hay matt, after the 9amp upgrade, is this light brighter than a skyray king now? do you know if this light is floodier than the king with the upgrade? if both of these were a yes, you can add me to the list now.
I don’t have a SRK unfortunately. The SL3 is my brightest light. All my other lights are p60’s or smaller.
Its very floody, but also has an intense hotspot, so throws well too.
it will be brighter than the skyray king, king only pushes around 2a per emitter…
ok, in that case, put me on that list as well
How much would the modded light be brighter than than a genuine SkyRay King?
Cheers!
Anyone know what board they use? Would it be possible to replace them with 16mm or 20mm SinkPads (and XM-L2 U2)? 8) If so I could be interested…. (sorry can’t give a definite at the moment)
around 600-750 lumens brighter
so around 25-30% more light
Sounds promising, thanks!
The 3 Led’s are mounted on a single large aluminium pcb.
List updated, thanks
You can count me in, too. I really, really like my SL3, and I’d like a brighter one even more.
3 more!!!
bump
and forgot my name on that list of interest too… just two more and we may see what materializes
I once had a JM26. It won’t accept a single flat-top KK 26650 without a magnet, and because of clearance problems, neither will it accept a KK raised-top, so I sold it.
Will this SL3, 9-amp version accept 2 protected 70mm 26650s ? (assuming a 2-cell battery tube is used)
I use a piece of copper tape folded over to make contact with a flat top 26650.
There is a small brass contact piece that needs to be a couple of mm longer, then a flat top would work.
18650 flat top cells fit though.
morning bump in hopes we can get the last two and get some details of whats to come
ok i’ll bite as long as price isnt astronomical
ok - 1 more!!!
