E1320
(E1320)
April 28, 2011, 11:13pm
18
http://www.manafont.com/product_info.php/ultrafire-uf980l-980lumen-t6-memory-led-flashlight-118650-p-5513
It's a little over your price range, but it needs no mods.
1. Three modes low, medium and high, no stupid strobe modes.
2. Brighter than my brightest light, my KD-C8.
3. An XML thrower, hard to believe but what a hot spot.
4. Absolutely awesome heat transfer.
5. Great threads and a real quality feel.
6. Put a little lube on the o rings, pop a battery in and it's play time.
Did I mention how much I love this light.
Nice looking light, E1320! I like how it has 3 usable modes. Is the stainless steel assault crown removable?
E1320
(E1320)
April 28, 2011, 11:53pm
20
Yeah it's removable and needs to be "foyerized". At least the manufacturers are starting to get the hint about the stupid strobe modes, next improvement assault crown delete.
Does the flashlight function correctly with the crown removed?
raccooncitydoesn'thavethetoolstogrindthecrown
sorryforhijackingthisthreadbutinquiringmindswanttoknow
E1320
(E1320)
April 29, 2011, 12:29am
22
The crown holds the lens and the reflector into the light. If you check the link you can see the pieces it holds in.
jb1
(jb1)
April 29, 2011, 12:30am
23
E1320:
Wow, brighter than the KD C8? That's impressive. How does it compare regarding flood to the C8?
E1320
(E1320)
April 29, 2011, 12:45am
24
Don, so sorry for the thread hijack. At 20 feet the hotspot is one half of the size of the C8s.
Piers
(Piers)
April 29, 2011, 1:39am
25
I was looking at the TK-737 earlier on PriceAngels, You can get a little screw in extension so you can use it with 18650's - http://www.priceangels.com/Tank737_Flashlight_Extension_Tube___Ring_p5258.html
Huge
(Huge)
April 29, 2011, 2:13am
26
Does the extension really work? fed up with the problem about shortening ……
Oldienea
(Oldienea)
April 29, 2011, 2:18am
27
This one
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11307
I have never seeen this one before. Slightly bigger than a TR-801, with side clickie and stainless both ends, SMO reflector. Could this be a hoist for a XM-L?
Budgeteer
(Budgeteer)
April 29, 2011, 2:45am
28
Oldienea
(Oldienea)
April 29, 2011, 6:16am
29
It would be better if they could put a SMO reflector in there.
Budgeteer
(Budgeteer)
April 29, 2011, 6:41am
30
Available separately at the same dealer. :) C8 reflector *Hint*
BlueBeam
(BlueBeam)
April 29, 2011, 7:16am
31
JB1:
Don,
I have the OP one that FlashPilot reviewed and I just received the smooth reflector version. To me, it has the same (or close enough) amount of spill but the throw is noticeably stronger. If I could only have one, I'd get the one with the smooth reflector. It's $26.34. For the money, this light is going to be hard to beat.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11284
Can you measure the current draw of both the OP version and smooth version please.
Sorry for the thread highjack...Don, I have no good suggestions for you but the Nextorch might be a good idea.
BlueBeam
(BlueBeam)
April 29, 2011, 7:35am
32
Hey Don I was just looking around and this one is kind of neat http://kaidomain.com/ProductDetails.aspx?ProductId=11307
It has a side clicky and some nice shiny accents!
Wow, for those that are keeping track, that's the third apology (from three different individuals) for hijacking this thread.
And it seems that all three are probably unnecessary!
Well that's strange, I thought the TK-737 was supposed to be compatible out of the box with 18650? That's what it claims on most of the product pages on most sites with the exception of Priceangels.com
Don
(Don)
April 29, 2011, 3:20pm
36
Indeed - given that I'm particularly guilty of this. And not just in forums - I do it all the time everywhere else too.
Budgeteer
(Budgeteer)
April 29, 2011, 3:27pm
37
I admit i have this issue too. :S
