Does the flashlight function correctly with the crown removed?
raccooncitydoesn'thavethetoolstogrindthecrown
sorryforhijackingthisthreadbutinquiringmindswanttoknow
E1320: raccoon city:Is the stainless steel assault crown removable?
Yeah it's removable and needs to be "foyerized".
The crown holds the lens and the reflector into the light. If you check the link you can see the pieces it holds in.
It's a little over your price range, but it needs no mods.
1. Three modes low, medium and high, no stupid strobe modes.
2. Brighter than my brightest light, my KD-C8.
3. An XML thrower, hard to believe but what a hot spot.
4. Absolutely awesome heat transfer.
5. Great threads and a real quality feel.
6. Put a little lube on the o rings, pop a battery in and it's play time.
Did I mention how much I love this light.
Wow, brighter than the KD C8? That's impressive. How does it compare regarding flood to the C8?
E1320:
Don, so sorry for the thread hijack. At 20 feet the hotspot is one half of the size of the C8s.
I was looking at the TK-737 earlier on PriceAngels, You can get a little screw in extension so you can use it with 18650's - http://www.priceangels.com/Tank737_Flashlight_Extension_Tube___Ring_p5258.html
Does the extension really work? fed up with the problem about shortening ……
This one
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11307
I have never seeen this one before. Slightly bigger than a TR-801, with side clickie and stainless both ends, SMO reflector. Could this be a hoist for a XM-L?
http://www.manafont.com/product_info.php/trustfire-f15t6-3mode-1600lumen-led-flashligh-118650-p-6312
It would be better if they could put a SMO reflector in there.
Available separately at the same dealer. :) C8 reflector *Hint*
Don,
I have the OP one that FlashPilot reviewed and I just received the smooth reflector version. To me, it has the same (or close enough) amount of spill but the throw is noticeably stronger. If I could only have one, I'd get the one with the smooth reflector. It's $26.34. For the money, this light is going to be hard to beat.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11284
Can you measure the current draw of both the OP version and smooth version please.
Sorry for the thread highjack...Don, I have no good suggestions for you but the Nextorch might be a good idea.
Hey Don I was just looking around and this one is kind of neat http://kaidomain.com/ProductDetails.aspx?ProductId=11307
It has a side clicky and some nice shiny accents!
Wow, for those that are keeping track, that's the third apology (from three different individuals) for hijacking this thread.
And it seems that all three are probably unnecessary!
Ahem, post #26.
Piers:I was looking at the TK-737 earlier on PriceAngels, You can get a little screw in extension so you can use it with 18650's - http://www.priceangels.com/Tank737_Flashlight_Extension_Tube___Ring_p5258.html
Well that's strange, I thought the TK-737 was supposed to be compatible out of the box with 18650? That's what it claims on most of the product pages on most sites with the exception of Priceangels.com
BlueBeam:Sorry for the thread highjack...Don, I have no good suggestions for you but the Nextorch might be a good idea.
Indeed - given that I'm particularly guilty of this. And not just in forums - I do it all the time everywhere else too.
I admit i have this issue too. :S
raccoon city: BlueBeam:Sorry for the thread highjack...Don, I have no good suggestions for you but the Nextorch might be a good idea.
Me too.
So, how about the weather this spring? Pretty nasty eh?
Do you have one of this already?
Of course for modding into a nice pretty neutral R4-r5 with a decent driver, maybe stolen from the famous one and only ramping dropin at dx?
A set of KD multicoated lens...
Don: raccoon city: BlueBeam:Sorry for the thread highjack...Don, I have no good suggestions for you but the Nextorch might be a good idea.
Me too.
Actually beautiful :)
No rain for a week - lovely sunny days, but the peak temperature today was 14C (57F). Currently 8C (46F). No wind worth noticing either. It's been a lovely week - especially as there were two public holidays, Monday (Which I sorta, kinda worked) and today for a wedding of a junior royal - first royal wedding that we got a holiday for since 1981. Gave that the body-swerve completely - I've not consumed any media at all today. Instead I played with the assistant in the sun.
Monday coming is also a public holiday but I'm working Sunday and Monday. Or at least, I'll be present at work on Monday and deal with anything urgent. Might even tidy the office and move some furniture around there.
