Awesome. Thank you for the suggestion. I’m going to order both of those. And I’m glad they’re both fasttech links :). I’m currently waiting on some batteries from them and some random odds and ends. They shipped out fast too, no pun intended. I don’t really foresee myself getting heavy into modding, but I might do a little here and there. I also just recently purchased a ton of random stuff from other sites too so I’m sure I can find a use for those items.
I have read “Fujik” quite a few times on light forums.
Why do people prefer it?
Does it have better heat transfer than other options out there?
What would be the difference between Fujik and something like Arctic Silver?
Is it because of a lack of electrical conductivity from silicone based thermal pastes? But in that case, there might be a ton of other options right?
And thermal GLUE which is what i linked to you before.
The glue type products will adhere the LED stars where the grease will not.
Arctic Alumina is the comparable one to the Fujik that i posted before.
Its just a different brand. If you want to use the same stuff that’s on the flashlight now your looking for the fujik glue. Its way easier to work with.
Both of those black wires are soldered onto that LED as indicated by the picture below. The orange dot represents where they are soldered together onto the LED.
It might still be a little difficult to see how they are soldered together there… but there appears to be good contact. Also, since the central 3 LEDs are still functional, there should be good contact there. The negative wire comes off the driver and is soldered onto LED “1”. Another black wire then connects “1” and LED “2”. This happens at the orange dot. Next is 3, then 4, etc.
Looking at that wiring, I'm going to say it is the problem. The wires are supposed to wire them in series, and I don't think that is what you did. (May be wrong)
I modified the picture. It may need to be refreshed if it doesn’t show the alterations.
The wires marked by the blue arrows were the ones that were clipped and that I initially replaced. It was pretty obvious where they were connected, so I just replaced them accordingly. The white arrow marks the re-soldered black wire that firelight2 suggested. I don’t think I wired it incorrectly, but it’s been a while since I’ve taken electricity and magnetism in Physics so it all seems pretty foreign now.
There should be no branches (two wires connected to the same side of an LED). You have at least one branch in the red wires. You need to wire them like Scaru has drawn. There should be one wire going from the + of one LED to the - of the next LED.
Edit: Make sure the red wire coming from the driver goes to the first LED + and the black driver wire goes to the last LED -.
No his wiring is right, if I remember correctly there are 3groups of 3 parallel.
And this is what I can see.
This would also make clear why just the 3 in the middle worked.
Yeah, the wiring is screwed up. Truthfully I am having a hard time figuring out what you did but it isn't right. :P I'm gonna try drawing up how it should be wired on one of your pictures for ya.
