Test / Review: Efest 16340 850mAh (Black)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 8 min ago
DSC_1767
Official specifications:
  • Operating voltage: 3.70
  • Capacity: 850mAh
  • Ultra-high capacity and premium built quality
  • Protected to avoid over-charged or over-discharged
  • Built-in PCB protection board
Efest%2016340%20850mAh%20(Black)-info
This battery is a short 16340 battery, making it easier to fit instead of a CR123 battery.
The capacity is considerable lower than specified as is usual the case with 16340 batteries.
Internal resistance is calculated between 1A and 2A.
DSC_1766
DSC_1768 DSC_1769
DSC_1771
DSC_1772
DSC_1773
Efest%2016340%20850mAh%20(Black)-Capacity
There is a large difference in performance between the two batteries, this is not good for use in series.
Their upper current limit is also rather low, the performance at 2A is not very good.
Efest%2016340%20850mAh%20(Black)-CapacityTimeHours
Efest%2016340%20850mAh%20(Black)-Energy
Efest%2016340%20850mAh%20(Black)-PowerLoadTime
Efest%2016340%20850mAh%20(Black)-TripCurrent
The two batteries does not have the same protection threshold , one is at 2.9A, the other at 5A.
Efest%2016340%20850mAh%20(Black)-Charge
Conclusion
I am not very impressed with these batteries. They can be used on at a time, but with the differance in capacity, they are not very good for use in series.
Notes and links
Comparison to other LiIon batteries
Edited by: sb56637 on 08/26/2014 - 17:45
DimBulb
Last seen: 8 years 1 month ago
And is 1/4 ohm like the table says?
The curves may show different values for this but I can’t make out the color legend.
HKJ
HKJ's picture
Yes, the DC resistance is 0.25 ohm.
DimBulb wrote:
The curves may show different values for this but I can't make out the color legend.
Next time I generate curves the legend will use thicker lines.
The internal resistance is calculated from the "Protection Test" curve and you will not get much help in reading that from thicker legend lines.
DimBulb
With that curve I get (4-3.5)v/(3-1)A = 0.25 ohm or (4-2.3)v/(5-1)A = 0.43 ohm, avg.
Seems like nothing with cells gives a straight line and coming up with a formula for even a single discharge curve would be pretty difficult.
Back to the piece-wise linear approach. Sad
SashiX
SashiX's picture
Last seen: 7 years 1 month ago
Hm, mine have bigger nipple Flat Stare
http://budgetlightforum.com/node/18593
And… this review shows that they are better than AW at 2A Flat Stare Well, they are better in general.
What happened here? First XX good samples and then… s%&t ??? Very disappointed Sick
HKJ
HKJ's picture
DimBulb wrote:
With that curve I get (4-3.5)v/(3-1)A = 0.25 ohm or (4-2.3)v/(5-1)A = 0.43 ohm, avg. Seems like nothing with cells gives a straight line and coming up with a formula for even a single discharge curve would be pretty difficult. Back to the piece-wise linear approach. :(
That is the reason I calculate it between 1A and 2A, when you put a heavy load on a cell the curve will not be linear and you will get to high a value (Except if you plan to use the battery at high currents).
MRsDNF
MRsDNF's picture
Last seen: 1 week 2 days ago
Thanks HKJ. We need a 3000 mAh capable of 3.5 amp discharge in this size package. Next year maybe. Cheers.
djozz
djozz's picture
Last seen: 4 hours 31 min ago
Thanks for another usefull test, I'll stick to my Nitecore 16340 then.
sb56637
sb56637's picture
Last seen: 17 hours 58 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
scheven_architect
Last seen: 3 years 5 months ago
sirockalot
sirockalot's picture
scheven_architect wrote:
where can you buy these :)?
is this a 16340 http://www.fasttech.com/products/0/10001848/1134001-nitecore-nl166-rcr12... ?
yes they are, I have a few
