Test / Review: Efest IMR26650 3000mAh (Blue)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 4 hours ago
DSC_1561
Official specifications:
  • Nominal Voltage: 3.7v
  • Battery Model: 26650 Capacity: 3000mAh
  • Positive: Flat top
  • Cycle Life: 500 Cycles
  • Max Charging Rate: 4.5amps
Efest%20IMR26650%203000mAh%20(Blue)-info
This is a IMR cell with low internal resistance.
DSC_1555
DSC_1562 DSC_1563
DSC_1564
DSC_1565
Efest%20IMR26650%203000mAh%20(Blue)-Capacity
The cells does very good up to 10A, but 15A is to much.
Efest%20IMR26650%203000mAh%20(Blue)-CapacityTimeHours
Efest%20IMR26650%203000mAh%20(Blue)-Energy
Efest%20IMR26650%203000mAh%20(Blue)-PowerLoadTime
Efest%20IMR26650%203000mAh%20(Blue)-TripCurrent
Efest%20IMR26650%203000mAh%20(Blue)-Charge
Conclusion
The cells has only about 2500mAh capacity, this is low for a 26650, you can get 18650 with more capacity, this does not make this a bad battery, but a battery designed for a special purpose.
If you need as much voltage as possible and a lot of current, this is the battery, especially between 5A and 10A.
At the current time I can only rate them acceptable, because Efest is a new company, and the batteries is not from one of the big brands.
Notes and links
The batteries was supplied by Efest for review.
Edited by: sb56637 on 08/26/2014 - 17:45
MRsDNF
MRsDNF's picture
Thanks HKJ. Maybe the capacity on these batteries should be changed to closer what really are?
nickelflipper
nickelflipper's picture
Last seen: 3 weeks 5 days ago
I ‘ve been wondering how these cells would perform. Thanks for the review, always informative. Looks like they would hold 10A, at least for a little while.
Kent
sb56637
sb56637's picture
Last seen: 4 hours 34 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
That Ninja Guy
That Ninja Guy's picture
Last seen: 10 months 4 weeks ago
Thanks for the thorough review HKJ as usual. I can’t see me needing this type of cell in any current situation, but you never know. Smile
