Test / Review: BattEnergy 18650 3400mAh (Black)
Official specifications:
  • System: Li-Ion
  • Voltage: 3.6 V
  • Capacity: 3400 mAh
  • Size max: 69.5 mm x 18.5 mm Ø
  • Weight: 48 g
  • Protection: 7A
  • Maximum discharge current: 2C
  • Maximum charge current: 0.5 C
  • Manufacturer: Panasonic
  • Cell: 3400mAh NCR18650B
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
As usual with good cells, the discharge curves tracks very well.
Conclusion
This battery is using the best high capacity (for now) Panasonic cell and there was no problems in the test, i.e. it is a very good battery.
Notes and links
The batteries was supplied by Taschenlampen-Papst.de for review.
Made by EnerPower. ;)
Thanks for the great test as always HKJ. :)
Thanks very much for the review! Frontpage’d and Sticky’d.
