Keep an eye on Nitro’s thread, he’s trying to get Sink-Pad 16mm’s made.
Vestureofblood is selling the 20mm copper stars now, in XP-G and XM-L formats.
Fred turned a 20mm star down to 10mm for my build, so anything is possible!!
Oh, I forgot some nice data:
Taken from here: http://www.taschenlampen-forum.de/modding/13515-bastis-bastelbude-13.html#post296083
Testing of a copper star on Alu, Cu and Ms (brass) heatsinks. The material doesnt matter all that much at all..
Can you post the pictures here? I don’t have an account there.
Are these direct bonded copper stars?
Yes, copper bonded.
/edit: I fixed it.
I must not have been very clear. Obviously, more thermal mass will not take longer to cool down if it receives the same thermal input as an object of a lower thermal mass if they have the same surface area. That’s pretty pretty obvious. However, that’s not what I’m talking about. I’m talking what happens once the object has reached steady state equilibrium (ie. it’s temperature has stabilised), which obviously takes longer with objects of greater thermal mass as they can absorb more thermal energry. However, because they’ve absorbed more thermal energy, they have more thermal energy to dissipate once the heat source is removed. Like filling a bath vs. filling a sink. A bath holds more water, so it takes longer to fill up, but because it holds more water it takes longer to empty (the plug hole being the surface area of the housing in this case :laughing:. Pretty simple stuff.
As for thread surface area. Where is the force coming from to mate the metal surfaces together in your P60 drop in/ housing interface? How much metal is being forced into direct contact? Is the force perpendicular to the two surfaces or in shear? Unless your P60 drop in has an interference fit into your torch body (without any thermal gunk, wrap etc), such that you have to press it in with a vise or use differential expansion, then there is simply no way that it has more metal to metal contact than a threaded pill of the same depth. It is unlikely that it has much by way of direct metal to metal contact at all, perhaps a thin ring where the base of the pill hits the body tube or the reflector touches the bezel. The P60 format, AFAIK, was designed for filament lights that project most of their waste heat out the front of the light, not through the housing. If you wanted to design a light format from scratch to use with LEDs, there’s no way you’d choose a loose fit spring loaded format, you’d choose a threaded pill of a standard pitch.
Sorry Nightcrawl, but I never said anything about a C8 or it’s threads, and neither did the OP. My comments and the added pictures were to enforce what Matt was saying, to give ideas to skyrider as to how he might accomplish his goal. Not trying to start an argument, and you obviously know far more than I do about this subject, but to classify the incredible machining accomplishment of my lights head as “thingy” is pretty downgrading and not really called for in the least nor even vaguely appreciated.
Was just trying to help the OP with his ideas, which is what I thought this forum was all about.
And now, on to the regularly scheduled program.
Skyrider, tightly wrapping your P60 drop-in will most likely give you the result you’re looking for, without added copper mass in the pill. Going to that length would be more suitable for a larger light running multiple XM-L’s at higher amperage, with an accompanying larger head with better heat dispersal capabilities. That’s pretty much been aluded to here already. I have a triple Nichia 219 in a Solarforce L2P and it does very well, the entire body warms up but I haven’t run it for extended periods as I know it’s not great for the emitters and, as yet, have not needed this particular light for long illumination times. I have bigger lights for that, when that time comes. That being said, this Tri 219 is in a copper P60 drop in from EDC+ so it provides a larger mass for heat dispersal and the host does well removing that heat from the copper, with it being wrapped of course.
Good luck with your endeavor, still look forward to seeing how you go about your design.
matt, indeed, your explanation clarified what you meant. :)
My tightly wrapped P60 dropins have good heat transfer. They get warm as fast as my UF980L with a screw-in pill design. The force comes from a very tight fit..?^^
P60 has its disadvantages, but they are interchangeable. The C8 isnt, there are so many manufacturers and they dont all use the same threading..
DBC, you obviously didnt read matts post two posts over mine. Thats where he mentioned the C8 and thats what I answered to. Next you show some great threads (which have nothing to do with most crappy C8 threads at which my post was directed) and tell me there wont be much air inbetween, which is pretty obvious.
Thingy was not meant offensive, its just a neat small light. Neat thingy is a compliment in German. ;) I hope we will see a thread about your neat thingy once its done.
The EDC+ dropin is also a neat thing but no challenge for a P60 host. 2A is safe even for very long runs.
I did indeed read the initial reply from Matt, and understood your explanation as the why concerning C8 threads. Being fairly new to the forum, I have yet to master following multiple conversations within a thread and usually try to keep the OP in mind. Doesn’t help getting old and forgetful.
Y’all will definately see more on my “lil thingy” when it’s done. Looking for ~300 lumens or more from this pinky sized little dynamo, we’ll see how that works out.
And yes, the EDC+ is a bit on the conservative side. For some reason my DMM won’t get a Hi reading at the tail, but Med is 1A and Lo is .03A. Nice build, like what they did with the copper body and silver plating, very useful drop-in for some down-and-dirty illumination during macro photography. I plan on getting one that will be quite different, already have the host built, that Matt is working on over in Australia. I’m thinking it won’t be quite so tame, as he advised me to upgrade the switch in my host so it wouldn’t be melted down with his drop-in
Skyrider, are you looking for more output than you’re seeing in readily available drop-ins, or are you primarily interested in the DIY project?
I think the interchangeability is its biggest advantage, which also leads to another big advantage - the relatively loose tolerances manufacturers can get away with and it still manages to work. Given the difficulty manufacturers seem to have just getting the bore size right, I shudder to think what the outcome would be when you throw threading in there. I guess in the real world, ease/ cost of manufacture trumps all
DBC, yes, multiple conversations in one thread can be a downside in such a low-regulated forum like this. But I really enjoy it. Thats why I usually start my posts with the name of the one I'm adressing my post (or parts of it) at. :)
matt, yep, definitely. Even Solarforce hosts have different head IDs..
You stated in your first post that ” I will solder 3 very small pieces of rectangular pads on top for bonding the LEDs.” That won’t work, will it? The pads have to be isolated from the heatsink or they’d be a direct short. Soldering them in place isn’t an option, is it? Am I missing something here?
Edit: I see it now. Soldering a pad for the center of the emitter to be bonded directly through copper to the copper heatsink will raise the electrical connections and prevent the contact that I thought would short them out. Will you, then, connect the wires at the top of the emitter?
Solarforce is not consistent?
<—hand over mouth, frantically checking the 3 in front of me while worrying about the P1d the wife has.
I have an L2P and an L2T and they are off by a few tenths of a mm. Also, the inside of the L2T is not as smooth as the inside of the L2P.
The Nichia does not have solder pads on top btw. So if you want to raise it, soldering wires will be hard. I would rather use three 10mm stars. That would work.
Skyrider, I just got 20mm SinkPads and I’ll be attempting to turn some of them down. Will let you know how that goes. You’re looking for a single XM-L, correct? My main project here is an XP-G so I may just attempt the XM-L to 16mm and get a feel for it, before going for 10mm on the xp-g.
If I’m successful in turning down this XM-L copper star down to 16mm, you want it? I got 5 boards in XM-L and 10 for Nichia, XP-G.
Nightcrawl, anything I should know before I attempt resizing these?
Will be taking some pics first, I’ll post em a bit later.
Yes, copper is pretty hard to grind down compared to Aluminium. Dont let it get too hot.. and when you are done, check for connection between the center pad and the positive and negative pads with a DMM.
Thanks NightCrawl, I’m looking for there to not be a connection between the center pad and either led connection, is that correct? Making sure I haven’t shorted a lead against the board, right?
These can be seen in much higher res by clicking on the pic and then viewing the original in Flickr.
Just got back from class and looks like you guys had some good discussion going on haha. Ideally I wanted to start this build ASAP but will probably have to wait til may to start.
Yea, the idea is to raise the LED so I still have access to the bottom contacts. I’ll use a method mentioned in OLs thread about making stars to gain access to the contacts with copper pads.
Let me know how the turning down the 20mm star goes. Sounds like it could work out. I only worry about the +/- contacts making contact with the pill if I were to install it in the p60 drop in. Is it possible to grind off part of the outside of the contact so that it stays fairly physically isolated? Hold on to your sinkpads for now as you will probably have better use for it. Ideally I wanted to start this build ASAP but will probably have to wait til may to start and the 16mm sinkpads might be out by then.
I mainly want to make these builds because there isn’t a drop in currently that fits what I want.
For the XML I want:
- XML-2 T6 3C
- Direct copper bonding (reduce thermal sag)
For the triple:
- 3x nichia219
- triple driven with 1 amp to each led
- direct copper bond
Yes DBC, you wont want a short. ;) I hope you have a DMM.
I have grinded down a lot of PCBs until today and it is really easy. If you look closely at the boards you will see a thin "bump" connecting all the negative solder pads on the one side and all the positive solder pads on the other side. Thats just a trace with paint on it, so you can scrape off the paint and solder to the thin part.
Now if you want to grind down the board to 16mm for example, the edge will be right in the middle of the soldering pads. Thats usually no problem, but if it turns out to be a problem I use my dremel and a thin cutting disc to grind off the solder pad or trace. The dielectric underneath is a lot thicker, so its an easy operation.
Seems like an Xacto knife could be used to trim the pad back so that it would clear the edge, and/or a bevel put on the top side to also ensure no contact with the sides of the pill.
Now I am interested in some.
DBCstm, if you have the tools to turn it down could you do that for me? Send me a PM if you can with your paypal addy!
