Okay, the tension is building here at battery pack central. We have the main cover off. And we have ……
STOOPID security torx screws. Had to drill out two holes to get a driver in there …… But I drilled out the holes because even with two screws out, I could pry the pack slightly open. Inside I could see, in all their glory ……
Did you hear the one about the watermelon salesman and the farmer’s daughter? Well, it’s late one night in the Texas gulf coast and this nattily dressed dude in a straw hat and ……
Did I see a wink of red inside there? Yup, cover is now off and we have —- YES!!!——- red Sanyos!!! Now to see the numbers, I will have to go in deeper.
On a side note, there is a button on the side you can push to check charge level. Don’t have to worry about getting a pack with dead cells. Just push the button and see the charge level!!!
Okay, I now have to pull them outta their cage to get at them, so I will be gone for a while. But I will report back about the farmer’s daughter …. I mean the mah on the Sanyos.
No, they were on a clearance shelf in garden by the string trimmers, which is what the pack is for. I have the cells out and am looking them up now. TEN bright and shiny Sanyos. All 3.60-3.65 volts.
I do have to say that this pack was the hairiest one I have disaasembled and I have taken apart quite a few at this point. Definitely NOT for the timid.
The cells are stacked neg pole to positive in the cage. You MUST be extremely careful when stripping off the contact tabs. I won’t say I was sweating bullets, but there were a couple minor puckers. And one minor shower of sparks. Really. I slipped.
To remove them from the cage, you must pull off the tabs, which is extremely difficult to do without contacting the opposite pole in the next cell row. Hard to explain, but you will see it in person if you decide to do the deed.
Now to see what these are. I assume they are 1500 mah. Back in a bit.
Found one. Top shelf burried with a bunch on random stuff lol. Guy had to get a ladder to get it.
Yup on sale. $23.14 after tax. Only shows 1/4 full though…
1500 mah as suspected. Gonna dremel off the burrs and charge em up and see how they do. Never had new 1500s before. The used 1500 sonys and Samsungs seemed to work pretty good in the lights I tried, but I never really did any scientific load tests.
However, I DID run some in my test flashlight and ended up with 3.80-3.90 volts in the cell after 30 minutes, which is pretty much what I end up with for 2600s. Someone with more li-ion-load knowledge than me will have to chime in on whether these are really comparable to a “normal” 2600.
Mine was also 1/4 charge on the little led meter on the pack. All cells were 3.6-3.65 as I said.
What will be great in a couple years: The new 2600 mah tool packs will start going on sale and showing up in recycle bins. Those will be a treasure trove!
>>>>>are these the cells inside it? AW IMR 1600mAh v Efest IMR 1500mAh v Sanyo UR18650W2
It appears to be the Sanyo with the pink ring to the right. There is the possibility that some packs will have different cells. Not likely I would think, but possible. I have seen computer battery packs: same model, different batteries.
How much do these cells cost loose? I’d hate to find out they are only $2-3 a piece lol
Red cells pink rings here… This black holder is going to be a pain to get apart. Or is there a trick?
>>>>>If anyone sees a bunch and snaps up an extra I would be interested in buying it.
Scaru, I would have mailed one to you, but I just went back and the other two, they be gone now. Sorry.
Guy I talked with in garden dept said some guy came right in after me and bought the other two.
Another BLFer living very close to me where I’m staying in the OC, Calif.? Probably not. Probably someone who saw it on fatwallet. Fat wallet people buy a lot of these sale items and resell em on flea bay.
So we are not the only ones who know about it, so if you want one, might be best to grab one or two. You can always return it to HD months after you buy it.
As for using these in lights? I have NOT used the Sanyo tool 1500 mah cells. I have used the Sony and Samsung ones, which seem to work on par with “normal” 2600 cells, BUT YMMV. I did NOT do scientific comparison tests.
Has anyone done any real tests on any 1500-mah tool cells? Am I the only one on BLF who has used them? That’s hard to believe.
