Photos?
here is what the bulb looks like. I will have to get some pictures of the flashlight when I get home as I do not have it with me.
Thanks for trying to help!
yes they exist in a lot of variations from cheap to expensive. But I haven’t bought one yet because i have no light which is worth such an upgrade. But if i would see such a cheap like the walmart one i would buy it just for fun.
I put one of these:
http://www.niteize.com/product/LED-Upgrade-Kit-C-D-CELL.asp
In one of these:
Its worked pretty good so far. The light is not real bright but will light up a bedroom for days.
Does it matter if I get a 3 volt or a 6 volt drop in? I see they have both for the 2 cell d lights.
4 AAA is 6Volts. That is too high for the 3 volt bulb.
So I should buy the 3 volt bulb?
this one correct:
http://www.walmart.com/ip/Rayovac-3VLED-1T-Rayovac-3V-LED-Replacement-Bulb-2-Cell/22086116
I have a dorcy led bulb like
this one for a retro flashlight.
It is not very bright but a good upgrade.
no if you have 4x1.5V in series than you have 6V and should buy the 6V bulb.
or
If you take your light apart and read what stands on your bulb you will see what you need
Hey, Chad…
I was trying to do the exact same thing with my Garrity in early 2012. I abandoned the idea when, for some reason, the MagLED wouldn’t sit right in it. I finally sold it.
Yes I know what you mean. I tried my Terralux insert from my mag light in it and it would not fit, but the one that actually came with the mag light originally did fit. I think the insert was just a tad bit bigger around.
would this one work as a drop in?
the light bulb in there now is a PR15 4.8v 0.5 amps. Any suggestions for a replacement led bulb for this?
Honest answer is ... there is nothing made by garity that is worth throwing money at ..certainly not 10$
Buy this for 16$ instead http://www.fasttech.com/products/1601/10002364/1195011 and you will take the Garity out back and shoot it dead .
Lots of us have old plastic lights that weren't that bad .. truth is the reflector is thing that will getcha .
i have about 5 dumb lanterns that basiclly can't be modded the beams are horrible with an led .. most of them are a lantern flashlight combo too .. Dorcy combo lantern . the worlds most un-moddable light
i wonder if it floats
will it blend ?
Boaz…didn’t these used to be more expensive? Maybe that was some other Convoy model I was thinking of. Looks like a great little light.
I ended up giving up on this idea and I just bought one of these:
http://www.amazon.com/gp/product/B0084YL5XK/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
How did that work out for you… I can’t see that working well as a lantern.
Oh yeah!
Straight up drop in replacement for multi cell flange style maglite bulbs
http://www.superbrightleds.com/cat/b-series/
I got the 1 watt ( 7~26 VDC) in my 18vdc porter cable tool light, and a 3 watt in my 3-D cell maglights and they work AWESOME…the one I got for the dewalt at lowes got CRAZY hot and melted the retaining ring…after I put these in em…very good light, almost NO heat at all, and they run forever!
Make sure you get the right voltage
