If you look at the myriad of PCBs out there in electronic devices the distances separating circuitry apart from disaster is likewise as these USB units. The point being is don’t get these type of things wet or for that matter any other similar device, nor mess around in there unless you know what you’re doing and you should be fine. Even if gaps somehow connected with the AC voltages involved the result would most likely be a fried connection, a strong smell, and a device that doesn’t work.
The tests here IMO would have more credence if the author subsequently bridged these gaps, submerged the units, or some similar test to see what actually happens if said gap was bridged. Think UL Labs testing.
The safety standards says 4 mm distance in air, on a pcb it will be longer, except if it has a special isolating coating. This distance has two purposes, one is to withstand humidity and dirt, the other is to withstand transients on the mains.
I did not open the transformer, but it will probably also fail the safety standards on the cheap units.
Read this article from BBS, especially the bottom part, that is what can happen with the worst of these chargers.
A UL Labs style torture test would be interesting. Do they catch on fire, go into electrocution mode, etc. IMO, any electrical device that’s abused whether by liquid, cord yanking, what have you, is potentially dangerous. The construction of the units claimed as being unsafe on the surface seems pretty robust. I don’t see dangling bare wires or particularly shoddy soldering IOW.
The safety standard is called IEC60950-1 and is implemented in many countries (including US). One important aspect of it is that any vital to safety isolation must be double thickness or two layers normal isolation. There is also different requirements in US and EU, because the mains voltage is different (110VAC vs. 230VAC).
For US indoor equipment with safety earth only needs 1 mm safety distance, without earth 2mm, in "Polluted degree 3" environment it is 2.6 mm and all these distances can be reduced if the factory does a high voltage test on equipment, before shipping.
The standard does list many other safety requirements, including detailed specifications on how solid the equipment must be.
IOW not three pronged like you typically see on most power tools? If they had it then the 1mm distance would be ok? I was also thinking about US and EU voltages and their respective different safety guidelines as you wrote the reply.
I think if we dissected most Chinese inexpensive electronic devices a good many of them would also fail under stringent wide safety criteria as well.
Because both EU and US uses the same safety standard, the differences are probably minor, and all equipment that can work on bot 110 and 230VAC, needs to use the larger distances.
I believe that big brand names are careful with the security, just imagine what it would do to Samsung or Apple if one of their charges killed a child!
I was thinking of buying what looks like the same 4 USB power adapter on Ebay, but with the name YOOPOO (!). So it is nice to see it covered here. I wonder if it is the same adapter but with a different name?
Its rated for 2A single output or 1A each dual output. So I guess it should be fine for tablets and such. I dont have any test equipment, but if there is anything I can figure out with a DMM, I will try. :)
