It should be in every tank and armored personnel carrier in case one ran out of ammo. lol
Loaded with 3D’s if you’re a security guard this thing at minimum requires you able to bench press 300 lbs. Oh and you better have big hands too with the ability to grip a large pipe once you assume a standing position regardless of how sore your knuckles are from draggin them on the pavement.
Other than that, I can see this getting modded to run off of 1x18650 or 1 x32650. I think the 3C Super Thrower is still superior especially with a side clicky.
My local HD showed 6 units “in stock”… When I got there, they were unable to locate any units. They told me that they would try to find them and give me call. Bunch of BS. What if I ordered online and chose to pick up at store?. Things like this really piss me off!!
Reflector is plastic, 60mm wide (od) x 44mm deep
Lens is plastic, 61/5mm wide
LED star is 20mm wide
Aluminum screw in pill, looks to be pretty good heatsink
Overall length: 12-5/8 inches
It's a 3 speed: High, Medium, Strobe. All tail - reverse clicky. As suspected, it's slightly brighter than the 3C, but hotspot not as tight and intense.
L-R: Small Sun ZY-T08, Defiant 3C, Defiant 3D, Maglite 2D, Solarforce M8, Mini Maglite Pro
God another Defiant light? How many of these am I going to end up owning? The 550 lumens Christmas one was cool, had to grab it at $20. The 3C Super Thrower was also cool and even though I didn't need it, well I bought one anyways. Now I'm going to end up getting this for what reason I do not know, other than compulsion of course... Really just wish they weren't available at HD, I wish they were only sold at some random store that does not exist in my area, would make life so much easier.
They are probably in the "no home" section. It's a smaller display box, since there's only six lights in it. About 24x24x24 box.
I gave the guy in my store the number and he found it in the "no home" area. In my store it's in the tool section, on upper shelving, but it may be anywhere in other stores.
The title says it all, it weighs two pounds, four ounces with batteries.
The other posters aren’t blowing smoke, this thing is heavy and big. I bought it mainly as a curiosity because of the weight. Plus, I’m hoping there will be some great mod ideas. But at this weight and size, this behemoth will stay on the shelf 99.9% of the time. Unless, like others said, I need to use a light AND crack ice blocks in half or bash heads or drive in BIG nails. Or maybe some long-lost uncle leaves me a truck full of D batteries in his will.
Still light here in windy SoCal, but it appears floodier than the HD sooper thrower while hunting white walls. It sure is heavier. That’s for sure.
Also, they couldn’t find it, just like the other HD torches. Took ’em a half hour. Plus, I was all excited and got it home; threw the batteries in and and and ……… COMPLETELY DOA.
Fortunately, BLF has taught me well. Paper clip showed me that it works fine without the switch and tailcap. DMM showed me that the switch worked fine, with the tailcape off the light. Disassembly was fairly straightforward, and so was the problem. Switch contact was not in the spring correctly so when pressure was applied, it lost contact. Put it back together. STILL NOTHING! GRRRRR.
More fiddling and use of certain phrases and words that are not allowed to be printed in a family forum.
This problem was not so easily trouble-shooted. It appeared that the VERY tight-fitting end cap caused the O rings to roll out of place and block the contact (even with a liberal goop of nyogel). Will investigate more thoroughly when I have more time. In any case, WITH end-cap o rings = no work. WITHOUT o rings = work.
Summary: Seems like a well-made light and brightness is okay, but it is way too big and heavy for anything but emergency use (or using it to demo a concrete patio).
Well, it's brighter than the 3C Thrower and I really don't notice much of a larger spot. It throws well. Now I've only tried at about 250 yards, but right now, I would favor the 3D over the 3C. That's in stock light form, no mods. It will be interesting to see the driver in this thing. Can't find out here at work, but I will at home.
I was reading through the reviews of this light on the HD site. One of the reviewers says, “The one feature it’s missing is a focus adjustment.”
Really? A testament to legacy lights, this feature is still engrained on consumer’s ‘flashlight feature’ checklist. Until the day arrives that people forget about focusing, Maglite will likely cater to it in order to stand out. Too bad. They should just leave that to LED Lenser and move on.
Besides, I can’t believe people don’t think of simply buying an additional, more floody flashlight
or getting creative with Saran Wrap and the rubber bumper cover that comes with the 3D Defiant.
Just got one of these from my local HD but they were still in the box on the over head shelf. A stock man was nice enough to help me look and get one out for me once we found them. 8) Now what to buy the wife so she doesn’t blow up!!! 0:)
Yeah, mine too. I went into the store, armed with the SKU# and they looked at me like a deer in the headlights. Finally, the aisle guy, got the ladder out, and there was a box of them on the top shelf, all taped shut. They brought it down, and I bought the whole box, minus one that the salesman wanted. They didn’t seem to know anything about them, however, the had bunchs of the Garry Bunk Defiant models.
