DQG 18650 EDC--World's Smallest 18650 Flashlight
698 posts / 0 new
neverfeltbetter
djozz wrote:
You encouraged me to try it, but at this moment I can't get the board out of the head anymore Frown. anyway, here's how the disaster looks:
On the left side of the board is where the part is ripped off, the part still sticking to the foam is seen bottom right next to the flashlight head. Now that I see the picture, it appears like the complete solder pads were ripped off with the part. It's beyond repair after all Frown
Getting a bit off topic now, let's talk about happy stuff again, the 18500 DQG.... Smile
she is not dead yet.
thanks for the picture. there's a good chance you can repair this one. it does take some skill and good eyesight Smile
the 18650 dqg looks like such a nice light, the chinese have done it again.
the 100ma low mode is too much for me but that won't stop me from buying two.
Firelight2
Firelight2's picture
Last seen: 1 hour 51 min ago
I wonder if I could mod an 18650 DQG.
I’m thinking something along these lines:
1. Replace star with 20mm triple XP-G2 R5 neutral 5000k and put appropiate optic on top.
2. Remove driver and replace with contact plates for direct drive.
3. Add QTC at head for brightness control.
4. Run on IMR 18650.
EDIT: hm. maybe this idea won’t work with this light. With the LEDs mounted on the driver board there wouldn’t be enough separation from the top of the batteries.
FX-32
FX-32's picture
Last seen: 4 years 11 months ago
Nice, it's really short.
Now it would be awesome to have a ~5cm long 16340 with XM-L2, That would be a really small powerful EDC.
Werner
Werner's picture
FX-32 wrote:
Nice, it’s really short.
The mini 01 is about 6 cm long so there we have a nice pocket rocket.
But the great on this is the capacity of a 18650 which is about five times a 16340 or 14500
FX-32
FX-32's picture
The mini 01 is about 6 cm long so there we have a nice pocket rocket. But the great on this is the capacity of a 18650 which is about five times a 16340 or 14500
That's true, But I was thinking in something shorter can be made using integrated driver in LED's board and TIR optics. Obviously you will get less runtime, but it's nice to have a really small option. Personally, I don't use my EDC for too much time to have a 18650's capacity, for that reason a 16340 is enough for me. It can be shorter and brighter than an AA or AAA EDC.
CheapThrills
CheapThrills's picture
Last seen: 1 month 1 day ago
Actually, I like BLF Mini more than for example iTP A1 because it is a tad longer – easier to operate.
djozz
djozz's picture
Last seen: 1 hour 44 min ago
got the board out, succesfully resoldered regulator, both modes worked again, assembled the light, TIR pressed board out of pill, took it apart again, tried to solder board to pill, something got too hot/got messed up (no idea), light is back to only low mode.
Now she really and utterly is dead. I did learn how to solder tiny bits though Smile :
neverfeltbetter
looks like you had a lot of fun tonight. are you ordering a new driver now ?
Ric-CN
Ric-CN's picture
Last seen: 4 years 2 months ago
djozz wrote:
d*mn, just tried to remove the led/driver board of my DQGIIIAAA to make a picture of the led sitting on the driver board (I removed it before, so no calamities expected) and while removing the foam insert a current regulator was ripped off the board with it (##@!!!). Stopped there but now it won’t switch to high anymore. Too tiny to solder back I’m afraid….
Result: no nice picture to show you, and no working flashlight *sigh.
This is an expensive hobby in the end…
show us a picture :~ I just took a look a mine and with a very fine tip you should be able to solder the missing stuff back to the board.
You encouraged me to try it, but at this moment I can’t get the board out of the head anymore Frown. anyway, here’s how the disaster looks:
On the left side of the board is where the part is ripped off, the part still sticking to the foam is seen bottom right next to the flashlight head. Now that I see the picture, it appears like the complete solder pads were ripped off with the part. It’s beyond repair after all Frown
Getting a bit off topic now, let’s talk about happy stuff again, the 18500 DQG…. Smile
Looks like DQG AAA, Need a new driver for DQG AAA to fix it?
i can send one to you for free. I have 3 pieces DQG AAA driver left.Please PM me or send an email to sales@cnqualitygoods.com
BTW, DQG IV AAA SS version will come out next month, the UI will be Screw-off and loose-on. Maybe i should post this on DQG AAA thread. Smile
Ric
BTU flashlight; DQG Series Flashlight ; Torch Component
Pulsar
Pulsar's picture
Last seen: 1 week 4 days ago
Any idea when it will be available and how much it will be?
Philipp
Philipp's picture
Last seen: 7 years 7 months ago
Wow! That’s is what I call awesome customer service! Kudos to you, Ric-CN!
Very nice! 8)
I always thought that this would be a better and more practical UI for Twisties and I wish more lights would come this way, but I guess that’s more complicated to implement.
…BUT: Does the light now have parasitic drain with this UI? or is it still a mechanically disconnected circuit when in off position? (was this understandable? :8) )
Trevi_lux
Trevi_lux's picture
I love all DQG aaa, Love
djozz
djozz's picture
Ric-CN wrote:
djozz wrote:
d*mn, just tried to remove the led/driver board of my DQGIIIAAA to make a picture of the led sitting on the driver board (I removed it before, so no calamities expected) and while removing the foam insert a current regulator was ripped off the board with it (*##@!!!). Stopped there but now it won't switch to high anymore. Too tiny to solder back I'm afraid....
Result: no nice picture to show you, and no working flashlight *sigh*.
This is an expensive hobby in the end...
Looks like DQG AAA, Need a new driver for DQG AAA to fix it? i can send one to you for free. I have 3 pieces DQG AAA driver left.Please PM me or send an email to sales@cnqualitygoods.com BTW, DQG IV AAA SS version will come out next month, the UI will be Screw-off and loose-on. Maybe i should post this on DQG AAA thread. Smile Ric
Wow, that'd be great, good service, thanks, I will send you a PM right away, I am a bit clumsy sometimes but the light is dear to me.
The new version IV is a real improvement by the way, the threading is so smooth that at the moment I do not dare to put it on my keychain in fear of loosing the head, great that the switching is now the other way around!
SashiX
SashiX's picture
Last seen: 7 years 3 weeks ago
Wow, nice light Big Smile Hardly dunno it will work with protected cells Flat Stare
On the other hand, what part should be twisted? That SS part? Just saying, because that part should have some knurling for easier operation. I see small knurling part on the head, if that is the part you need to twist – awesome.
Ric-CN
Ric-CN's picture
SashiX wrote:
Wow, nice light Big Smile Hardly dunno it will work with protected cells Flat Stare On the other hand, what part should be twisted? That SS part? Just saying, because that part should have some knurling for easier operation. I see small knurling part on the head, if that is the part you need to twist – awesome.
It works with most protection 18650s, Like AW , Keeppower , Sanyo , Panasonic.
Yes, by twisting the knurling part on the head, you can turn it on/off and change modes.
Ric
NightCrawl
Last seen: 5 years 1 month ago
sixfink
Last seen: 2 years 2 weeks ago
Wow, what a fabulous-looking torch. I want one!
gords1001 wrote:
http://www.cnqualitygoods.com/goods.php?id=1846 Pound for pound, this is one of the best 18650 edc sized lights available, I’ve been loving mine since I got it.
no clip, but now that I have seen your link, I still want one of those, as well! Dual O-rings on each end, even. And, at that price, I think this will also make a terrific birthday gift for my best friend. Thanks!
NightCrawl
Does this flashlight have a low-voltage stepdown or sth like that so we can use unprotected cells, too?
GottaZoom
GottaZoom's picture
Last seen: 2 years 8 months ago
GottaZoom wrote:
Ric, given the TIR and same driver, how would the throw and beam compare between the U3 and a XPG2?
bump
totilde
totilde's picture
Last seen: 2 weeks 4 hours ago
Ric, do you have a release date and estimated price? i was waiting to get one of these, but the wait is getting too long, and i need an edc
Mooooooo
NightCrawl
It will be released by the end of the month. Price tag.. he said it will be worth the quality, considering the DQG AA is 31$ in NW, I guess this one will be around 50$.
FlashPilot
FlashPilot's picture
Last seen: 1 hour 21 min ago
The price might be acceptable to some, but thats at least twice what Id be willing to spend for a light like this. Im sure there are many others that would agree…
totilde
totilde's picture
I am the first who agrees… If that’s the cost i need to go for other deal. Too expensive for my customs policies.
Mooooooo
jmpaul320
jmpaul320's picture
Last seen: 1 month 1 week ago
i agree – $30 is my max for edc lights…if a light is lost or dropped $30 isnt too bad to replace
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Firelight2
I’d pay $31 for this.
I wish there was an option of having a higher current driver though. If I only want 500 lumens I might as well stick with a AA light which will weigh less and take up less space in the pocket.
If I’m going to go to the trouble to carry around an 18650 light I want it to be able to output high lumens, even if only for a few minutes at a time due to overheating. I’d prefer the option for a 2.5 or 2.8 amp driver.
relic38
relic38's picture
Last seen: 3 years 4 months ago
I hope it’s under $30. If so, I’ll order one.
Even if it is great quality, for me the function of this sort of light doesn’t warrant that price tag. On top of that, it has relatively simple optics which should lower costs a little. Not having glass up front means eventually having to change the TIR or live with a ‘fuzzy’ light.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
janko.hrasko
janko.hrasko's picture
2A is enough for this kind of small light!
I know my h600w heats quickly on turbo (645 lumens, probably 2A too) and it is similar in size but have cooling fins
But please make this affordable, I’m still a student and have income of ~60 euros a month only Sad
Optional xml2 t6 3c would be the best imho
FlashPilot
And now, a friendly announcement: (ie: cynical sense of humor): Perhaps the few that were so eager to spend the big bucks (before the price is even announced) can help offset what the light might be worth to the vast majority. Ric, please go ahead and collect from the $50 crowd first, as they are most willing to pay right away. Some might even buy the shoes off your feet (sight unseen) if you post your shoe size.
That, or please feel free to donate all that money burning holes in your pockets to the FP Avgas happiness fund. I will guarantee that your contributions will be well spent providing utter bliss to myself and many other air junkies. :bigsmile:
All in good fun… Wink
lionheart_2281
lionheart_2281's picture
Last seen: 17 hours 23 min ago
Don’t bother posting shoe size, I’ll buy em sight unseen Wink
phantom23
phantom23's picture
I’d like to see it with XP-G2 for better throw and three modes 0,05A-0,35A-1,5A in that order. With or without memory. That would be perfect EDC light.
