Hi Tom E, nice to see our stock numbers match quite well. The XM-L2 mod should give impressive throw numbers, looking forward to seeing what you get.
Great review! Looking forward to your mods!
-Garry
Numbers are in... Ready?
1,302 lumens at start, 1,281 lumens at 30 secs, 94 kcd -- 2 Pana PD's from FT (no tailcap spring mods, but added a magnet on each batt neg end, and dab of solder on the pos end to get contact - tops are pretty flat)
Oh - didn't give the batts time to fully charge, though probably close.
Some issues with the lens/reflector/emitter but got a working solution. This is because of the thinner UCL/p, adding the copper disc soldered under the SinkPAD, and biggest issue: oh boy -- going from a 25mm star to a 20mm star put the wires closer and interfering with the reflector seating down on the plastic emitter alignment piece. Crappy plastic reflector extends out too far. If only I could have miraculuously recessed the wire/solder points on the SinkPAD... Sort of jury rigged a working fix, but its ugly - afraind to open here up for pics though....
I'll be re-charging 2 Pana 3100's and the Pana PD 2900's to re-test, maybe slight improvement.
Running - 1 min: room temp basically, 2 min: 82 at hottest, 3 min: 83F hottest, 4min: 85F hottest warm to the touch, 5 min: 87F ... wow! This is one cool dude at 4.2A!
Updates:
- little more on fresh batts, both Pana 3100's and Pana PD 2900's got the same exact #'s for each set: 3.92A measured at tailcap (well, 2 batts held together, common neg) - 1,339 lumens at start, 1,315 lumens at 30 secs, still 94 kcd
- made the tailcap solder wick mods as OP (relic38 did (no more magnets on batteries)
- changed the button to GITD (allen head screws were loose originally as well)
Great results Tom E! too bad about the reflector. I’ll have that issue too. I think there is extra material that can be ground off the base of the reflector to allow for wire clearance.
Edit, Update to go with Tom E’s update
Good stuff, looks like it is regulating then. The spring mod gives a lower resistance path to the regulators, so they can do their job for longer.
That’s a great result overall Tom E. I might need to see how I can 1-up that…
This model is parallel.
-Garry
Well this light is about the same size as an HD 2010, weight I measured was identical, and you can get a triple HD 2010 but everyone says it's no good. Main point of this light with it's big reflector is throw w/good spill, so 1 LED is best for throw. Triples that can throw are huge (BTU shocker, etc.). Plus battery drain on triples kind of warrants more batteries, so also back to bigger.
Hey, don’t get mad for Replying to this. The reason, if someone please by the clone, and review it, we might know which is the best — the clone or the anti-clone J)
I think that is a rebrand, not a clone. The driver looks exactly identical. I can’t say the innards are the same, but I would not be surprised if these lights are one in the same, different name.
Agreed, even tge lanyard looks the same.
I’m harbouring a plan of getting a hunk of copper, getting my dad to machine it to a press fit in the pill to carry both this driver and a direct bonded xm-l2 then use tge original driver as a contact board.
I have no sinkpads so I have to do it the hard way…
Looks good. Take that driver, replace all wire with 18 gauge, direct solder to contact board. Do the spring mod, and you should get 5A on fresh cells. Not sure for how long, but with a huge chunk o copper to work with, heat would not be an issue.
Another option apears to have presented itself…
What was needed for a sink pad? I’m still using that driver, I figure it’ll give 4.5a ish given my experience of the 4a version.
Hi relic, thanks for the detailed review. What is the diameter of the threaded part of the pill please?
Woody
- Pill Outer Diameter at threads: 31.7mm
- Pill Outer Diameter before threads: 33.1mm
- Pill Outer Diameter at driver flange: 34.0mm
- Head inner diameter at pill threads: 31.1mm
- Head inner Diameter before threads: 34.4mm
Info added to review as well. Thanks!
Thanks relic, I was worried that you might think I was taking the p1$$, as you had already provided so many other dimensions!
Woody
I’ve added some indoor beamshots to the review. They appear darker on here, maybe a Photobucket effect. I might have to reshoot them brighter than I see to adjust.
Thanks for the great review. I’ve been debating which one to get the HD2010 or this ZY-T08, but now I think it’s this one. I didn’t know they were so cheap at Fastech. thx
Thanks very much for the review! Frontpage’d and Sticky’d.
Great review relic! What size braid is that?
I have Soder-Wick #3, which measures in at 1.9mm wide. It carries oodles of current. I tested 5 inches of it once at 6A and it registered 18mV IIRC.
I’ve heard that Goot Wick is not as good, it might not be pure copper. I do not have that to try.
Soder-Wick is more expensive but works very well for ‘fixing’ springs, and its intended purpose.
Edit: I get my Soder-Wick from Digi-Key.
