Test / Review: Fenix 18650 ARB-L2 2600mAh (Black)
13 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 min 50 sec ago
DSC_2127
Official specifications:
  • 2600mAh large capcity with outstanding performance
  • Triple overheat protection, safe and reliable
  • Built-in over charge, over discharge protection circuits
  • Circuit board has front and back protection for impact resistant
  • No memory effect, negligible self discharge
  • 3.6v 2600mAh
  • Size 18.5mm x68mm, weight 49g
  • Charging currect - Recommanded 1A, Max 2A
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-info
DSC_2121
DSC_2128 DSC_2129
The battery has a flat top, but due to the raised ring on the bottom it can be used in series.
DSC_2130
DSC_2131
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-Capacity
This battery has a high voltage at low loads and higher capacity than most other 2600 mAh rated batteries. There is also very good tracking between the batteries.
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-CapacityTimeHours
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-Energy
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-PowerLoadTime
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-TripCurrent
Fenix%2018650%20ARB-L2%202600mAh%20(Black)-Charge
Conclusion
The high voltage can be an advantage in smaller (i.e. 3-4 watt) lights where the battery replaces two CR123 cells.
With Fenix behind the battery I have no problem rating it as a good battery although it uses a unknown cell.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
jacktheclipper
jacktheclipper's picture
Last seen: 20 hours 36 min ago
Cool
What I do
Tecmo
Tecmo's picture
Wow look at that 5.0A draw test!  Too bad these are more expensive than some 3100 mAh batteries.  If they were closer in price to other 2600 mAh batteries they'd be a great deal.
kreisler
kreisler's picture
Last seen: 7 years 4 months ago
excellent discharge graphs, thanks for the tests!!
*FMI* i got 4 i/o sh
fishinfool
fishinfool's picture
Last seen: 1 year 9 months ago
Thanks for yet another great review HKJ!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
sb56637
sb56637's picture
Last seen: 19 hours 54 min ago
Thanks so much for another detailed review! Frontpage’d and Sticky’d.
malkoff junkie
malkoff junkie's picture
Last seen: 21 hours 21 min ago
i had these before and now moved over to AW.
i tend now not to buy from china & their chinese cells.
thanks.
Malkoff !
NightCrawl
Last seen: 5 years 1 month ago
Yeah, because AW are not made in China.. Party
These are good cells with a reputable company behind them.
malkoff junkie
hi thanks, but then how can they perform pretty good as a chinese cell then?.
in HKJ’s test they did fairly good.
does that mean they maybe got a good grade of cell from japan?, and even if it does, its still considered chinese?.
the company what makes the ARB L2 is “BAK”.
Malkoff !
NightCrawl
AW are assembled in China. 18650 cells are Sanyo/Panasonic, other sizes are made in China, some by DLG, some unknown. Maybe some of their cells are even made by BAK.. not everything made in China is crap.
What are you trying to say? These Fenix batteries made with chinese cells from BAK perform very well.
ri chevy
Any other places to buy this cell?
malkoff junkie
www.fenix-store.com
Malkoff !
ri chevy
Thank you.
