Photon Fanatic Build, Ti Neck Light (Pic Heavy) *8-5-14 Upgrade*
88 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 6 days 14 hours ago
——-8-5-14 Upgrade to the Texas Poker…check it out! I put an XP-L in this lil guy and gained over 300 lumens! It was drawing 3.11A making 552 OTF with the de-domed XP-G2 I put in it with the BLFTiny10 FET driver. Now, same driver, it’s pulling 3.20A and making 873 lumens OTF! WooHoo!!!——-
Hey everybody, thought I’d share some pics of my new light that Photon Fanatic is completing. This is a pet project, done with a 1” bar of Grade 23 Surgical Grade Titanium that I’ve had for over 13 years. Finally figured out what I wanted to do with this bar, thanks in part to the Forum. Wink So I tried to apply some of what I’ve been learning here in the last couple of months (stuff missed out on at CPF by the way) and designed my own little rocket. Based on either a Cree XP-G S2 in 5700K or a Nichia 219 in 5000K, with a driver custom designed by Matt Wright out of Australia and being programmed in Germany, the hold-up to this light’s completion, the driver will push 1.2A for something in the neighborhood of ~300+ lumens on hi, with regulation and overheat protection as well as over-discharge protection. That’s the plan, anyway.
I have always like the look of Leupold rifle scopes, so based on the bore end of a scope, I submitted my idea to Fred Pilon for this build. Fred uses an old Swiss manual lathe and uses it well. He also designs in Solid Works and has stuck by the design perfectly. The design calls for a large heatsink in copper, as the Ti doesn’t remove heat well…with this in mind external ribs from the heat sink were designed as a solid piece that pretty much fills the Ti head. The bezel screws onto the sink, the copper pill screws into it from below, and the battery tube screws into the base of the head. Making this a twisty for simplicity, the 3 modes should be easily accessible.
Bear with me, this is a first for me in more ways than one….
Texas Poker_WIP-1
.5mm threads anyone? This pitch is used throughout. I have a sample of these in a Ti pill bottle made from the remains of this 1” bar and they’re smooth as butter.
Texas Poker_WIP-2
Boring out the pill area after the outer threads for the ramp portion of the lower head,
Texas Poker_WIP-3
Did I mention Fred like’s a challenge?
Texas Poker_WIP-4
Creating the exposed ribs for heat dispersal. Whether or not this works, it’s sure got a nice aesthetic!
Texas Poker_WIP-6
The reflector area, bored, countered, ready for the reflector and lens.
Texas Poker_WIP-7
The copper heatsink, with quite a bit of work in this one tiny piece. Art! Gotta love it! I figure those threads are just a little thicker than my thumbnail.
Texas Poker_WIP-9
So we’re all good? Nobody wants to see anymore?
I have no idea how all this works, so I’m going to break it up in sections. Consider this phase 1.
Edited by: DB Custom on 08/05/2014 - 19:26
DB Custom
DB Custom's picture
Phase 2
Many years ago I made 3 rings from this bar, you see how rough the ends were when I sent it to Fred. I had almost zilch for tools, cut it with a hacksaw. That took some doing!
Texas Poker_WIP-11
Fred sqaured it off, turned it down for the bezel, and started the tedious process of boring out and countersetting all the tiny details. Have I mentioned the outer diameter is 20mm on the head? The overall light will be about 3” long, with a 13.25mm battery tube. Getting some idea of scale?
Texas Poker_WIP-14
Threads on the bezel, for attaching to the heat sink.
Texas Poker_WIP-15
The heatsink, threaded into the bezel. Perfect fit. Fred’s lines are genious!
Texas Poker_WIP-17
Opening up the lens area of the bezel. Very small work here as well.
Texas Poker_WIP-18
Flip the bar, on to the battery tube. More hacksaw results here, from Y2K.
Texas Poker_WIP-19
Squared up and bored for the 10440 cell, now the boring work of stock removal.
Texas Poker_WIP-20
Making Ti twistys, the time consuming way.
Texas Poker_WIP-21
Step back to the bezel for a look at it’s fit on the heatsink.
Texas Poker_WIP-22
Nice!
Texas Poker_WIP-23
So this will wind up phase 2
DB Custom
DB Custom's picture
Phase 3
Now some seemingly simple stuff, right?
Texas Poker_WIP-24
Now that the end of the tube is prepared, it’s time for more threads!
Texas Poker_WIP-26
So now let’s make the back end of the head, in preparation for the battery tube.
Texas Poker_WIP-27
Turned down and bored, ready for yet more threading! There’s 5 pieces of machining on this light, with 8 areas of threading!!
Texas Poker_WIP-29
Ready to see if the battery tube fits?
Texas Poker_WIP-30
Starting to look like a glorified tire thumper, but look at the fit….nice work Fred!
Texas Poker_WIP-31
The 1” bar held in the lathe, with the cutting tool set on an angle to cut the taper for the head to join up with the battery tube. Tedious stuff again.
Texas Poker_WIP-32
Another nerve wracking moment, parting off a piece you’ve got a lot of time on. Once again, perfection!
Texas Poker_WIP-34
The shape of the Texas Poker. The tapered portion will be reduced further to meet the copper heatsink and the battery tube will get some more work as well.
Texas Poker_WIP-35
So it’s time to get the pill area cut out of the lower head. For me, every step get’s more nerve wracking with all the time involved. Don’t know how you guys do this!
Texas Poker_WIP-36
Piece o cake! Love how that fresh copper looks against this dark Titanium. Wow oh wow!
Texas Poker_WIP-38
So here’s the head, bezel mounted, heatsink inside and man what a work of art! On a tiny little flashlight dreamed of for a decade.
Texas Poker_WIP-39
As Fred said when he got to this part , “What’s to say?”
Texas Poker_WIP-40
Texas Poker_WIP-41
Texas Poker_WIP-42
And moving out of this headed for the last phase…
DB Custom
DB Custom's picture
Phase 4
Boring the tail for my 3.8mm Ti curb chain. This is a neck light after all.
Texas Poker_WIP-46
A live shot of the tail being tapered, Ti flying, how in the world does he do this and get pictures too?
Texas Poker_WIP-47
Perhaps I failed to mention that Fred went down inside the battery tube and cut a raised bump at the bottom, to ensure contact with cells that had wrap around the edges, and now on the outer end, cutting this little mole nose ….I’d be scared all over again to get inside the already tedious little tube.
Texas Poker_WIP-48
Essentially, the work is done. A few cosmetic touches and some work on the pill and star board. But here stands the Texas Poker.
Texas Poker_WIP-53
Star cut down from 20mm on the bottom to 10mm on top. This is a XP-G S2 5700-6100K found at LED-tech in Germany. Got 4 of em just in case Wink
Texas Poker_WIP-54
Trace removed, ready to go into the pill.
Texas Poker_WIP-55
Fit’s the pill like a glove. I swear I can’t figure how he gets those lines so dang tight!
Texas Poker_WIP-56
Cosmetics on the head, the last of the machinework save for boring the pill for the driver. Which will be done when the driver arrives.
Texas Poker_WIP-57
So, here she is, a final polish to make her gleam when all is done and she’ll be coming from Mass to Texas! YiHaa! Smile
Texas Poker_WIP-58
Texas Poker_WIP-59
Thanks for watching! Hope you enjoyed the amazing show that Fred Pilon, known as Photon Fanatic, put on for me with his camera while working magic on an old Swiss manual lathe. Sheer genius and worth every dime! Thanks Fred! Smile
EDIT-New Photos: These are the last of the pics from Fred, he dropped the light in the mail this afternoon! Smile
Boring the heat sink for the reflector, a Dereelight orange peel aluminum unit
Texas Poker_WIP-60
And here’s the reflector, nice and beefy with a reinforcing ring around the top…good for heat sinking too Wink
Texas Poker_WIP-61
Perfect fit! But of course it is, Freds the conductor on this trip!
Texas Poker_WIP-62
Ah, a thing of beauty! As near perfectly matched as any I’ve seen, this should really make a nice beam!
Texas Poker_WIP-63
And here’s the pill to go into the heatsink, keep in mind that little bad boy is only about a half inch in diameter!
Texas Poker_WIP-64
And in the next few days, I’ll be taking my own pictures! This has really been an incredible experience, Thank You Fred for an amazing ride!
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
That is absolutely the beginnings of a work of art. You must have friends in high places with parts built here and there and modded over yonder. Half a mm thread pitch is so small. For those not into metric the distance from the top of one thread to the top of the next is twenty thousandths of an inch. This is very detailed work. Keep those pictures coming. Thanks for sharing.
Pulsar
Pulsar's picture
Last seen: 1 month 5 hours ago
yes. i cant wait to see more. i love titanium
bushwhacked
bushwhacked's picture
Last seen: 6 years 2 months ago
Those two pieces look like one with different colors, amazing.
P60dropins.com (just a redirect for now)
DB Custom
DB Custom's picture
Where you meet a few people and things start falling in place. Nice people. Helpful people. And they’re movers and shakers and I got lucky. That doesn’t happen to me real often, and I really really appreciate it when it does!
Who said it? “I Love it when a plan comes together!” Smile
So do I.
Pulsar
Pulsar's picture
So do I.
congrats, puts my custom light to shame! haha…
that thing is a piece of jewelry
DB Custom
DB Custom's picture
I’m tellin ya, Fred’s a genious on that lathe of his! He’s got some works that are just drop dead gorgeous and look impossible to do. And manually. Don’t know how he does it. Wish I could!
Hey, y’all see my post count climbing over there? Don’t even think about seeing this light when it hit’s 1000!! ROFLMAO
JohnnyMac
JohnnyMac's picture
Last seen: 2 weeks 1 day ago
i said it before and I'll say it again, simply amazing!!
MRsDNF
MRsDNF's picture
DBCstm wrote:
I'm tellin ya, Fred's a genious on that lathe of his! He's got some works that are just drop dead gorgeous and look impossible to do. And manually. Don't know how he does it. Wish I could! Hey, y'all see my post count climbing over there? Don't even think about seeing this light when it hit's 1000!! ROFLMAO
Who said anything about giving it away for 1000 post's posted. 500 post giveaway would be a lot better. I'm the first entry. Hope I win this thing. Simply orsm and thanks for such an amazing giveaway.
Pulsar
Pulsar's picture
MRsDNF wrote:
DBCstm wrote:
I’m tellin ya, Fred’s a genious on that lathe of his! He’s got some works that are just drop dead gorgeous and look impossible to do. And manually. Don’t know how he does it. Wish I could! Hey, y’all see my post count climbing over there? Don’t even think about seeing this light when it hit’s 1000!! ROFLMAO
Who said anything about giving it away for 1000 post’s posted. 500 post giveaway would be a lot better. I’m the first entry. Hope I win this thing. Simply orsm and thanks for such an amazing giveaway.
i like the way you think Wink
DB Custom
DB Custom's picture
Looking to change the rules eh? You really do have a horrible memory! Don’t even think about it, means it just ain’t gonna happen! Silly Smile
But swim over here through Midland and don’t get blown up at Ft.Hood and we’ll talk Wink
Very exciting time for me, the closest I’ve ever come to “commissioning” a successful build on something was a few holes poked in the top of a gun barrel with a window in the slide over it for competition shooting with a Glock .40 cal. That was before Glock started doing it, and it worked very well. 4 holes and a slot. Nothing like this at all!
Some of y’all will like the idea of this. Know how I happened upon Fred? I was talking with Matt, the designer of the driver, about a build he’s doing for a kick-a** P60 drop-in that’s not quite done. He had mentioned making a new light with a bigger head to have cooling fins and I’m sitting here looking at this big 2 1/2” diameter chunk of Titanium, sitting on my shelf like a big heat sink that there’s never gonna be any way I can do anything with it, too big! So I ask him what I could do with it, kind of offhand like, make a flashlight head? He say’s, “Give it to Fred, see what he can do with it” I contacted Photon Fanatic in a PM and gave him the chunk of Ti. Payed it forward if you will. And that’s how I found out what Fred does and ended up commissioning him to do this light with another piece of the same grade of Ti that I also had.
Ironic, isn’t it? When you’re finally willing to give something away look what can come back at ya? Smile
Edit for clarification purposes: Fred works for money.
jacktheclipper
jacktheclipper's picture
Last seen: 3 hours 37 min ago
That is the most exquisite tiny light I have ever seen .
UN . BE . LIEVABLE .
BRAVO !
What I do
SashiX
SashiX's picture
Last seen: 7 years 5 months ago
Howly cow Shocked Thanks God you have used Canon EOS for this work, those shots are simply gorgeous!!! Love
DB Custom
DB Custom's picture
Thanks for the compliments, really means a lot to me. I can’t, however, take credit for the pictures as they are Fred’s from his 30D and 100mm macro. Nice photo’s though, to be sure. Smile
I’ll take some stacked macro’s when I get the light, with my 5DMkII or 1DsMkII, see if we can show a bit more of his fine detail work! Wink
DB Custom
DB Custom's picture
In doing all this posting and writing the description something occurred to me. Now I don’t know if Fred planned it this way or not, but…the V-Grooves in the head, the wider portion of groove that breaks over the ridge, that is almost exactly the position of the emitter in the center of this lil jewel! Almost like the tines on a physical torch that surround the flame, I really like that visual and once again I have to be amazed at the creative artistry that is Photon Fanatic!
Having made rings from this Ti in the past, I know that the tiny bezel detached from the light is near weightless…one of the things that’s always drawn me to Titanium, the piece is just difficult to believe even when holding it in your own hand, mind boggling compared to like items. I just can’t wait to have this light in my hands! Smile
gords1001
gords1001's picture
Last seen: 3 years 3 months ago
That is just quite frankly jaw droppingly gorgeous. Congratulations.
And severe thumbs up to fred. He is without a doubt a master of the old school.
Cannot wait to see this finished, please keep us updated.
ruffles
ruffles's picture
Last seen: 2 weeks 2 days ago
Everything was looking pretty amazing through the build, until the end.
Then you turned the awesome-meter past 11 with those grooves on the head.
MRsDNF
MRsDNF's picture
ruffles wrote:
Everything was looking pretty amazing through the build, until the end. Then you turned the _awesome-meter_ past 11 with those grooves on the head.
ruffles. You are certainly a hard task master. It started of at 12 for me and went to a 15 (out of 10).
Rufusbduck
Rufusbduck's picture
Last seen: 5 months 3 days ago
Nothing to say, nothing to add. Just posting out of wonder.
Scott
DB Custom
DB Custom's picture
Here’s a bonus, the last of the Ti bar. Fred made a pill fob for my wife by my request in order to use the rest of the 1” bar. This series of pictures you can thank MRsDNF for, enjoy!
Photon Fanatic Pill Fob Collage
Chicago X
Chicago X's picture
Last seen: 8 years 2 months ago
[Thud!]
That was the sound of my jaw hitting the floor.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
DB Custom
DB Custom's picture
It took 100+ pictures to make those 7! That collage is actually 16×24 at 300dpi, click it and go to Flicker to see it full size. Wink
DB Custom
DB Custom's picture
Laugh out loud Wayne! Thanks! Now my kid will never get to sleep! “What’s so funny Dad? So what’s so funny?”
MRsDNF
MRsDNF's picture
DBCstm wrote:
Here's a bonus, the last of the Ti bar. Fred made a pill fob for my wife by my request in order to use the rest of the 1" bar. This series of pictures you can thank MRsDNF for, enjoy!
No I did not make this or take the pictures. I just inquired about it.
Thanks for nothing DBCstm. I will no longer post any pictures of any machining I do. I'm just not worthy. Cry
DB Custom
DB Custom's picture
I’ve seen your work man, post em up! That little scope looking mini is awesome, send it to me and I’ll take some pics for you. Wink
I tried to show the little pill fob against common objects so’s you could get a sense of it’s size. My mojo was off but I’m happy with a couple of these, especially the ones in front of the P-60 and in my wife’s hand.
Glad you like em.
Bottom’s up!
Chloe
Chloe's picture
Last seen: 5 years 1 month ago
Wow!! Shocked Incredible work. Thanks for sharing!
Buwuve
Buwuve's picture
Last seen: 4 years 4 months ago
It looks fantastic. Thank you for the many pictures. I haven’t the equipment or the ability to do such a great work. For me it’s really nice to see, how such a great product was produced.
Light up the darkness.
DB Custom
DB Custom's picture
I’m a photographer. Can’t help myself. So, with that being said, here’s a new shot I just took for a size comparison evaluation. This picture is a stacked macro comprised of 62 individual shots merged together to get this one highly detailed picture. Nothing spectacular about the Solarforce L2P used here other than the Gold color. But, the AAA MiniMag recently acquired from O-L is a very cool little light! I hope to chop it to a single AAA and with that in mind started taking some measurements. That’s when I realized that in chopped form it will be almost exactly the size of the Texas Poker shown above! The chopped AAA MiniMag in this photo is not actually chopped….I took the liberty to Photoshop it to show the result if I’m able to pull it off. Go ahead, look at it full size in Flickr and see if you can find the “seam” lol
Chopped AAA Mini Mag vs L2P 62P
