excellent work Match, thanks!
Particularly this Vf graph is neccesary for a good mod! I was expecting the lumen results but i was a bit surprised from the Vf graph. Do you have any xm-l for comparison? THanks!
So it appears that even running multiple healthy parallel cells wouldn’t run very long at 5A. Guess one needs to consider getting the equipment needed to measure capacity and rate of discharge if they want to push an XML2 hard.
I would love to see the difference with sinkpad to aluminum. This difference was talked about elsewhere. It would really be good to KNOW what that difference would be. Remember the heat capacity of aluminum is about twice that of copper, even though the thermal conductivity is about half. Sinkpad to Aluminum is the practical construction technique, lets see how effective it would be.
Thanks Match!! This confirms what I've been seeing in the few XM-L2/SinkPAD builds I did and posted about. I ordered a Small Sun ZY-T08 exactly because of the 2 parallel battery configuration - perfect for a hot XM-L2/SinkPAD/Nanjg 3.85A or 4.2A setup.
Also, these results don't mean you won't see much of an advantage from single cell applications - even at lower measured amps, results are impressive over XML U3's on aluminum. I've also seen outstanding results with an XML U3 on a SinkPAD and having the same high Vf issue with that, so it's not so much an advantage of the XM-L2, it's the SinkPAD's advantage. For single cell applications, switching to lower resistance batteries directly results in higher amps, higher measured lumens/throw - I've done this on a few lights by testing with an AW IMR 2000 mah.
So, I'm seeing greater gains with a SinkPAD upgrade than upgrading to an XM-L2 emitter only, so, Match's results seem to confirm this. I'm not saying XM-L2's have no merit - they do with efficiency, and with equal bin, equal tint, they should do better than an XML, but unfortunately the best/brightest available XML emitter is a U3 1A/1B/1C, while the best/brightest XM-L2 is U2 1A/1C now, and I've only used XM-L2 U2 1C's and XM-L2 T6 3C's up til now.
That’s right, I am not saying Aluminum is better, I am saying that it is more practical, therefore for most applications it is what will be used. So it would be good to know how it performs when mated with the copper sinkpad. I suspect it wouldn’t do that much worse than copper all the way. If it is only a few percent difference, then that would be great. The thermal path from the junction of the LED to the back side of the copper sinkpad is the most critical part. The further away you get from the LED, the less important thermal conductivity becomes because the cross sectional area is greatly increased. It would be really good to know how Aluminum performs past the copper sinkpad.
MT-G2's are great for flood, haven't seen/heard of a good throw setup with one yet. What relic38 and rdrfronty are thinking about with the BTU is potentially one of the best applications of the XM-L2/SinkPAD's
