Emitter Test Results pt4: XML2, XP-E2, XP-G2, and Nichia219! (along with sinkpad tests)
99 posts / 0 new
Match
Match's picture
Last seen: 5 years 5 months ago
Folks,
  Long time no see...  Since most of you are now aware of my testing procedure, I'll be brief here.  The following is a test of the Cree XML2 on a standard aluminum 20mm star, along with another xml2 mounted on a copper sinkpad. (member vestureofblood was kind enough to send me out these for testing).
Graphs speak louder than words, so here they are.  The first one is the XML2 on a standard star, followed by a comparison graph between a standard aluminum star and a copper sinkpad.  The third represents the associated vf of each.
 There you have it.   Max lumens on regular aluminum star came out to 1259, while it was 1770 for the sinkpad ( at much higher current).  The sinkpads do well at dissipating the heat - During an extended run at 5 amps, lumens only dropped by 50 before stabilizing out.  Also, while the output is quite impressive for the copper mounted XML2 (and xml2's in general), please note that there's a good chance max lumens won't be realized on a single li-ion due to the high vf.
UPDATE 3/10/2013
The last round of tests are complete and the data has been collected.  Here, we'll see graphs for the XP-E2, XP-G2, and Nichia219. The two Cree's have been tested on a standard aluminum star and on a copper sinkpad, and the graphs will reflect that data.
There you have it. I'll let the data speak for itself, but suffice to say that with the availability of these sinkpads, I've milled my last copper pcb.  I did get a chance to do a direct comparison between the same emitter (XPG2) directly mounted to a large milled copper pcb and then on a sinkpad.  The difference between the two was anywhere from 5-10 lumens in favor of the milled pcb.  Not enough difference to be noticeable in anything less than an integrating sphere, much less real world use (and definitely not worth the added effort).
  My final addition to this emitter testing Opus will be to make one large graph with all of the new emitters present for easy comparison.  After that, I'll be retiring my testing setup for it's a big pita and I'm finding I don't enjoy it as much as I used to.
Enjoy the data,
-Match
Edited by: Match on 04/05/2013 - 06:48
scaru
scaru's picture
Last seen: 4 years 9 months ago
Great work Match, so now it looks like the vf of the XM-L2 is very similar to that of the Nichia 219. Sad
DARCANGEL
DARCANGEL's picture
Thanks Match,I love these "where the rubber hits the road" tests.The sinkpad really makes a difference and is clearly the winner over the aluminum mcpcb.It seems XML-2 is best suited in a multiple cell configuration because of the higher vf.Very valuable info for modders,and out of curiosity what is the bin of XML-2 in this test?
texaspyro
Last seen: 2 years 2 months ago
Yes, but isn’t Match is sinking copper to big chunk ‘o copper? Results would be less spectacular if the copper sinkpad was sinking to a chunk ‘o aluminium like in most flashlight bodies.
moderator007
moderator007's picture
Last seen: 6 months 5 days ago
Thanks for the valuable information Match.
I guess amc7135 drivers are out at high currents. The battery wouldn’t be able to stay above vf of the led and the .12v overhead for the amc7135’s, at least not for very long anyways.
Pok
Pok's picture
Last seen: 2 years 1 month ago
Great work and Thank You Match Smile
Pulsar
Pulsar's picture
Last seen: 3 weeks 4 days ago
Thanks match, been waiting for a test on these.
Would the higher vf on these be accounting for the 2.25a draw using a 3.5a driver? Or is there something else coming in to play here?
Thanks again, your tests are invaluable to us here
MRsDNF
MRsDNF's picture
Last seen: 1 month 6 days ago
Thanks for the testing match. Interesting results.
moderator007
Are you using a single cell driver?
And if so, what battery are using?
Update: Pulsar I found your thread with the mag, I’ll take the discussion there.
apt323
apt323's picture
Last seen: 1 month 4 days ago
Great information as usual, thanks!
Slim Pickens
Slim Pickens's picture
Last seen: 47 min 8 sec ago
Sweet mother of pearl. As always—a big “thank you” for the data, match! I’m looking forward to how the XP-E2 fares. Will it have a higher Vf than its predecessor, like the XM-L sequel? Or will it be notably lower like XP-G2 vs. G1?
I know. It looks like high currents will call for 4xNiMH in a Mag. All the better for heatsinking, at least.
On the upside, the XM-L2 hovers around 62 lumens/watt at nearly thirty watts, >1.5A/mm^2, and delivers >400 lumens/mm^2. That’s crazy!
relic38
relic38's picture
Last seen: 3 years 8 months ago
Excellent work Match! This puts my ‘XM-L2 on copper SinkPads BTU Shocker’ mod very high on my list Wink
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
PilotPTK
Last seen: 7 years 7 months ago
Pretty Awesome that you can see the increase in Vf (roughly 0.15V at 3.0A) with the emitter on the Copper vs the emitter on the Aluminum. This is almost certainly attributed to the lower operating temperature of the emitter on the copper. Some of the difference, however, is likely just emitter to emitter variation. I’d love to see what the difference in the Vf to Current curve would look like for the same emitter soldered to an Al vs. Cu star.
You should, in fact, be able to work backward and figure out what the actual die temperature difference is between Al and Cu. It’s easy to calculate – 1.6mV difference per degree C.
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
Slim Pickens
PPtk
+1
I agree; Sinkpad’s design is definitely doing it’s job! I’m impressed.
RaceR86
RaceR86's picture
Last seen: 5 years 6 months ago
Thanks for sharing..
This is how I would rate the upgrade by looking at your graph.
Up to 1,5amp, no difference
1,5-2,5 minimal difference
2,5-3,0 some difference, about 10% at 3A – or 100 lumen gained compared to aluminium.
3,0-4,0 defiantly some gains. Especially when getting close to 4A. About 200 lumen gained compared to aluminium star @4A. Or 15% increase.
4-6, huge gains
1500+ lumens @ 5A. NICE!
But, gains are mostly when having high vf.
Can someone explain to me how real life gains would be when using a 4-5 amp driver and only 1 li-ion like a Panasonic NCR18650B Protected in combination with a linear driver… Would there actually be any gains at all?
Using one protected 18650 in combination with a boost driver, would there be any issues?
If using only one battery, I am assuming larger , low resistance, no protection would be helpful. But pushing 5A for some time would not be realistic even with one “high ouput” 26650, or??
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
rdrfronty
Last seen: 6 months 3 weeks ago
Exactly my plans. Got all my parts ordered. Just have to wait for these dang XM-l2’s to eventually come in.
And thanks match for the awesome tests!
PilotPTK
Even the best 18650’s aren’t going to push the XM-L2 harder than about 3.6 to 3.8 Amps on a linear or switching buck driver.
moderator007
And even if it does make that suggested current it would not stay there very long maybe a couple of minutes at best. A IMR cell would probably stand the best chance at it. Possibly 8 to 10 min judging by HKJ’s IMR graph.
PilotPTK
Yep, the XM-L2 really wants two LiIon cells and a buck driver. That would be ideal.
PPtk
RaceR86
RaceR86's picture
moderator007 wrote:
And even it does make that suggested current it would not stay there very long maybe a couple of minutes at best. A IMR cell would probably stand the best chance at it. Possibly 8 to 10 min judging by HKJ’s IMR graph.
I had a feeling that would be the case..
AlexGT
AlexGT's picture
Last seen: 8 hours 30 min ago
Thank you for the analysis Match, What bin were the XM-L2? Tint? Where did you purchase them?
Thanks!
nofearek9
nofearek9's picture
thanks for the test,sinkpads do great job.
bibihang
bibihang's picture
Last seen: 1 day 5 hours ago
Thanks Match. Now I just need to know where can I get those XM-L2 on sinkpad Sad
ergotelis
excellent work Match, thanks!
Particularly this Vf graph is neccesary for a good mod! I was expecting the lumen results but i was a bit surprised from the Vf graph. Do you have any xm-l for comparison? THanks!
bdiddle
Last seen: 2 months 2 days ago
What bin is that XM-L2?
Newb
georgek
very nice work.. thank you very much..!!!
I also need to know where to get xm-l2…
NightCrawl
texaspyro wrote:
Yes, but isn't Match is sinking copper to big chunk 'o copper? Results would be less spectacular if the copper sinkpad was sinking to a chunk 'o aluminium like in most flashlight bodies.
Yes he is. But the difference is not that big, see here:
Taken from here: http://www.taschenlampen-forum.de/modding/13515-bastis-bastelbude-13.htm...
Testing of a copper star on Alu, Cu and Ms (brass) heatsinks.
Thank you for the test Match. Nichia 219 in sight? Big Smile
ImA4Wheelr
Last seen: 1 week 1 hour ago
Great info. Thank you Match!
So it appears that even running multiple healthy parallel cells wouldn’t run very long at 5A. Guess one needs to consider getting the equipment needed to measure capacity and rate of discharge if they want to push an XML2 hard.
dchomak
Last seen: 3 years 2 months ago
I would love to see the difference with sinkpad to aluminum. This difference was talked about elsewhere. It would really be good to KNOW what that difference would be. Remember the heat capacity of aluminum is about twice that of copper, even though the thermal conductivity is about half. Sinkpad to Aluminum is the practical construction technique, lets see how effective it would be.
Thanks for doing the measurements.
dthrckt
dthrckt's picture
Last seen: 3 hours 11 min ago
WOW!
Thanks for doing those tests.
Tom E
Tom E's picture
Last seen: 1 hour 32 min ago
Thanks Match!! This confirms what I've been seeing in the few XM-L2/SinkPAD builds I did and posted about. I ordered a Small Sun ZY-T08 exactly because of the 2 parallel battery configuration - perfect for a hot XM-L2/SinkPAD/Nanjg 3.85A or 4.2A setup.
 Also, these results don't mean you won't see much of an advantage from single cell applications - even at lower measured amps, results are impressive over XML U3's on aluminum. I've also seen outstanding results with an XML U3 on a SinkPAD and having the same high Vf issue with that, so it's not so much an advantage of the XM-L2, it's the SinkPAD's advantage. For single cell applications, switching to lower resistance batteries directly results in higher amps, higher measured lumens/throw - I've done this on a few lights by testing with an AW IMR 2000 mah.
 So, I'm seeing greater gains with a SinkPAD upgrade than upgrading to an XM-L2 emitter only, so, Match's results seem to confirm this. I'm not saying XM-L2's have no merit - they do with efficiency, and with equal bin, equal tint, they should do better than an XML, but unfortunately the best/brightest available XML emitter is a U3 1A/1B/1C, while the best/brightest XM-L2 is U2 1A/1C now, and I've only used XM-L2 U2 1C's and XM-L2 T6 3C's up til now.
