If the push pins keep moving and/or "funny" text appear (more than earlier today), I'll remove the edit rights from all users. After that you need to PM me to get your push pin added to the map..
But let's still try with the collaborative edit mode. Please be careful and don't mess up the map.
If you type in a given address where you want your icon to appear, there’s no need to edit the map. So use the street corner, 5th and Main, and the icon will appear right there. Done. No need to go into edit mode. If you don’t mind using your actual address, just put in the search bar and there ya go.
I think the OP was actually thinking of an automated system that would put a blip on the map in accordance to where you say you are in your profile. As Gords said, sb would be in the dark, somewhere….
set the first fire in Maine. put my actual town, just not the actual address. its a small town so if some stalker wants to find me, wont be too hard though
edit: looks like north east USA and surrounding area is dominating in density (i say surrounding area because canada)
