I’ve actually been using asda rechargeable aaa cells in one light and so far, so good, might be worth a look.
Eneloops big point is low self discharge - they don’t go flat on the shelf like traditional rechargeable cells. They also seem able to give out decent amounts of current so largely, the decision depends on the light in question, its regularity of use and current demands.
What this waffling means is I have no clue if the cells you linked are any good, helpful eh? :bigsmile:
Thanks guys. So for a light I was using a lot (right now my Sipik SK-68 clone), would it be better to get a higher capacity and sacrifice the low self discharge feature? Would higher capacity make my torch brighter?
I ask because 7dayshop also have these 2900mah for the same price.
I wouldn’t recommend them, there are tests online somewhere and the variability is massive. The capacity is generally less than claimed and the self-disacharge is higher than eneloops.
I wouldn’t go with the XXs but just the basic eneloops, they have a bit less capacity but are rated for 3x as many cycles, meaning they are probably more robust in general. The Panasonic (Evolta I think) LSD ni-mhs are good too if you can find them for a similar/lower price.
The ‘normal’, non-LSD niMh self-discharges an average of 1% a day. So your choice will be dependent on how much you use your torch in an average length of time. In my case, I’m a very casual user so an LSD is a must for me. If you go for an AA LSD, go with standard Eneloop. I have both the Eneloop and the Imedion LSDs and the Eneloops are much more consistent, and easily exceeds its minimum rating.
iCell media are a good source. When I clicked your link I noticed I’d bought these a year ago, and since then I’ve had a 4x 4 AA pack of eneloops at a great price (about £18, I seem to recall - a deal long since gone). I recently bought 4xAAA eneloops from them, which never arrived - when I told them after a couple of weeks they sent a new packet. Still haven’t seen the first packet.
Oh, and 7Dayshop are, like iCell, based in the Channel Islands, although the tax advantages in the form of no VAT to UK have been scuppered since last year.
Well, I’d say you should have them by now. I never did receive the first shipment, but when I emailed to tell them they hadn’t arrived, they immediately re-sent another set of cells. They came in 3 or 4 days - so drop them an email.
They use Deutsche Post from the Channel Islands, presumably because it’s cheaper than Royal Mail.
BTW, 7Dayshop no longer ships lithium cells to the UK by Royal Mail. Not that they were that competitive.
Yeah, that’s what got me wondering - Fasttech stuff has been arriving in 8/9 days, so I was a bit concerned that the eneloops took so long. Never did get the first lot, so not sure what’s going on - the route via Frankfurt isn’t so clever.
If you can find the Camelion 2100mAh LSDs or the Panasonic evolta ones for less than Eneloops I’d buy them, they hold their charge nicely. Not sure about their high current (5+ amps) performance as I have no means of testing this. Eneloops are supposed to be good up to 8 amps without the voltage falling off a cliff.
I bought some evolta’s about six months ago. I love them, but they do seem to have a slightly lower voltage after a few weeks off the charger compared to the Sanyo’s. However Evolta’s seem to have better wrappers than the eneloop’s, a big plus for me. My sons don’t take the same care taking them when taking them out of their toys. But the Panasonic’s seem to hold up better.
Thanks, Don. I couldn’t find any Camelion but I did find Panasonic Evolta, and thought I’d found a bargain until I realised they use the same name for their alkalines!! :bigsmile:
I must say I do like the striking “eco” styling of their rechargeables. I wonder how they will rebrand eneloops for worldwide distribution.
