the stock pill has a raised 16mm pad. did you machine that down or just leave it so there is an air gap around the outer edge of the 20 mm sinkpad? the lens in the ones i’ve built are 38.02 mm. yours is 32mm?
There was indeed a raised 16mm pad, i left it like that, I reckoned that a 16mm diameter solder joint was more than enough for the heat to get away and the brass under the gap was thick enough to maintain a good heat-path.
The lens when taken out of the flashlight is indeed 38mm, but in the flashlight, with the retaining ring in place, 32mm is effectively used.
Very cool! Good job there. I’d love to have a lil thrower like that.
My plans have been wrecked from the start. I ordered a UF-V3 type light from DX and they sent me an aspheric. I ordered two 16mm xp-g2 from ff and they sent them to me on 10mm stars.
Thank you Tecmo, you were the start of this. Hope your plans come together soon, the UF-V3 seems like a very good light. High time you learn how to reflow leds then .
do you have any stock lights or maybe a c8 to compare readings to? nice light by the way. over 100k is good numbers. i was just hoping for something to compare my thrower lux to when i get my meter, as im sure my meter will be less than accurate lol
I'm sorry, nothing is stock anymore when in my posession for a while . And I'm the only flashaholic who does not own a C8 (don't like the design).
My ceiling bounce lux-readings are always compared to a Thrunite Ti with a fresh Duracell alkaline (that is said to output 60 lumens), to convert them to lumens. So the lumen numbers are not very accurate, but I would be surprised if they are more than 10% off.
Has anyone here on BLF actually calibrated their luxmeter? Is it doable at all?
you are not alone. i don’t have a working p60 host(as long as enough parts to put one together doesn’t count) or an sk68 either…but i do have two c8’s!
Thank you for such a great detailed how-to post. I have 3 T20’s and have been rather pleased with their stock performance. But now after reading your post, Im completely amazed with your results in such a small and easily modded package. Your reflow of the sinkpad directly to the brass pill was brilliant! In an age with more and more AL pills, its nice to still find some made of brass. I have 20mm sinkpads and some 16mm on order. Thanks to you and tecmo, we all now have a relatively easy conversion for the cheap pocket mega-thrower. Also, I didnt realize the lenses were glass. They are all very good quality in the 3 examples I have, as are the hosts. I also agree with your observations about the heat sinking. Even when not on sale, these lights are still a great bargain. IMO, buy them before they change the pills to aluminum. Those are usually the first changes they make when trashing a once great light. Next will be the lens.
I just realized that my T20’s were purchased at wallbuys… I hope the pills are brass. Anyone know?
Edit - its brass.
Probably a silly question, but after your mods, are you happy with the lights performance at the fringes of its range? In other words, does it throw photons way out there?
Great mod, I love it. The UF-T20 is a great light to mod. I have a direct drive single mode XRE R2 in mine mounted to my scoped rifle. It easily out throws anything else I have, plus I like the fact that the zoom is threaded so it won’t zoom out from the recoil of my .308.
I got a stock T20 from WallBuys, and yes, it does have a brass pill, actually it's a C8 sized brass pill, so got some flexability there. I got an XP-G2 on a 20mm SinkPAD waiting on what to use it on - this sounds perfect, though it's got the dome.
Im with you on that nightcrawl do the same thing to a C10. I personally like the C10 better, in the looks and it performs better then in the xre (green) department.
Put it in Tom! Interested in whats the difference in dome and no dome!
thanks for posting this. I’ve been considering almost the exact same mod. I already did the sinkpad soldered to brass pill with a green xpe, but for the next one I’m going with white, but haven’t decided which emitter.
I think I’d prefer xpg2, but I might do xml2 with everything else the same (though I prefer 5000k) so we can compare numbers.
Haven't been camping with it yet, just annoyed some neighbours by searchlighting the little square I live in. I have a reflector based budget thrower build (49mm reflector, dedomed xpg2, 2A) that throws 70 klux, and I don't like the spill much because everything in close proximity is lighted up as well and so distracts from what you want to light up in the distance. This one effectively has no spill at all. And I can also hearthily recommend a neutral tinted led for a thrower like this, very nice in the outdoors.
But to directly answer the question: o yes, those photons get there alright! Huge fun!
Simply amazing results! I can't help but think that it would be even better if the LED was not dedomed. Dedoming works great on a reflectored light because it's the spread of unfocused light from the LED hitting the reflector that helps focus and throw the light down range. In an aspheric light you want the light from the LED focused into the center of the lens, not the walls of the head. Leaving the dome on the LED should focus more of the light into the center of the lens than the same LED without a dome.
I had an XR-E ftt light that I accidentally dedomed and it ruined the output in comparison to when it still had the dome.
