Can't recall exactly, but didn't have to do anything nasty to get it out or get it back in. Think I describe later in that thread how to remove it.
To install the new driver, you will need to de-solder the + and - LED wires, then solder them to the new driver at the places indicated for the + and -.
I ordered the I-O driver, looks the same, specs are the same, little cheaper, great support from Hank at I-O, rated for 3 batts, includes thermal pad.
Yes I can get to the driver the same as in your pic, unscrew the battery tube, take out the retaining plate and the driver just “falls” out… I guess there is no need to solder in the new driver (onto the head) as shown in the thread where they modified the J12’s… yay
Now, my next noob question. What is the thermal pad for? From what I see the driver just “sits” in the flashlight. There is not any “flat surfaces” for you to “glue down” the driver.
Actually I emailed Hank about the thermal pad - it goes in between the 2 boards. Haven't gotten the driver yet and haven't worked with a double board driver before, so not sure exactly how to fit it until I get it and see. I know the 2nd board just dangling by itself hanging by wires is probably not good - you want a path for the heat to go along, escape to. I think guys have been potting the driver in these cases, not sure (potting is taking thermal grease or epoxy and smothering the driver, and maybe filling the inside of the pill).
Got the I-O driver, installed it, wow! just wow! 3 simple modes, easy to install, fits perfect, sandwhiched in the thermal pads it came with between the 2 boards, cutting into pieces to fit. Measurements of the J18:
Before with 3 TF 26650 5000 batteries, as is, not fully charged but in the 4.05v range:
tailcap reading: 3.8A down to 3.1A, fluctuates, usually dropping steady
lumens: 3330 @start, 2940 @30 secs, throw: 34 kcd
After with same batteries as is, not charged in between:
tailcap reading: 5.78A
lumens: 4930 @start, 4726 @30 secs, throw: 48 kcd
Waiting on the TF batteries to charge, takes long on an i4, but should get 5000 lumens.
I see one of these drivers in the fit-40s in the near future, thanks for the update tom. Any ideas on a more heavy duty tail switch or are we crossing that bridge when we come to it?
I'm taking my caliper home with me to measure the driver for my UniqueFire S7; if it's the same size, I'll be checking the possibility of completing either the resistor mod or hitting up I-O for the high-power driver. I'm just not as satisfied with my S7 since I have my King clone which is not quite as bright, but too close for the difference between a 3-LED and 7-LED light.
Anyone with experience with the resistor mod; what wattage resistor should be used? and what's a good source for a single low-resistance resistor of the appropriate sort?
Dunno what to do about the switch - where do you find better ones? Only thing I've seen is where O-L makes them out of copper - no idea how he does it, amazin stuff though. There is a lot of power going through it. The best I see is the conventional type rated for 2.5A, 240v. Can't recall now what's in the J18, though I had it apart a couple of times - it was flaky when I first got the light, did something to fix it, maybe just tightened it up, re-assembled.
That’s my problem, the only high current switch I’m aware of is that mega bucks mosfet jobbie, not seeing that myself. I suppose the other answer is braid the spring and buy in a rook of switches, just swap em when they burn out.
Just tested the J18 out on 2 ICR KK's, reads 5.2A, does 3630-3570 lumens throw of 35 kcd, very steady during the first 30 secs. Nice light at this size, easier on the components and switch too!!
I thought they were standard switches, you can get at FastTech, I-O, FancyFlashlights, etc., but will confirm. The ones I've been buying are stamped at 2.5A for 240v 1.5A 250v - I've replaced a lot of them, mainly because of quality issues, squeeks, etc. I never melted one, so I'm not sure where/how it breaks down. I saw in one of O-L's mods, he took a switch apart in all it's pieces, then fabricated replacements parts all in copper, I think from copper sheet material - that switch must be awesome -- beware of oxidation though!! (O-L's new thread on that topic).
Update: Just confirmed it's a 1.5A 250v rated switch, Omten brand name - I got 2 spares already of the exact brand name. Good thing is it's an actual brand name, and should be better quality then what you get in a typical C8 for example (not the XinTD - it's a quality switch already). Buy them here for 50 - 60 cents each:
I’ve got a pack of the omtens, I did my zy-t08 switch making sure it was not the source of low run current. I’ve just found out a host that’s inbound has a 3a switch, I’ll see if that has any id on, may be a bit more robust….
Final #'s on the J18 on fresh off-the-charger TF 5000's, 5.87A measured at tailcap:
5,235 @start - 4,998 @30 secs --> Darn, just short of 5,000!! Impressive @start though...
There are some driver issues though - slow mode changing, buzzing in low, maybe slightly in mid - gonna check the ground/mount now... Gotta get a wall beam shot -- freak'n thing is blinding on the snow!!
I have read forum post after forum post to the point of almost being nauseated. I have the Trustfire TR-J18 that ive had for about a week now. I am currently running the flash light with four 1.2 volt AA’s @ 2700 mAh’s.
From my limited understanding that would be 1.2 volts x 4 = 4.8 total volts @ 2.7 milliamps per hour? Correct?
I do have 26650 x 3 batteries that are rated at 3.7 volts and 4000 mAH coming in the mail by Tenergy with a battery charger that can and does charge batteries independantly from each other.
My biggest question is that since I am going to be increasing the voltage to 11.1 (which is over twice what I am currently running), am I going to see the luman and lux increase?
I laugh almost evertime I see the “Caution: Hot Surface” sticker on the bell of the light because it never puts off any heat needless to say but there is no way someone could possibly hurt themselves.
You are greatly under driving it, even with AA's, so the light is probably ok. Others may know more exactly what's going on with driving it at that voltage, but my best guess it will be ok, and yes, you should see a lot more lumens and lux. Think mine did over 3,000 stock with 3 TrustFire 26650 5000's - definitely brighter than a good, stock SRK.
I got my KD driver, Got it installed and. … um… nothing…… it won’t work…
If anybody has any ideas what it could be… please let me know… here’s what I did…
Removed the old driver (just cut the 2 wires). soldered the new kd driver in… red to red… black to black.
Removed the center spring from the old driver… soldered to the centre of the new driver (added braid).
Added braid to the tail cap spring…… put everything back together… “nothing”.
Looking at the driver… I am assuming that the outside “ring” of contact is the negative and the inside center is positive. The large outer spring seems to be not making contact… so… soldered the large outside spring to the top contacts… no luck still…
Looked again… “maybe” the negative is the contact on the BOTTOM of the driver…. found a contact that bridged down… added a bit of braid to connect to the bottom contact (outer ring of the driver)… still no luck.
What I did notice tho is that with the tail cap off and batteries in… if I try and “jump” the battery to the battery tube, I do get a “tiny” spark… which is telling me that something is trying to work.
Few things I guess I wanted to see if anybody could clear up.
a) is the negative contact the on the top or the bottom of the driver (or is it both).
b) do you think it is a driver problem?? or do you think it’s a problem with the batteries (trust fire flames 3000mah… they did work before fine before the light went dim all of the sudden… prompting me to swap drivers).
Johnny, did you ever get the issues ironed out on this light? If it still doesn't work, try posting some photos of the work you did. Also, the KD drivers have a slight delay when using the tailcap or taking current measurements with the tailcap removed. Also, what batteries are you using. If it's assembled correctly, it could also be the cells are not powerful enough to drive the light.
