I got 172 at switch-on for my F23, the only light that overlaps with your list. I certainly don't trust my readings enough to give decimal places.
My numbers may be an underestimate - certainly sixty545 who has a better sphere than mine got higher results on the same Ultrafire C303 that I measured.
I find it makes a big difference just how fully charged the cells are. I use this protocol:
The NiMH cells get charged on a Vanson SpeedyBox and get left for 24 hours after the light turns green.
The lithium cells (That can take the charge rate) get charged in an Ultrafire WF-139 and get used within a minute of the light turning green. Mine doesn't seem to continue to charge but I can't say I fully trust it. The other cells get charged by a hobby charger.
Obviously this leads to what I regard as absolute maximum real-world readings and is why I do the readings at 30 seconds and 2 minutes as well.
Am I the only one here that did not know this combination was so damn powerful? 800 lumens? Are you kidding me? I thought 800 lumen flashlights cost like, a bazillion dollars. I've always been amazed at the output of my lights with this set-up but I reckoned it was about four or five hundred - which I would have been/was fine with.
