The Powerlight that I linked to adds a new feature- It disassembles on both ends. Slightly different color too. I'm curious.
You could also try that xtar rechargeable light on special on that thread around here.
That one also looks good.
So many lights. So little money :(
BestOfferBuy's price is excellent for that Tank007. If the specs are right, I'm sure you'll love it Mr. Admin.
I don't have a recommendation for Don, though. I have a question: Which XM-L lights do you already have, Don?
Not all that many. Most of mine are mods.
A few XM-Ldropins from Manafont and KD and an EastwardYJ J06 from DX.
I want more of them that I don't need to mod.
I don't own any XM-L lights (yet), but how about the popular KD C8 CREE XM-L T6 1000 Lumen 5-Mode LED Flashlight?
Don,
I have the OP one that FlashPilot reviewed and I just received the smooth reflector version. To me, it has the same (or close enough) amount of spill but the throw is noticeably stronger. If I could only have one, I'd get the one with the smooth reflector. It's $26.34. For the money, this light is going to be hard to beat.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11284
It's a little over your price range, but it needs no mods.
1. Three modes low, medium and high, no stupid strobe modes.
2. Brighter than my brightest light, my KD-C8.
3. An XML thrower, hard to believe but what a hot spot.
4. Absolutely awesome heat transfer.
5. Great threads and a real quality feel.
6. Put a little lube on the o rings, pop a battery in and it's play time.
Did I mention how much I love this light.
Nice looking light, E1320! I like how it has 3 usable modes. Is the stainless steel assault crown removable?
Yeah it's removable and needs to be "foyerized". At least the manufacturers are starting to get the hint about the stupid strobe modes, next improvement assault crown delete.
raccoon city:Is the stainless steel assault crown removable?
Does the flashlight function correctly with the crown removed?
raccooncitydoesn'thavethetoolstogrindthecrown
sorryforhijackingthisthreadbutinquiringmindswanttoknow
E1320: raccoon city:Is the stainless steel assault crown removable?
The crown holds the lens and the reflector into the light. If you check the link you can see the pieces it holds in.
Wow, brighter than the KD C8? That's impressive. How does it compare regarding flood to the C8?
E1320:
Don, so sorry for the thread hijack. At 20 feet the hotspot is one half of the size of the C8s.
I was looking at the TK-737 earlier on PriceAngels, You can get a little screw in extension so you can use it with 18650's - http://www.priceangels.com/Tank737_Flashlight_Extension_Tube___Ring_p5258.html
Does the extension really work? fed up with the problem about shortening ……
This one
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11307
I have never seeen this one before. Slightly bigger than a TR-801, with side clickie and stainless both ends, SMO reflector. Could this be a hoist for a XM-L?
http://www.manafont.com/product_info.php/trustfire-f15t6-3mode-1600lumen-led-flashligh-118650-p-6312
It would be better if they could put a SMO reflector in there.
Available separately at the same dealer. :) C8 reflector *Hint*
