Yeah, i’ve heard great things about Tassie. I might even be tempted to emigrate there as there is no work here in Ireland. Australia/Tassie is great for Electricians at the moment i believe, not to mention the better climate
If the group buy doesn’t work out, i might put my soldering skills to the test
Because the SL3 is quite substantial and weighty, it handles the 9amps quite nicely. It still steps down, so it works out well as its just getting hot and the level drops.
The switch still works as normal.
I had some issues with faulty chips, and possibly other unknown factors running 12 extra chips at just over 9amps. I settled at 11 extra chips running around 8.7amps reliably.
again, depending on price and how quick this can be done, im in. always wanted a triple and always wanted a shadow… why not a limited run triple shadow?
I don’t have anymore info on a possible production run 9A SL3, as this thread was just testing the water. I got curious after seeing the circuit board and finding out it was the perfect candidate for extra AMC chips, so had a go at making my own 9A version.
Yeah, this Is the perfect balance of flood and throw for me. It lights up everything around me, and still has a concentrated hotspot that throws really well.
At the moment, the SL3 drops down based on voltage sag(as far as i know). The time before drop down varies between cells.
Its several minutes even @ 9A, and at which stage, the light is hot.
ill wait a week or so to see if this materializes… if not i may just buy one and add the chips myself. id like to see what changes, if any, are offered on this deal though. if there is no changes other than adding extra chips, im thinking $85-90 tops though.
edit: that is if there is no mode/ui changes or an extension tube… just added chips
