to be stepped down/limited/restricted.
If I can I’d like to avoid lions and just add a monitor for the lipo cells; If I’m going to be running 4000mah+ packs it would be nice to charge them at 2+ Amps :bigsmile:.
How did I miss this thread? I swear I miss way too much around here.
Rich, good to see you are still modding. That is somewhere between James Bond and Rube Goldberg, but it's cool looking and I bet, it's bright as hell!
Way to go Rich!
Born of necessity as night vision is worse. Don’t get old! I’d like to redo the handle. Looks worse in the pic than in person though.
Rich
wheres the beam shot at the football field
In my mind… I’m lazy, not equipped for beamshots, and it’s too damn cold!
Bump, new pics and comments.
No one with comments about the updates?
Thats our subtle way of telling you that we are still waiting for beamshots. :P
Just wondering… When do you start full-scale production? :bigsmile:
Wowzer! I like all those triples. On coming people must hate to see that localized sun approaching.
Rich,
I’m speechless That’s one heck of a customizing job you’ve done. Congrats!
As for Longbow I completely agree. They were so well done that their waterproofing allowed models to be used by divers. They were around, out of Singapore, from 2004 to 2007 give or take. They also make, as you’ve demonstrated, excellent customizing platforms. I own a Micra, Mini, and have an Eco tube.
My Micra’s regulated 1watt Lux Star is run using the Eco tube and 2xAA NiMh. And my Mini sports a factory crenelated head and clicky tail along with a Don McLeish McLux TX0J/DB700 pill driven by 2xCR123A. Both have UCL lenses and IMS S017XA reflectors installed. Both still see regular use Shown here just off center right:
Here’s another group shot (sorry… they’re all I have available to post) but with the Longbow Micra (far right) in stock form (1xCR123A) with an aftermarket pocket clip.
Reminds me of a “Christmas tree” at the drag strip… Ready, set, WOW!
Good Lord, that's awesome! How the heck did I not see this until now? :beer:
thats pretty tight man. how bright is this thing?
This really has to be done yourself then… nobody know of a manufactured multiple flashlight holder?
The closest I can think of is an airsoft-style multi-rail adapter with ring mounts
I don’t think you’ll be having any problems with night vision at all when you fire up that monster.
I can’t find the thread (I have searched using every keyword I could think of), but yes, someone here made a similar, simpler four flashlight set-up using just rail mounts (in a T formation). Each flashlight has to be turned on individually, but it is a wonderfully elegant solution for those of us without much technical skill. I think the parts are about $6-7 from DX.com. If anyone finds the thread, and can link it, that would be great.
Hi!
My personal “gadget” is a work in progress, but I was inspired by this thread to show it off prematurely. I am using picatinny rails for connecting the lights together, and the Nitecore P25 acts as the handle. It will also form the center of my final setup, mostly because of the dual picatinny rails. I mean they are there, so I have to use them, right?
Here’s how it looked initially:
I tested this setup with the Led Lenser X21R. Initially the X21R had the longest throw. After 10 minutes the situation was reversed, and my setup threw the farthest, with a lot of spill that the X21R has zero of.
Then I suddenly got a Convoy M2 from Fasttech that fit nicely into the wanting center hole:
The lights used are:
- Nitecore P25
- Fandyfire STL-V6
- Jetbeam BC40W
- Convoy M2 (Neutral white, 2,1A drivers)
The numbers add up to something like this:
100 000 candela
3 400 lumens
with a mix of cool and neutral white tints.
The P25 is possible to quick disconnect. I’m planning to be able to do this with the other lights also. Now I need my allen and torx wrench to get them off.
An advantage with using picatinny rails is that the lights are perfectly centered as soon as I install them. The disadvantage with this setup is that I need to press every lights rear button to power them up.
Beamshots will arrive when I got my setup finished; I have a little triple eyed monster I need to attach before I’m done
