Bottom side of pill. This plastic cover just unscrews
Driver and big old spring - Resistance
Driver. I believe it's direct drive with modes. H/M/Strobe
Tail cap insert unscrews
Another super long spring and an inner insert that holds the switch in.
Switch assembly I doubt it would take 3+ amps for long
Beam Shots - Mouseovers. MOUSEOUT is 3C MOUSEOVER IS 3D in ALL Shots.
1/8 second shutter, to show the beam better.
1 second shutter
2 Seconds Shutter, to show the tree.
Down to 1 second shutter here You can really notice how much more spill the 3D is, but it's still brighter in the spot as the 3C is. At least to me it is.
1 second shutter
Sorry, I don't have a stationary holder for the lights when I take photos. Handheld does not make each shot in the exact place as the last one.
What this proves is that the Depth of the reflector has little to do with the size of the spot. It is the diameter and profile of the reflector. The spot on the 3D is just about identical to the 3C and it is brighter. The 3D has more spill, due to the shallow reflector.
if i could get my hands on a P bin sst-90 that would be ideal for this… i already have 4x c nimh i use in my vpt3 so i will test to see if they fit with minor modification
To me the 3C still outdoes the 3D on all counts. I would be leery of ‘handheld’ beamshots telling the whole story. No offence meant to anyone here doing so but IMO if you’re really going to compare light output, spill, throw, etc., the lights should be fixed and pointed exactly the same onto something immovable like a tripod or what have you. Hotspots for example at those distances just need a tiny bit of variance to throw perceptions off on how things are lit up. Much less spill and flood. IOW I wouldn’t jump to conclusions just quite yet.
The 3C’s larger reflector when all’s said and done still makes the difference. JMO.
Yes!
Maglite is missing out on a huge market. It’s infuriating that the American company won’t put out an 8xAA/2D or 12xAA/3D-size XM-L light with a 3” turbohead. Throw in a white diffusing lens with their anti-roll bumper, and they would have no excuse for including the now-obsolete cam-action focus system.
As for this light…I’ll have to wait and see if I’ll pick it up over the 3C.
Obviously the 3D is going to have a longer runtime just by shear battery horsepower and one could also think that its ‘brightness’ will last longer at x-mount intensity than the 3C hence individual differences in performance at any given moment. But that’s why we also mess around with lithiums more than alkalines here. lol
>>>>Anyone able to do some light output measurements?
Hopefully someone with a light-measuring sphere (or bathroom) will post actual lumen output, but my 3C moirders the 3D in throw, even on a white wall (and tested outside last night). I don’t have the equipment for a real lumen readout. For my eyeball test, 3D had the brand-new defiant batteries with maybe 3 minutes of run time on them; 3C was with only one 18650 (with the spacer mod), a fully charged fasttech unprotected Samsung 2600 pink.
The 18650 spacer mod for the 3C is really simple to do and totally worth it. Lightens up the weight considerably and no more throwaway alkalines! (You can also just screw a 26650 on to the 3C head with the BLF A8 battery tube.)
Haven’t tried anything with the 3D tube yet, but it’s cavernous!
