Yes. The Eneloops will quite often give more output due to lower internal resistance despite the lower nominal voltage.
Hmm.. 14500 in a 15 min charger. That would make an interesting video. Hopefully it would not charge but if it did I would expect an explosion.
Thanks for all the good info. I found 4-14500's 900ma w/universal charger on E-Bay for $11.99 W/free shipping. I am going to use the charger for my AA's and ditch the 15 min charger.
Thanks everyone for the help.
Hi Dave,
Just confirming your new li-ion charger is for charging your new 14500s and not for recharging NiMH AAs right?
Remember the 14500s charge up to 4.2 volts. (Or are you saying you are getting a charger for both chemistries?)
First of all buying batteries or chargers on ebay is a bad idea
Absolutely the worst place to buy important things like chargers or batteries ..Too many fakes , too much junk ,
that'ts a really good question ..Are you thinking about charging nimh with a lithium ion charger ??
And those 3 words are pure death anyway .. 15 minute charger ?? huh ?? on what planet is this ?? if a nimh charger doesn't take like 4 hours you can almost always trust it's junk.
You need to study this stuff before you buy
Sorry to get ya all worked up. http://cgi.ebay.com/4-x-900mAh-14500-rechargeable-battery-charger-AA-AAA-/130502134632?pt=LH_DefaultDomain_0&hash=item1e62888b68 Is what I ordered.
I have a similar charger I use for my 18650's with no problems (also e-bay). Guess I got lucky with my 15 min charger I have not had to buy any batteries for my camera for the last 3 years.
Anyway, I know some of these questions seem dumb to some of you. I would rather ask it here rather than ask someone in china named Joe.
The charger will also charge my 18650's so that's bonus.
I guess another greenhorn question would be Universill means so onley for Li-ion batterys?
If the batteries are fakes I wonder if they will work in my fake Sipik flashlight?
For lithium-ion batteries you need a specific charger that can only charge that type of batterie because the voltage is much higher than that of Nimh-batteries.
Do not use the wrong charger, it can be dangerous.
I use a Ultrafire WF-139 for 14500 and 18650's, and a Maha Powerex MH-C9000 for AA and AAA.
Every type of battery needs the correct charger, for the 12V battery of your car, you also have to use the right charger...
Dave, don't worry about asking "dumb" questions. Like Don says, the dumb question is the one that never gets asked. It's worthwhile to be as informed as possible when dealing with Li-ion batteries especially.
The charger on the eBay link provided seems to indicate that in fact charge both NiMH and Li-ion. It has 2 different outputs. I wonder how it knows which battery type it's charging. If it ever makes a mistake...
Hi Dave,
Interested to hear how the batteries and charger perform.
I'm no expert on Li ions but $12 for 4 x 14500s and a charger seems way cheap.
Assuming the protection circuitry/design doesnt kick in, I see the charger discharging the battery, but its all depending on its floating voltage.
Slightly off topic but I just stopped the wife putting 2 14500's in a tv remote. The batteries were dead so she thought she would change them and saw what she thought were aa batteries lying around. I wonder what would have happened?
I assume you would have gotten extra channels
Or maybe you would be able to set your TV Remote to "stun".
The charger and batterys should show up any day or week now (china) I will let you guys know how they work out.
If on the news you see any clips of a house fire due to battery explosion in Michigan. That might cause a delay in me getting back to everyone on how they perform.
Thanks for all the input. Dave
Hey all! i have been reading here quite a while and just registered and i saw this post had no ending (or did it LOL?) What happened Dave? Did the stuff work out? I just gotta know!!! BTW, My name is Keith and I am glad to be here. Let me know if i have broken any protocol with my first post.
Keith
Welcome to BLF, budynabuick..
Thank you mate for your well come
Welcome! There’s not so many protocols to worry about breaking here!
Been reading up a bit on Li-Ion batteries, having some basic questions as well:
1. Are protected Li-Ion preferred over non-protected?
I read in some places some flashlights won't take protected--wonder which would be safest purchase for compatibility with flashlights on the market then (protected vs. non-protected)?
2. It seems the light output on the same flashlight is normally doubled for Li-Ion vs. AA NiMH cells (assuming the flashlight takes both). I suppose that would mean the runtime would be almost half on the Li-Ion's compared to NiMH's then (if I take TrustFire 14500 0.6mAH x3.7v = 2.2WH, a bit less than an Eneloop AA ...) ?
2. Was reading a bit on the BLF Battery database, I wonder what'd be a good choice for 14500 Li-Ion?
3. And I am reading that the sizes for the same Li-Ion type can vary quite a bit among different brands.
Wonder if the ones in the database are those that conform to the standard sizes--and if not, would be great if there'd be an additional column for the actual battery dimensions... .
Thx much for the info... .
if you're not sure, definitely get the protected, and yes the light will be a lot brighter. i've had good luck with the trustfire flame protected 14500 batteries, and they fit everything i needed them to fit.
