Review: Small Sun ZY-T08 2x18650 XM-L T6 from Fasttech
This may come as a shock, but I do not own the T13. Based on the styles, and hearing the same thing you did, I went with the T08. If you have one of either, getting the other would be to collect (perfectly valid reason :wink: ), or to check out the other format.
My major mod is a surprise, parts are ordered. :wink:
I would recommend XM-L2 on copper. This light really can handle heat well. I think 4A is a minimum drive level.
Sourcing a coated lens would be nice too.
If the crelant head fit on this, it would have been a no brainer for me. This host looks like it would handle the heat a lot better
I think he also added copper braid on the tail spring.
Thanks Relic for the review! Any noticeable change after adding the copper braid?
Adding copper braid (alternative is soft stranded copper wire) to the springs brought the voltage drop way down. Before was 240mV drop across spring and switch. After, 48mV. That’s an extra 200mV for the driver to remain in regulation. On many popular batteries, that could be an extra 20 minutes of runtime at full output.
Edit: Almost forgot to mention the efficiency improvement with this mod. Small (maybe 3-5%) but every little bit counts. :wink:
Thanks Relic!
Excellent review AND terrific photos. You got it all, relicc38 :bigsmile:
Great review relic. As an aside. The lanyard lgs allow an excellent secure cigar grip. I think this light really wants a copper slug pressing in to mount a 4 - 5a driver then use the original as a contact board.
Relic38,
I have one of these arriving this week (hopefully).
Would you mind explaining or posting link to what “Adding copper to the springs” means.
Thanks for your time.
At that price, if Small Sun fixes the improperly machined surface that the LED star attaches to, this will be a really nice host! Since the switch is mechanical, there are MANY driver options if this one isn’t preferred.
relic: Thank you for the great review! Because of you, I’m now considering one of these :stuck_out_tongue:
By copper, I mean copper braid or soft copper wire. Take a close look at the pixture of the board with two springs on it. You will see copper braid running down the center of each spring. It is soldered on each end to the spring. This greatly reduces the electrical resistance of the springs which improves run time with full output and overall efficiency.
I’ll clarify the wording in the review and consider doing a quick how-to guide post on this.
Thanks!
Nice review sir! You make it hard to keep resisting this light.
Nice review! Got mine Friday from FastTech, got all the parts to mod it. Been working on it - same idea as you. Using a Nanjg custom programmed at 4.2A, using the original driver board as a contact board, stripped, and XM-L2 U2 1C on a sinkPAD w/copper disc under the SinkPAD. Hoping to finish it late today if all goes well. Been taking photos, I could post here in this thread if you don't mind.
My measured stock #'s on 2 fresh Panasonic 3100's, unprotected:
- stock lens, 2.1A, 656 @start, 639 @30 secs
- with UCL/p lens: 673 @start, 653 @30 secs, 48 kcd throw
The UCL/p lens I had was an extra, using the same size in a HD 2010.
Tip - I am definitely getting better results with low resistance batteries for XM-L2/SinkPAD's. The Samsung INR's do slightly better than Panasonic PD's or AW IMR's. Using 2 Samsung INR's and 1 Pana PD in my 7G9 w/XM-L2 SinkPAD, I actually got 4.2A measured, more lumens, more throw.
Hi Tom E, nice to see our stock numbers match quite well. The XM-L2 mod should give impressive throw numbers, looking forward to seeing what you get. :wink:
Great review! Looking forward to your mods!
-Garry
Numbers are in... Ready?
1,302 lumens at start, 1,281 lumens at 30 secs, 94 kcd -- 2 Pana PD's from FT (no tailcap spring mods, but added a magnet on each batt neg end, and dab of solder on the pos end to get contact - tops are pretty flat)
Oh - didn't give the batts time to fully charge, though probably close.
Some issues with the lens/reflector/emitter but got a working solution. This is because of the thinner UCL/p, adding the copper disc soldered under the SinkPAD, and biggest issue: oh boy -- going from a 25mm star to a 20mm star put the wires closer and interfering with the reflector seating down on the plastic emitter alignment piece. Crappy plastic reflector extends out too far. If only I could have miraculuously recessed the wire/solder points on the SinkPAD... Sort of jury rigged a working fix, but its ugly - afraind to open here up for pics though....
I'll be re-charging 2 Pana 3100's and the Pana PD 2900's to re-test, maybe slight improvement.
Running - 1 min: room temp basically, 2 min: 82 at hottest, 3 min: 83F hottest, 4min: 85F hottest warm to the touch, 5 min: 87F ... wow! This is one cool dude at 4.2A!
Updates:
- little more on fresh batts, both Pana 3100's and Pana PD 2900's got the same exact #'s for each set: 3.92A measured at tailcap (well, 2 batts held together, common neg) - 1,339 lumens at start, 1,315 lumens at 30 secs, still 94 kcd
- made the tailcap solder wick mods as OP (relic38 did (no more magnets on batteries)
- changed the button to GITD (allen head screws were loose originally as well)
Great results Tom E! too bad about the reflector. I’ll have that issue too. I think there is extra material that can be ground off the base of the reflector to allow for wire clearance.
Edit, Update to go with Tom E’s update
Good stuff, looks like it is regulating then. The spring mod gives a lower resistance path to the regulators, so they can do their job for longer.
That’s a great result overall Tom E. I might need to see how I can 1-up that… :wink:
This model is parallel.
-Garry
Well this light is about the same size as an HD 2010, weight I measured was identical, and you can get a triple HD 2010 but everyone says it's no good. Main point of this light with it's big reflector is throw w/good spill, so 1 LED is best for throw. Triples that can throw are huge (BTU shocker, etc.). Plus battery drain on triples kind of warrants more batteries, so also back to bigger.
Hey, don’t get mad for Replying to this. The reason, if someone please by the clone, and review it, we might know which is the best — the clone or the anti-clone J)
