PALight/safe-light
have a find in the dark glow mode which is always on
it i enough to navigate to the toilet in the dark
PALight/safe-light
Okwchin curious about your v10 vs a d-10 or ex10 ramping ..
D-10 sp is 2,5
ex10 sp is 3
ramping ex 10 is 1.5
q5 eos a3 itp is about 3 lumens(With terrible PWM).
the zebra h31 is .5 or 1/2 a lumen and 5 L on the second low
Zebralight H501 flood is the lowest thing on the planet on low low it's like 1/4 lumen and on the upper low 2 lumen all flood so it just seems lower than that
the N-light b3 AAA 2 mode low is 5. all flood so it sems low too
Eastward low about 8
coast mini tac 10lumens
nitecore ezAA 10 lumens on low
The flood makes a huge visual difference .. looks much brighter than it really is .If you ceiling bounce or flood a small room you can tell numbers are the same
Ill try to get a pic of Lows
With my phone camera...!!! FAIL
Picture taken under a table with a big torch providing Under table top bounce.. (edit, the bottom of the table is a brown surface, coupled with the pink/brown tint of the SST-50 neutral, the camera has adjusted its white balance, so the tints are more blue than they really are.
BTW, the Tritium is reflecting light, its not really glowing that bright.
5 torches. --- Maratac AA SS, LF5XT, D10 with Q4 5A tint, D10 with R4 4B tint, V10R with R4 4B tint, yellow 1.55x5mm trit. ---
Brighter exposure with reduced ambient light to show that the V10R is actually on, and how it compares to tritium. Tints are Less blue here. Compared to daylight, the XP-G R4 4C tint is close to daylight. These tints appear closest to what they really are like in-terms of hue. But not in saturation.
Here the light from the tritium is primarily from its own glow
EDIT. I think we need another picture of the V10R... You can only see if your brightness on the screen is set really high, or if you own a TN LCD panel (95% of lcd panels) try standing up higher than your screen to see the V10R beamshot
Just i very interesting this product and want to search about the product's document
Yah, lack of control in phone cameras is great for General users, but not good for reference shots especially in difficult environments (under table bounce of light off a dark brown surface ;)
Lights - Maratac AA SS XR-E Q5 Cool, LF5XT (some neutral XR-E 5A tint or something), D10 (XR-E Q4 5A tint), D10 (XP-G 4B tint), V10R (XP-G 4B tint), EX10 GDP cool
Love how you can see the PWM on the maratac. The vertical scan of the camera when its taking the picture vs the frequency of the PWM
Officially the Maratac is the brightest of the lows I have, followed by the LF5XT. The narrow spill and wide SMOOTH hotspot of the LF5XT makes it appear brighter in this picture than the maratac, but is actually slightly dimmer for total output. The Nitecore D10s come next, followed by the EX10 GDP, and then far below that for brightness is the V10R.
I dont have a SP nitecore, but that usually is about double the low of the nitecore ramping that I have, more like the maratac level.
okwchin, is that a V10R or V10A? I didn't think the the V10R with the set points went that low (other than the titanium vs that seems more like the V10A). I may be completely nuts, really craving one of these magnetic continous rings.
V10R. . .The V10A is the same torch.
Maybe your thinking of the M series - the M10R and M10A. which as the same low as the nitecores.
Same head, just that early V10R's aluminum's had misaligned magnets that limited the low to one lumen. Too low for me is off. I have an infinite runtime maglite that currently puts out .2 lumens or so, I'd say. It draws .2 ma right now.....
Mines an early V10R - it has a lower low than current models. The difference is not magnet alignment, the mechanical alignment is handled by the same aluminium part in both torches. The problem is fundamentally based on the circuit, primarily a software issue with the ramping behaviour (rate was too fast/range not big enough).
Just compared the V10R against the lowest mode on a Novatac 120P. The 120P is meant to have a low of 0.08 lumens!!
Interms of Usability, LOW lows are useful if the UI can back it up IMO.
The novatac low is a very usable low, I can find my way around the house very well, and not lose my night adapted vision, and I dont feel that I need to cover the head of the torch. To me it's about right for a UI with 4 modes.
The V10R has an AWESOME low, but what matters is the variable ring makes it SUPER easy to control the brightness, so its really easy to just tweak it up or down fractions of a lumen to suit the situation (such as looking very close, to the wall at the end of the room). For this reason, it feels very functional, and is Never a hinderance, theres never the feeling that its too low because its easy to adjust.
The D10 doesnt have as low a low. A little too bright for night adapted close reading, but otherwise a very nice general purpose low. The key here is that the ramping interface is too fast (not very controllable) so its not possible to adjust to a slightly higher level, you end up jumping to a 10 lumen level all the time, so the minimum level of about 0.7 lumens (referenced to 120P) is a very practical low. Any lower would be nice, but would start to borderline annoying.
The Maratac has the highest low level of all the torches in my pics, I do feel it could be lower, but its not something thats really annoying, its still a functional low level. As a Twisty with only 3 modes, Its a brightness level that is understandable and acceptable. Referenced to the 120P, its about 10+ lumens.
So I guess it all comes down to the UI. Low Low Lows are really nice like in the V10R, but in a torch with just 3 modes, its not practical to always have that low a low. From my experiences, I would call an ideal low for most torches to be in the 0.3-1.0 lumen range to suit my needs. If the UI supports it, I would happily accept a lower low.
That's exactly why I want a V10A or V20A, for more precise adjustment in the low range with a rediculous low low. That and being able to set it to low before turning it on, really trips my trigger. The cost and tint are my only hold backs.
Ok well this is all nice talking 100 lights let get to budget lights .. what lights have a real usable low without PWM and are under 25 $ How about that for making life tough ?? birthday candle aside ..wooden match notwithstanding .
What about the Akoray programable What are the odds of anything not having horrible pwm which bothers me to no end ..making my baby ITP virtually unusable or the edit 16340 baby zoom ..same thing pwm pwm pwm .
what cheap lights are there with low lows ??(and no nasty pwm).???
Solitaire?
That is a good question, and certainly more affordable.
Like I said, the infinity mag. Two alkies, with a strip of tape connecting them (for protection against leaks), a mini-mag, and a 5mm LED. Bore out the reflector, and use that, or do what I did, use a Minimag Rebel head, and some scotch tape to fix up the threads (the Rebel head has a larger internal width), and sand the entire dome off the LED. That way, the reflector focuses the LED well, into a traditional flashlight beam. I'm probably gonna switch to the normal head once I get my hands on some Nichia GS, for some halfway decent CRI. Infinite runtime FTW! Well, maybe a year or so straight... if they don't leak first.
I must confess - for a while I obsessed with a low low flashlight. Ultrafire's UF-H2b was too high for me. Then I found the perfect flashlight - my cell. But even the cell was too bright.
So, if someone want a really low Android flashlight, there is an app called Screen Filter that will dim your screen to nothing (literally, so beware). It is a bit more expensive, but I already needed a smartphone (and I believe several of you have a similar phone) for daytime stuff.
So my flashlight line up is:
Phone - Fauxton - UF-H2b - Skyray S-R5
This solves every need I have... But after seeing this post I want a V10A....
Well i need to ammend that thought and say budget and really good low low with no pwm and a decent high as well .. we can sit around and talk about very expensive lights that do it and cheap garbage that does a low low low but it has to be a flashlight too not a joule thief .. it needs to turn around and do at least 100 lumens too .
I'm with you Boaz, hope our prayers are answered soon. I am surprised there aren't more options based on a potentiometer(sp). I know these are fairly cheap, they must be hard to implement.
Its impossible to use a pot. in a light-they only take a very small amount of power. All the "infinite" output lights use 8 byte microprocessor controllers, so 256 modes, or something less.
Your probably right, I thought I had heard a T1A used that approach, and knowing the part in general is fairly cheap...
The T1A puts out like 70 measly lumens of blue-green, donut holed light....
