hi thanks very much.
would a “Panasonic Protected NCR18650A Rechargeable 3100mAh 3.7V 18650 Lithium Battery” fit the M1 ?.
might order a pair along with the M1 7C tint.
Quick question. I just bought this M1: Convoy M1 Cree XM-L U2-1B 2-Group 3/5-Mode 350LM LED Flashlight (1 x 18650 / AMC7135*8 / HA-III). On specs it says rated 350LM, while others T6-3C, T4-7C, T5-5C that are also AMC7135*8 are rated 700LM on the Fasttech website. Did I just purchase the wrong one?
If so then you could just buy one light and build a pill to swap in to it you wanted. That way you could choose different tints or brightness bins or upgrade the light when newer and better things come out without loosing the option to go back to the old one.
Thanks, bud! As to that pill you linked to I’d say no. That sucker is 30mm in diameter (according to their specs) and made for a 26650 light. The entire head on the M1 is only 35mm. Good idea though but no way will it fit.
If they will send me one I’d be happy to. A little too much $$ for me to spend on my own for a light that would redundant with some I already have. I did ask them to send me one originally but it was too pricey for them to send for a review. If I can work a good discount deal with them so it won’t be too much OOP I can make it happen. Maybe they will read this and reconsider. I will try though since the C8 looks like a fantastic light and a far better light of that size than a stock/modded Maglite.
