Thanks for the review. Werner, I read on one of the specs of this box NOT to use protected cells, that it would damage the box.
There is no reason to use protected batteries with the box, the automatic disconnect works fine for that.
I have reason, becasue I have a lot protected cells way more than unprotected…
I can’t imagine how protected cells can damage the box…?
The only thing which “could” happen is that the cellcircuit has a higher low voltage protection than the box, but the box switch off at 2.9V.
And even that would do any real harm on the box or cells.
I agree, as long as you have the batteries and they fit, I cannot see any reason to not use them.
The voltage drop in the protection might make the box disconnect earlier, but that is not a big problem.
Would you supply us a link to the most promising one? Thanks.
Who supplying a link to what?
I tried to imagine why also, could they mean physical damage if they are too long?
Here is the link to the site that claims electrical damage will result. This type of box was asked about here on BLF before
Looking forward to that! :-)
2xTP4056 chip for charging?
No, look at the charge curve. You can also look that the large version of the PCB photos (Click on the small photo) and see if you can find a TP4056.
Thanks HKJ.
And not a single one with micro-USB input… quite a shame, considering that most electronics are moving to microUSB nowadays (phones, tablets, mp3 players, etc)
These ones have a micro USB charging input:
http://www.ebay.com/itm/170922299583
I just got mine, and seems to work as expected.
Will do a review upon request.
Cheers!
Will do a review upon request. Cheers!
Please
Shadowww:And not a single one with micro-USB input… quite a shame, considering that most electronics are moving to microUSB nowadays (phones, tablets, mp3 players, etc)
http://www.ebay.com/itm/170922299583I just got mine, and seems to work as expected.
Cheers!
Review requested
Added to my to-do list, cheers!
Looks like there are a couple of variants: “Round 5V input”:http://www.ebay.com/itm/280996213277 “MiniUSB input”:http://www.ebay.com/itm/181059058196
The one I tested has both round and mini usb input, but you are right, there is many different version of it.
Suncoaster:Looks like there are a couple of variants: Round 5V input MiniUSB input
All above box chargers are for 4 cells. May I suggest you HKJ to test something for 2 cells? For example this one:
http://www.fasttech.com/products/1421/10002784/1207400-enb-218650-li-ion-battery-usb-emergency-charger
HKJ: Suncoaster:Looks like there are a couple of variants: Round 5V input MiniUSB input
+1
That looks pretty cool and a bit more pocketable.
