Tutorial: Rewrapping a battery
95 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 days 1 hour ago
DSC_1789
The above battery cannot be used anymore, it will short and might explode.
The wrapping will sometimes break, luckily it is a fairly simple operation to fix it.
Tools and parts needed
DSC_1801
I am using shrink wrap to repair the battery, due to the heat gun I uses, I have selected a low temperature type.
When flat it is 29.5 mm wide, the inner diameter is 18.5 mm, it will shrink at 80 Deg. C.
I bought a roll with 25 feet (7.6 meter) on ebay for $11 (Sellers name is atop_authentic_auction). This roll will last for more than 80 batteries. Fasttech has heat shrink in 1 meter pieces for less than $1.
This heatshrink is also fairly thin, this is an advantage for some lights.
Often heat shrink is specified in width of the flat tube, the table below shows the minimum sizes for different battery sizes.
diameter
DSC_1802
As a heat gun I uses a hair dryer, it is not the perfect tool for the job, but it can be used.
DSC_1803
I do also need something to measure with, my digital caliper is fine for that (A ordinary ruler could also be used).
With a caliper, remember to cover the jaws or it will short the battery.
DSC_1804
To cut the heat shrink I uses scissors.
Rewrapping
DSC_1790
I want the heat shrink tube to be about 3 mm longer than the battery at both ends, with a 68 mm battery this means 74 mm tube.
DSC_1792
The new tube for the battery has been cut of the roll.
Unwrapping
I uses the fingers to removing the old heat shrink, using a knife or scissors is unsafe.
If there is two layers of heat shrink, only remove the outer layer.
DSC_1791
The "naked" battery, do not try to bend the protection pcb out to get a look.
DSC_1794
Putting the new heat shrink onto the battery.
DSC_1795
There will be about 3 mm extra at each end.
Shrinking Shrinking2
Applying heat, rotate the battery and swipe the heat gun back and forth. If using a real heat gun, be careful with the fingers holding the battery!
It is possible to increase the temperature by covering part of the air intake on the heat gun (This might also melt the gun if overdone).
The battery must not be heated much (As long as it is possible to hold it, the temperature is fine). This is usual not a problem, the heat shrink will shrink long time before the battery is heated.
Final result
DSC_1798 DSC_1797
DSC_1799
DSC_1800
With a new covering, the capacity information is gone, to fix that I have added a label with capacity. I also included the date I got the battery.
Edited by: sb56637 on 02/28/2013 - 08:17
ryansoh3
ryansoh3's picture
Last seen: 1 month 3 days ago
Awesome tutorial, thank you very much!
I would just like to add that a very similar or even the same wrap used by HKJ is avaliable at FastTech at 1m units:
http://www.fasttech.com/products/1140200
BLF ≠ B-grade Flashlight Forum
Richie086
Richie086's picture
Last seen: 2 hours 49 min ago
Thanks for posting this HJK. One of my Trustfire 26650 5000mAh cells is starting to loose part of the wrapping. I’ll order this shrink wrap and make the fix.
Also glad to see I’m not the only one that uses labels to print the purchase date on the cell Wink
Richie
ryansoh3
ryansoh3's picture
I’m not quite sure if the shrink wrap will be able to wrap a 26650 cell, might be too wide… 0:)
Richie086
Richie086's picture
Thanks for the heads up. I’ll take some measurements of my cell and find the correct diameter for a 26650.
Richie
ryansoh3
ryansoh3's picture
No problem, I’m sure you’d figure it out sooner or later. Silly
That Ninja Guy
That Ninja Guy's picture
Last seen: 1 year 9 months ago
Thanks for the great write-up!
HKJ
HKJ's picture
ryansoh3 wrote:
I would just like to add that the same shrink wrap that HKJ used is avaliable at FastTech at 1m units: http://www.fasttech.com/products/1140200[/quote]
It is not exactly the same, the one I uses is without glue.
Richie086 wrote:
Thanks for posting this HJK. One of my Trustfire 26650 5000mAh cells is starting to loose part of the wrapping. I'll order this shrink wrap and make the fix.
You have to get something that is slightly above 26 mm in diameter
Richie086 wrote:
Also glad to see I'm not the only one that uses labels to print the purchase date on the cell ;)
My experience with pens is that the markings does not last, with these labels it will last.
ryansoh3
ryansoh3's picture
Thanks for pointing that out.
Do you know how different it will be with the adhesive?
That Ninja Guy
I use an industrial Sharpie for all my cell writing, haven’t had issues with it yet…
HKJ
HKJ's picture
ryansoh3 wrote:
Thanks for pointing that out. Do you know how different it will be with the adhesive?[/quote]
I have not tried with adhesive, but I will not expect any different when rewrapping, the final result will probably be a bit stronger.
Werner
Werner's picture
Last seen: 3 years 2 months ago
I would just like to add that a similar wrap used by HKJ (this one with adhesive) is avaliable at FastTech at 1m units:
I have ordered this shrink and it is without adhesive glue whatever…just blue plastic which is a tight fight on a 18650.
pictures in another thread:
http://budgetlightforum.com/node/17907#comment-314389
I also rewraped a 16340 with the fasttech shrink, this worked but the wrap doesn’t get perfect plain…
ryansoh3
ryansoh3's picture
Thanks for the confirmation!
Streamer
Streamer's picture
Last seen: 2 years 11 months ago
Nothing but red x’s…can’t see the pics.
HKJ
HKJ's picture
Streamer wrote:
Nothing but red x's...can't see the pics.
Looks like the server is down, it will probably not take very long before it is up again (I uses a hosting service).
CheapThrills
CheapThrills's picture
Last seen: 1 week 6 days ago
Cannot see pics at the moment.
HKJ
HKJ's picture
They are back again.
CheapThrills
Nice, thanks!
I have re-wrapped some batteries, did not bother to measure the wrapper before cutting. Just estimated it by eye.
I think after re-wrapping it feels at least as much if not more durable than before.
stevetexas
Last seen: 9 years 2 months ago
HKJ gives good advice.
I use a Laundry Marking pen from the Office Supply to mark cells. This is better than the so called “permanent marker”. The Laundry Markers are the ones that never wash out of clothes, even in hot water. Don’t get it too oily before you mark it.
If you mark it….better check your spelling first, you ain’t gonna change it.
ek9cv5
Thanks for the tutorial
Don
Don's picture
Last seen: 2 years 1 month ago
I have several metres of green shrinkwrap suitable for 18650’s – anyone in the EU who wants some – PM me – the cost will be the postage plus a few pennies. The cells I needed to rewrap have been rewrapped. Happy to supply it in 75mm chunks. And don’t pay till it arrives. Experience there.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
arjay
Last seen: 5 years 3 weeks ago
Thanks for the tutorial!
Question, isn’t the heat shrink too tight? I know that you need your heat shrink to be 3-5mm wider than what you intend to wrap. If the typical diameter of a 18540 is 18.5mm, how does your 18.5mm shrink wrap fit with a bit of room to spare? I was wondering if I should go a bit bigger by 3-5mm to be safe.
Don
Don's picture
The internal dimeter (unshrunk is 18.78mm). “Circumference” of the flat stuff is 59mm. So 59/pi gives the “diameter”.
Werner
Werner's picture
it is tight but it works, like i mentioned this shrinks not so much thats why my 16340(16mm diameter) is not so tight shrinked than my 18650.
HKJ
HKJ's picture
arjay wrote:
Question, isn't the heat shrink too tight? I know that you need your heat shrink to be 3-5mm wider than what you intend to wrap. If the typical diameter of a 18540 is 18.5mm, how does your 18.5mm shrink wrap fit with a bit of room to spare? I was wondering if I should go a bit bigger by 3-5mm to be safe.
No, as long as it can be pulled over the battery it is fine.
I have added a table with diameter and minimum width of the heat shrink tube for the common battery sizes. If you buy from somewhere where they do not specify that it fits a specific battery, I would recommend to get at least 1 mm extra.
NightCrawl
Last seen: 6 years 8 months ago
The larger the heatshrink, the thicker it will get. So for most flashlights its best to use a heatshrink that doesnt have to shrink very much.
arjay
Thanks for clearing that up guys. I didn’t want to end up picking up the wrong ones.
monanoke
monanoke's picture
Last seen: 4 weeks 1 day ago
Thanks for the write up HKJ. Just broke the wrapping on one of my keeppower 18650 and was looking for the wrap to fix it.
a
C
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 4 years 2 months ago
That is actually easier than I thought.
kreisler
kreisler's picture
Last seen: 8 years 10 months ago
nice crisp tutorial thanks!
Wink
*FMI* i got 4 i/o sh
Pavithra_uk
Pavithra_uk's picture
Last seen: 4 months 1 week ago
awesome tutorial
