Thank you for the performance analysis and the temperature / lumens statistics.
Was really looking forward to your report.
Now, for a ton of light and extended use, the BTU is good with a conservative 10 to 15 mins on turbo and the rest on high. This is a 2000 + lumens light all the way until battery failure. Now, with a little tinkering, the BTU is set up for an even greater performance and greatness.
In the flashlight universe, rarely does a torch delivers both - massive throw and flood of over 2000 lumens all the way. The BTU is a truly living testament to all discerning owners and lovers of led flashlights.
Great job RDR. I am certainly impressed.
That slight current drop is good to know. Thanks for that little detail. So perhaps the light loses maybe 200 lumens or so due to heat and 200 lumens due to driver output dropping slightly.
I think a 200mA reduction across three LEDs would be quite close to 150-200 OTF lumens of loss (around 50 or so per emitter). The rest is likely heat sag. Since the driver sage is quite quick, one could compensate by jumping up to 4A drive, which would fall back to 3.8A within a minute.
I’ve been hunting around for one without much luck yet. Found one company, but they have a minimum of 25.
It would be nice of Ric would upgrade us, but I’m not going to dwell on it.
My U3 has been shipped by fasttech and my soldering iron is all sharpened up tinned and ready muahahahaha
I strongly suggest to stop using that fujic crap .scrap it out and use a thin coat of "silver thermal compound" or artic silver and similar cpu products .It will greatly increase heat transfer from the emmiter
so heres my upgrade FOR MY BTU asap to beat the tk75 now
1- change over to U3 for higher lumens----AVAILABLE-
2- Remove all cheap fujic crap and use expensive silver thermal compound for better heat Transfer. ---AVAILABLE
3- change lens to ar coated lens -? ----NOT AVAILABLE--cant find ...hoping Ric has answer to this
This has been and informative and very excellent thread. Thanks to all participants. Both of these lights have been on my short list for a while. I’m now thinking of going with the TK75 even though it’s $70 more .
I was looking at getting a BS Terminator, but having seen the TK in action, this, and another review with the TN31mb, where the TK75 was the only semi-flooder to touch the target, went with the TK.
It's my most expensive light to date, and I couldn't be happier. One of the three LEDs is a bit off center, but I don't think it's affecting much of anything.
I have a possible source for a lens. Give me a few days to hopefully get mine in and to check fit & etc. If all is good then I’ll post up details on it for others looking.
[/quote]
[/quote]
changed the led to xml u3 now and am satisfied with the btu output.got no light meter but i think its way above 3000 lumens .i can see the diffrence.I think 3 u3 driven at 3.8 amps should give around 3500 lumens???? ! AND I USED A SILVER ARTIC THERMAL PASTE . now the whole light feels warm within minutes on turbo .I guess that means heat is getting transferred from the leds better then what the fujic stuff did . iused the 20mm star since it was cheaper then the 16mm for some reason
bought the u3 from fasstech https://www.fasttech.com/products/1189702
Nice work Shaquille! That’s more like it. I might skip U3 though since I already have U2. Go straight to XM-L2 U2 on copper SinkPads. I just gotta pull the trigger on Emitters one of these days…
It would take a brave man and a very experienced modder to upgrade his TK75. I don’t think it would be that hard, but messing with such a well and high quality engineered light, with my ameteur modding skills it’s a no go for me….
I am seconds away from pulling the trigger on the BTU,anyone would be hard pressed to find a comparable preforming light at this price point.Thanks all for the input/beamshots,the emitter upgrade is an excellent option to have and seems easily done vs TK-75.
Should probably explain a little better. I probably could upgrade the TK75 without too much trouble, I just don’t want to get a scratch on it. Probably the only difference between modding either light is the TK75 has a fixed bezel. I’ve managed to remove fixed bezels in the past quite easily by carefully applying a bit of anti-adhesive gunk, it’s just that I have a habit of being quite rough when I mod my lights.
Just read the whole thread, he he. Seems we flashaholics are quite passionate about our lights, I’m no different and quite obviously a TK75 owner. :bigsmile:
