Yes, 88,000 is what I came up with as well. You should see it in person..LOL. I'll do the SR King in a few minutes for you. I think you'll see much lower readings, so something much more in line.
Hi, can you please tell me how many amps do you read with 2 or 3 MNKE cells bei AK-47 stock driver? Maybe I’ll buy also MNKE cells. And I couldn’t find on internet a KD 9x driver. Can you please post a link where I can buy this driver? And one more thing, how do you pull out the old driver; it seems to be stuck there. Thanks!
note that they’ve changed the photo and that is NOT what the the top board looks like - it is much taller because the toroid is vertical and there is a big cylindrical component (capacitor?).
Thanks for the links. I think that the measurements in that comment are made with Trustfire cells; I was interested if there’s a difference with MNKE IMR Unprotected cells on the AK-47 stock driver. Thanks
I went through my notes and surprisingly didn't find the answer, so I temporarily tossed the stock driver (which is great) back into the Trustfire AK-47 so I can give you the correct answer on this one.
Additionally, if you install the KD driver in this light, Trustfire 5000mAh cells will NOT work. You may be able to
get the light to come on as far as MED mode, if you're lucky, but the light is undependable with the KD driver and Trustfire 26650 cells.
I'm hoping the ENERPOWER+ Protected 26650 4500 mAh (Tensai) PCB 9A cells will be able to smoke the Trustfires. The Enerpower cells are coming to me with a 9a protection circuit, and apparently not the 8a I've seen. I'll assume they'll be fine with more capacity too. I'll post when I have the cells in hand.
Zeus, I purchased it from the same vendor Old-Lumens purchased from, this ebay seller linked below. He also has various other sizes and types, so if you require something different, check his other auctions.
Just found another great set of 26650 cells that I had shipped in from Germany 7 days ago. Just charged up these EnerPower 4500mAh protected cells to 4.2v each. Tossed three in, the light came on super bright with a tail cap current at 8.14 amps. They effortlessly powered this modified Trustfire AK-47 with a KD driver installed as easily as the MNKE unprotected cells have. Remember, this is a 90 watt flashlight now. I’ve never seen 26650 protected cells with this much power before and it won’t be cheap for this type of quality cell.
Yep, my Trustfire 26650’s are great cells, but this particular flashlight, pushing this much power is beyond their output rating, but have been great in every other light I have.
I’m sure these new cells will be about $5.00 more per cells than the MNKE cells, but it’s nice to have choices when it comes to high output and quality cells that will keep performing. As soon as my hobby charger arrives, I’ll be able to check these new cells out indepth.
Super cells they are. Thanks for all the measurements. Can you please tell me how to pull out the driver from ak-47? Must I unscrew the driver or take it out by force? Thanks!
You unscrew the top retaining ring. You’ll need either needle nose plyers, or snap ring removers and press them into the 2 holes and twist. If you don’t have either of those, try to get the ring out by using two nails in those holes.
Once the ring is removed, the driver should lift out. If it appears stuck, try and carefully lift it from one side if you can get something sharp under one side of it. The driver itself is not screwed in, it just sits in the seat.
That’s a great question. I’ve been using the stock Omten 1.5a 250v PBS-101 switch it came with. In fact, I’m looking into purchasing a few spares or see about retrofitting a Jabsco (spelling?) The Jabsco switches I’ve seen have wires, so I’d have to figure out how to remove the wires so it installs and functions as the stock switch, perhaps allow some extra power to get to the LED’s as well.
Tested the light with 18650’s this time to see how they handle the power of the KD driver.
Using Redilast 2600mAh cells fully charged, just as the light came onto medium mode, about 4.85 amps, one cell tripped it’s protection.
Removed them and tossed in 3 Redilast 3100mAh cells, the light worked on all modes. On high, tail current was only slightly low at 7.85 amps. I left the light on high for about a minute with no problems.
Looks like there seems to be a problem with these AK-47’s that I had hoped would have been an incorrect assumption on my part from my original post.
I’ve got a second AK-47 in my hands that I’m upgrading for a forum member with the KD driver. All is fine with the light physically and is mint, but the stock driver I removed not only had one of the 3 resistors off, it was actually missing having never been installed.
Without this 3rd resistor, this has the effect of not allowing the light to push more than about 3 amps at the tail cap on high mode with 3 cells. With the resistor in place, the stock driver would pull well past 5 amps despending on how good the cells are.
At least the one I purchased recently, the 3rd resistor was present, just not soldered on sufficiently, so it was an easy fix. The one I’m working on now will have a 5-mode KD driver installed within the hour and pull over 8 amps at the tail on high mode with 3 MNKE cells in it. So this one will light up Broadway.
Sorry to give the bad news, but if you upgrade the driver, it’s simply a wall of light.
I don’t have a spare R820 resistor the stock driver is missing. But the member is allowing me to keep it as a spare, so I’m going to see about getting some. My wife loved the output of my light, I ended up placing an order for the last AK-47 that Amazon dealer had on hand, so it looks like I’m going to have to fix a third one.
She wants to use it in a 2 cell configuration because it’s pretty compact, so that’s fine. I also have some KD 3-mode drivers on order, so I’ll be able to get the power level up to what I feel it should be.
I just receied my multimeter. By the tailcap I got 3.2a falling out quickly. In the stock driver are just 2 resistors, one is completely missing, and I thought this is a powerfull flashlight. I ordered immediately 3 Enerpower 26650 cells and a KD 3-mode driver. I can’t wait to blind myself;) I’m so thankful for all the information I got here. Thanks!
