The latest and final round of emitter tests are done and complete. The first post has been updated to include the Nichia219, along with the xpg2 and xpe2 comparisons of aluminum pcb vs the copper sinkpad.
Also, you'll notice that I deleted the vF graph for the XML2. For complete transparency reasons, here's why: During an equipment audit, I noticed that my trusty Fluke wasn't that trusty anymore despite being within it's cal date. I have since swapped it out with another proven unit and ran a retest. New vF graph to be up shortly.
That test helps make sense of the TN31mb. I’ve tested mine at 741otf at 30sec. I just wondered how in the crap in Saabluster do that. But now I can see a XP-g2 on copper can get those type of numbers. I wonder how much difference the dedome made on its output? Likely not much I would guess since it still has 741 lumens.
Anyway, thanks Match for the very informative tests. Awesome work!
Measured at the tail, my X7 driver pulls 4.59A from 3 x 18650 cells, so the emitter probably sees around 4A. Id like more throw so Im thinking about swapping the SST-50 for a dedomed XPG2 or XML2 on sinkpad. 4A would be pushing it for the XPG2 and Im not sure it would survive. The TN31 MB puts out a beam like a laser on dedomed XPG2 and Id like to have something similar. I have no idea how the X7 reflector would focus an XPG2/dedomed.
Theoretical:
XPG2 - 925 lumens before dedoming. After?… Im not sure. Maybe 600?
XML2 - 1390 lumens
Anyone have any thoughts on this?
Match, thanks for all the data and your hard work. The new possibilities are almost endless!
Match, your nichia numbers reflect what I've seen on mine. I have a nichia 219 in a tr-801 with a driver that lets an xm-l pull 3A. With a nichia it pulls only 1.65A which coincides with your findings.
Again match your work is invaluable. Thanks for the huge effort doing this for us. My only concern though is that no one will build a light like we have before. I'm doing a mod on a particular flashlight at the moment that I thought was all planned out. XM-L2 on a copper star on a beefy copper pill in a large ally housing running a 5 amp buck boost driver. Do I now have to get a 9 amp driver to run the XM-L2 at its peak? Bugger, it never ends. Cheers and thanks again.
PS. Maybe I could use the 5 amp driver on a killer XP-G2 build?
These types of post are one of the reasons I check forums. Provides such a wealth of information! You’ve inspired me to build an integrating sphere once I find the time.
Thanks a lot for all of your work for this forum and it members Match. Your contributions stand second to none and are head and shoulders above anything I've managed to put forward.
A friend just pointed this out to me: Lightmall are now using these graphs on their XM-L2 product page and claiming “1770 lumens” on some of their XM-L2 torches.
They prove they can't understand the CREE datasheets too much, "maximum driver current 6200mA". They neither specify the bin of the XM-L2, they don't understand that either.
Actually there are many stores that simply copy the other store and I am sure they don't even understand what they sell, but since it's popular on the forums they got to sell it.
since they don’t point out theirs is not a sinkpad (or even mentioning the word sinkpad or massive amounts of heatsinking), i can imagine some non forum person thinking they can buy this and put 6200mA into it then seeing the puff of smoke or potential fire
