Review: Digital Projector LED Spotlight Cree T6
79 posts / 0 new
Richie086
Richie086's picture
Last seen: 10 hours 42 min ago
bibihang wrote:
Hi Richie!
Yeah actually I did see your mod already, but I don’t know how did you charge your cells without taking the cells out everytime when you want to recharge it? Do you fix a charging board inside?
Hi Bibihang, at this point I have the light dismantled in order to try upgrading it with a more powerful driver which will also require additional cooling. So I haven’t had a chance to figure out a better way to recharge the 18650 cells while still in the light. As soon as I make some headway, I’ll be sure to post about it. Wink
Richie
2100
Last seen: 2 years 3 months ago
Richie086 wrote:
Yes, using my LX1010B Luxmeter, at 10 meters or 32.8 feet, I get a rock solid 1,100 lux on High mode. Meter setting was on 2000 also.
I don’t think this is particularly great, but the beam is very tight and consentrated on this light. It should also be noted this measurement was from my gold version as the red one is disassembled for modding. But the internal lead acid battery on it was fully charged. Let me know what you think. Thanks.
110k cd is quite nice for 50 bucks! I believe the LX1010B reads a wee bit more optimistic, we can safely put it as 100k cd. Smile It could have been driven better as you can see from both the pure spill + ceiling bounce with the light meter, the difference is unmistakable (though you said you measured 3A + at the LED, not sure what happened there). If you do mod it, i think 150k cd is doable.
I think i’ll pull the trigger and get that 19.5cm diameter light, and see what happens. 71 bucks shipped to here in SG.
Andi
Andi's picture
Last seen: 2 years 2 months ago
I think, i will “open” the reflector and as heatsink i will use THIS
J)
Richie086
Richie086's picture
Andi wrote:
I think, i will “open” the reflector and as heatsink i will use THIS J)
Andi, whatever you end up trying, please take a few interior shots so we can see the install. I’m really into giving my mtg2 LED a try in this reflector to see how the beam is. I’m still working on a few ideas to deal with the extra heat involved using a 3.5a driver and the mtg2. I’ll keep you all posted as I progress with it.
Richie
radiancez567
Last seen: 2 years 7 months ago
WOW nice tight beam! Is this like a best budget thrower but a really huge one?
Richie086
Richie086's picture
Well, it’s a well made light and throws well, but moderately driven. So heat it’s a problem and the lead acid 4v battery is 7500mAh, so you get very long run times. One of mine I’m in the process of upgrading the XML to an MT-G2, and a more powerful driver. It’s going to take a while to get all the parts. But when complete, I’ll post about it.
Richie
Richie086
Richie086's picture
I noticed they’ve sold 9 of these lights since I’ve posted about it. Has anyone from this forum purchased one and received it?
Richie
Andi
Andi's picture
Mine don´t pass the customs. :_(
Richie086
Richie086's picture
Sorry to hear that. I’d like to know why they refused it. Maybe they thought it had Li-ion cells in it or that an X-ray showed it had the battery installed.
Richie
FlashPilot
FlashPilot's picture
Last seen: 13 hours 50 min ago
Man, I hate hearing about stories like that! |( … and it isnt my package. I hope this works out for you Andi.
Andi
Andi's picture
Problem was the implemented battery…no Manual/Type of battery, Signs, and so on.
Thx for your condolence.
ImA4Wheelr
Last seen: 7 months 2 weeks ago
I just noticed this light last night and instantly thought MG-T2. How is your MG-T2 mod going?
I ordered one from this vendor. $30 and maybe includes another flashlight with it. Don’t know the vendor, but decided to risk it.
http://www.aliexpress.com/item/Wideshine-the-glare-searchlight-outdoor-f...
EDIT: Looking at the 8the picture in the bottom section, it appears that the pill/reflector design may have changed.
ImA4Wheelr
Well, the vendor refused to ship me the light in the above link because the light is so heavy. So I ordered one for $44. Hopefully, this vendor will ship it. I really want to MG-T2 one of these.
pdh
Last seen: 3 years 1 month ago
I’ve ordered one of these – to be delivered to UK. So far I’m still waiting.
P.
ImA4Wheelr
Hi pdh and welcome to the forum.
The light has some potential, but I wouldn't have purchased mine if I could turn back the clock.  I started a thread here.  I still do intend to finish mine and am hoping for a surprise.
If the vendor has not shipped yet, you can probably still cancel the order.  I have before with Ali with good success.  I just select "accidentally purchased the wrong item" or something to that effect.  If you do purchase the light, I look forward to hearing how it goes for you.  I still have high hopes for mine.  I just wish it had a more sturdy and shinier reflector.
Richie086
Richie086's picture
pdh wrote:
I’ve ordered one of these – to be delivered to UK. So far I’m still waiting. P.
It’s a nice looking light, but it isn’t a mod friendly light. I think mine needs a battery replacement already too.
Richie
pdh
Hi, I liked the original images of the spot beam you posted. I’m not that interested in modifying it at present, just having the tight beam will probably do what I need. However it may end up being powered from the 12v supply in my 4×4, with suitable voltage regulator.
Paul.
RPsen
Thanks, I liked the design a lot. It looks special projector to me.
